How do you get spray paint off?
Discussion in 'Detailing' started by Sheepdog, Nov 8, 2009.
  1. Nov 8, 2009 at 12:29 PM
    Sheepdog
    Sheepdog [OP] Well-Known Member
    Gary
    San Diego, CA
    Black 2002 Tacoma Xtra Cab, 4x4, TRD, SR5
    Eibach/Bilsteins, Beefed shackles, Bushwacker Cut-Outs, Custom roll bar, TG Sliders, Elite Front Bumper, XRC8 Winch
    Here's my problem... I painted my badges on the tailgate because they don't come off easy and usually break. So I figured that if I just use painters tape and do a "REAL" good job, I wouldn't have to worry about getting the spray paint on the truck. Now I ripped the badges off because they came out REALLY bad and there are profile marks where the letters use to be. Does anybody know of a way to take the spraypaint off without messing up the truck's paint job?
  2. Nov 8, 2009 at 12:35 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    You could use a paint thinner or sand it off and repaint (only if you are re-painting it)
  3. Nov 8, 2009 at 12:38 PM
    4X4_TRD
    4X4_TRD Well-Known Member
    Justin
    San Diego, CA
    '03 Jeep RUBICON
    No front sway bar (does that count?)
    I have had a friend drive through wet paint on the road and decided a week later to try to remove it. It wasn't spray paint but WD-40 took it off. Not sure what it will do to your clearcoat. Might be worth a shot before you try re-painting it.
    I just looked it up and this might work for you.
    http://www.meguiarsdirect.com/product_detail.asp?T1=MEG+G1016
  4. Nov 8, 2009 at 1:04 PM
    bullshooter
    bullshooter Active Member
    central illinois
    08' Indigo TRD Sport 4x4
    access tonno
    try a clay bar from auto parts store. i used it on my wife's car when some vandals spray painted the side of her car bumper to bumper with red and black paint. works good
  5. Nov 8, 2009 at 1:18 PM
    Sheepdog
    Gary
    San Diego, CA
    Awesome. I can't pay to have it done by a shop or something and its not the whole tailgate so I just need something to do a small area.
  6. Nov 8, 2009 at 1:43 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    X2 clay bar can work wonders
  7. Nov 8, 2009 at 1:57 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Yeah - I'd definately try that first (with some buffing if needed).
  8. Nov 8, 2009 at 1:59 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Actually taking time to prep before you paint does even more wonders
  9. Nov 8, 2009 at 2:02 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    clay bar if that does'nt work wet sand with 2000 grit and then buff it out with a wool pad and about 1000 to 1500rpm and a cutting polish then wax. Its pretty simple to do good luck.
  10. Nov 8, 2009 at 3:09 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    acetone should work fine. I have done it plenty of times and never damaged the paint.
  11. Nov 8, 2009 at 3:13 PM
    Hologram
    Hologram Go with the flow
    Pensacola-Destin, FL 850
    03 Doublecab PreRunner SR5
    damn this came in just in time. i had spray painted my fenders black and got some residue on my impulse red. so i will try these.
  12. Nov 8, 2009 at 3:22 PM
    cutothechase35
    cutothechase35 Active Member
    VA
    Silver Tacoma 4x4 TRD Sport
    Coming Soon: Mud Terrain 33 Pro-Comps Hella Bulbs 4" Lift TRD Intake URD Mass Air Flow Sensor Calibrator Roof Rack with light bar Bull Bar with lights The list go on, but the budget does not.
    Clay bar. Wax compound and a buffer works great too. Had green spray and it came right off.
  13. Nov 8, 2009 at 3:32 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    oh my god....
    this thread
    :facepalm:
    this is why you take your time with projects
  14. Nov 8, 2009 at 3:33 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    DO NOT LiSTEN TO THIS GUY!!!!!
    acetone will DESTROY your paint!!
  15. Nov 8, 2009 at 3:34 PM
    DanGer
    x2 look at my previous post in this thread haha
  16. Nov 8, 2009 at 3:38 PM
    cutothechase35
    VA
    Eat it like acid more like it. :eek:
  17. Nov 8, 2009 at 6:24 PM
    Sheepdog
    Gary
    San Diego, CA
    Thanks for the input guys.
  18. Nov 8, 2009 at 6:29 PM
    Sheepdog
    Gary
    San Diego, CA
    The paint is about 2.5 weeks old. So it's had plenty of time to set, unfortunately.
  19. Nov 8, 2009 at 8:10 PM
    macgyver
    Brad
    Canton, GA
    I have used acetone many times to remove glue/adhesive as well as spray paint overspray and have NEVER had a problem with it messing up my paint. as long as you use it sparingly you should be fine.
    Let me clarify. I have painted quite a few cars in my time so I understand that excessive acetone can damage the paint. I have used to it cut down/thin paint before. But the clear coat is cured and hardened with his paint job so dipping a rag in acetone and lightly rubbing is not really going to do any damage. With the little amount you are applying it will evaporate before it does any damage. A little bit dipped on the end of a rag should be just enough to remove the overspray.
  20. Nov 8, 2009 at 8:27 PM
    Sheepdog
    Gary
    San Diego, CA
    It's ok brad, panda jerk isn't the most tactful person. Thanks for your input though. It's the principal that matters.
