How do you get the lettering off the tailgate?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NolaPKP, Oct 2, 2007.
  1. Oct 2, 2007 at 1:02 PM
    NolaPKP
    NolaPKP [OP] Active Member
    Slidell, LA
    PreRunner
    Sirius Radio, Rest is stock for right now
    Was just wondering if the lettering on the tailgate was just stuck on there or if i take it off will i leave a bunch of tiny holes where it was attached? I've seen some of you guys with blank tailgates and i like the look. lots sleeker.
  2. Oct 2, 2007 at 1:17 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    take them off the same way as the doors. same type adhiesive and all. as long as the adhiesive is warm and can be pulled off, there shouldnt be any chips.
  3. Oct 2, 2007 at 1:18 PM
    NolaPKP
    Slidell, LA
    PreRunner
    good deal. thanx
  4. Oct 2, 2007 at 3:55 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    One of the things the guys on the motorcycle forums do to remove tank lettering is to heat it with a blowdryer and then use fishing line to slip behind the piece.
  5. Oct 2, 2007 at 4:39 PM
    MR. NICE
    MR. NICE Member
    I just removed my emblems this weekend. I used a heat gun and fishing line.
    I then used a little rubbing alcohol to take off any left over adhesive.
    Then buffed and waxed the area. It took me about 45 mins to do the whole truck.
  6. Oct 2, 2007 at 10:48 PM
    sgoveas
    sgoveas Member
    dental floss also works well, it almost slices through the adhesive because its thin but pretty strong
    I've used it a few times to remove badging
  7. Oct 3, 2007 at 7:17 AM
    NolaPKP
    Slidell, LA
    PreRunner
    never would have thought of dental floss. thanx guys i'mma have to try that out this weekend
