How do you know if you have the TSB Installed
Discussion in 'Suspension' started by testedone, Oct 17, 2009.
  1. Oct 17, 2009 at 7:36 PM
    testedone
    testedone [OP] Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    I am reading over on wheelersoffroad about there leaf packs and they indicate that the TSB springs have 4 springs
    So I see on my trunk (2010 DC TRD) I have 3 springs plus an overload, so is it an assumption that 4 springs means the TSB has been done??
    Just trying to figure this out before I order my rear AAL..
    Thanks
  2. Oct 17, 2009 at 7:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You would have 4 leaf springs instead of 3
  3. Oct 17, 2009 at 7:40 PM
    testedone
    Rick
    U.S.A.
    Chris are you saying 4 total or 4 leafs plus an overload??
    Thanks
  4. Oct 17, 2009 at 7:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    4 total. 3 + 1 overload. :)
  5. Oct 17, 2009 at 7:41 PM
    testedone
    Rick
    U.S.A.
    Cool, so I have the TSB installed on my 2010... Thanks Chris
  6. Oct 17, 2009 at 7:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  7. Oct 17, 2009 at 7:45 PM
    testedone
    Rick
    U.S.A.
    Just double checked....
    I have only three...so I need to go with the 2" AAL versu the 1.5"
  8. Oct 17, 2009 at 7:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I figured as much.
  9. Oct 17, 2009 at 7:50 PM
    testedone
    Rick
    U.S.A.
    Maybe one day they will catch up with the 2009 & the 2010...or here is a bright idea...change it before they leave the factory...odd that my truck has a sticker that only states less then 4 pounds of cargo capacity when my 2009 stated 300+
    I would have thought that capacity difference would be the same as my 2009 which did not have the TSB
  10. Oct 17, 2009 at 7:57 PM
    testedone
    Rick
    U.S.A.
    Hey Chris, if I go with the 1.5 AAL (Knowing I do not have the TSB) and use the 5100's up front with my stock springs, will I be able to level it out? what setting do you think II would need the Bilsteins on?
  11. Oct 17, 2009 at 7:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, That will be pretty close to level. Set the 5100's at 2.5"
  12. Oct 17, 2009 at 8:09 PM
    testedone
    Rick
    U.S.A.
    Wow, that high huh? I was thinking they would be set at 1.75 or so...
    EDIT:
    Trying to keep from buying the whole Ultimate kit when I don't really need it, just want to lift 1.5 - 2 inches..
  13. Oct 17, 2009 at 8:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can try it on the 1.75" setting first. You should be able to keep your alignment in check at that setting better than the 2.5"
  14. Oct 18, 2009 at 11:36 AM
    testedone
    Rick
    U.S.A.
    I am thinking for better adjustabilty I might just have to spring for the Toytec coil overs, but I guess I could try it the cheaper route of just getting the AAL (1.5) for the rear and the Bilsteins for the front.. to many decisions
    Chris, if I am going maximum of 2 inches do you think i would need to shim the rear axle?? for $30.00 bucks it's not a expensive option, just want to be sure I need it
  15. Oct 18, 2009 at 3:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Nope. You will be fine
  16. Oct 18, 2009 at 4:23 PM
    testedone
    Rick
    U.S.A.
    Thanks again!
