how do you take the ac vents out?????
Discussion in 'Technical Chat' started by Frankoo1234, Jan 31, 2011.
  1. Jan 31, 2011 at 7:34 PM
    Frankoo1234
    Frankoo1234 [OP] Well-Known Member
    OC
    Double Cab 05 Taco PreRunner
    Running boards, Tint
    I want to take out the AC vents out and paint them to match the black dash... the ones next to the stereo.. ive seen how to take off the stereo and stuff is there just like a screw inside or does it just pop out??
  2. Feb 9, 2011 at 10:52 PM
    DevL
    DevL Well-Known Member
    You remove stereo and AC controls, remove stereo, unclip the left side from dash, unbolt and pull... its the whole chasis that has vents and holds the whole center dash... you cant pull just the vents.
  3. Feb 10, 2011 at 12:45 PM
    Frankoo1234
    OC
    thanks thats what i had thought ill have to try it
  4. Jun 1, 2011 at 7:50 AM
    abbywig
    abbywig Member
    Bill
    Beaverton,Oregon
    1997 Toyota Tacoma
    It's really quite easy ( once ya know how). Put a flat screw driver on the side of the vent and press out while pulling the vent with a needle nose.
    Where did you read on pulling the dash frame off???
    Hope this helps
  5. Jun 1, 2011 at 7:55 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    note the year of the vehicle in question.....
  6. Jul 28, 2012 at 10:03 AM
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    anyone know what bolt on the left side hes referring to? i got the general idea of how to take it off but something is not lettin go on the left side :( pics?
  7. Aug 7, 2012 at 8:06 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    No bolt on the left. The left edge is being blocked/held down by the instrument cluster surround panel. I had to pull that from around the guages before I could get the left side of the center dash panel out.
    There are two plastic push clips above the guage window. Use something small to push the center of them in until they release (not far, you'll know it). After that, grab the circular edges of the guages and wiggle it and those clips should drop out. Also, pulling the guage edges helps make it easier to get something behind the panel for releasing clips (I use a putty knife).
    After that, the instrument panel is all push clips which you have to kind of work out one at a time like the other panels. The three clips on the left side of the center vent panel are also hidden behind the instrument panel which you'll see once it's out of the way.
  8. Apr 8, 2018 at 6:19 PM
    1997tacomav6
    1997tacomav6 V6 5sp,RegCab,TRD Supercharger,Haltech,meth, 750k
    Denver
    97 reg cab, v6 5sp 300hp supercharged, Methonal Injection, 750,001 plus miles, Original Owner
    V6 5sp,RegCab,TRD Supercharger, 1.9” pulley, methanol injected Haltech ECU, AC TRD supercharger,(MUST DO) TRD supercharger ported, every 125,000- 150,000 needs rebuild Projector headlights HID 5 speed manual Amsoil for all drive train Smaller 2” pulley, (MUST DO) 2004 DESNO fuel injectors, zero ping ping, 2004 side door mirrors Dick Cepek Rims, Michelin tires LTX, ( that last 100,000 miles) Now running Dynopro ATM mud and snow tires KN cold air intake Cat back exhaust with ss exhaust tip, Raised exhaust tail pipe to 2" below body line Optima*dry cell battery,red top Alpine sirius radio, 200 watt amp, focal is165 split door pod speakers Focal door speakers Subwoffer behind seat Viper alarm, Electric Locks Dark tinted windows, bucket seats corbeau lg1 Tacoma Rubber floor mats TRD fender extenders, Bilstien shocks, King shocks nerf bars, add a leaf for rear springs trailer iv hitch, electric brake control, Drilled slotted brakes, High carbon steel (MUST DO) EBS green stuff 7000 series pads(MUST DO) TRD engine oil cap TRD stick shift, Marlin crawl shift kit. Rear sliding window 2002 4Runner functional hood scoop cut into Tacoma hood, 4Runner dual overhead map light Gentex Auto dim + Compass + Temp, garage,rearview mirror Snow Methonal kit stage 2 Custom 3 core aluminum radiator Linex bed liner Haltech stand alone ECU, Intake supercharger gauge. Stainless steel brake lines, Custom leather wrapped steering wheel,
    Can you pop out the side vents??
  9. Oct 13, 2018 at 3:27 PM
    panamaborn
    panamaborn Member
    1998 Toyota Tacoma
    none
    I have a 98 Tacoma and I am trying to replace the right side a/c vent, I have the glove box removed and I removed two holding the right side a/c vent can't seem to remove it. Is there something I am missing? Trying to replace my antenna, any help would be appreciated thanks in advance. 98 Tacoma Prerunner 2.7L 2WD Automatic.
