how do you take the door panel off my 1st gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by .Trdtaco315., May 5, 2010.
  1. May 5, 2010 at 12:20 PM
    .Trdtaco315.
    .Trdtaco315. [OP] Well-Known Member
    Will
    Santa ana
    03 Trd SR5 Prerunner
    hey can someone point me in the right direction?
  2. May 5, 2010 at 12:23 PM
    Loudpedal
    Loudpedal Mind = Blown
    Blair
    Not really New, not really Mexico
    02 SR5-Hole 4x4
    Andres Devil Horns, Goodyear Duratracs, Accidental Tailgate Delete (x2), Billy 5100s, OME 881 coils, Wheeler's 5-leafs, BAMF Sliders with kickouts, Box Rocket Fab Bedrack.
    There are two plugs under the armrest, pop those and remove fasteners. There is also a screw in the interior latch that must be removed. I think that is all, then it's just a matter of pulling off the panel carefully to not break any clips.
    Disclaimer: I am writing this from memory so I hope it's correct.
  3. May 5, 2010 at 12:31 PM
    .Trdtaco315.
    Will
    Santa ana
    hey thanks for the help man!
  4. May 5, 2010 at 12:46 PM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    correct. also it makes it easier if you roll your window down. remove screws the latch sould slide back. pop the clips when they are all free it kind of a sliding up motion and your off
  5. May 5, 2010 at 3:18 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    in the corner of the window is a black triangle that has to come off first im pretty sure
  6. May 5, 2010 at 5:36 PM
    81CountryGirl
    81CountryGirl Member
    Kate
    New Brunswick, Canada
    '01 Tacoma 3.4L 5Gear 4x4
    2.5" lift
    And unscrew the lock button at the top of the door, it just spins off.
  7. May 5, 2010 at 7:03 PM
    .Trdtaco315.
    Will
    Santa ana
    my project went smooth, chek it out in the "detail" section. should be the first one
