How does a 2nd generation 2WD with the access cab handle in the winter/snow?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Markcal, Sep 3, 2021.
  1. Sep 3, 2021 at 6:53 PM
    Markcal
    Markcal [OP] Well-Known Member
    I have owned my 2006 access cab for almost 15 years and this will be the first winter in Massachusetts that I won't have 4WD. My 4wd failed to engage a few weeks ago and ever since has been inoperable. Unless it's an easy fix (which I dought) or I can afford it in the future, I will most likely drive it as a 2wd.
    My question is, how will it handle this winter in the snow, and should I add weight in the back, I have a Leer cap on the back which does add some weight?
  2. Sep 3, 2021 at 7:33 PM
    2pei
    2pei Well-Known Member
    Scott
    Oregon High Desert
    03 Tacoma
    mild lift, suspension & assorted badassery
    like ass. add lots of weight and get some proper winter tires
    vtown, devkurf, JustJon and 1 other person like this.
  3. Sep 3, 2021 at 7:36 PM
    Bishop84
    Bishop84 Well-Known Member
    Weight, reduce tire pressures, enjoy slow driving.
    It's likely just a front A.D.D. module, you should fix it prior to winter, they aren't too crazy expensive.
  4. Sep 3, 2021 at 8:20 PM
    Markcal
    Thanks, I can't remember a winter without 4wd and not looking forward to it, so I will be saving up for it then.
    davidstacoma likes this.
  5. Sep 3, 2021 at 8:25 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Speaking as one who's driven a 2010 single cab 2WD since October 2012...
    You'll be fine.
    I don't even put weight in the bed, so your cap will add a little more "advantage" there.
    Particularly, I have a 26 mile round trip commute for work daily (before Covid) and never an issue. Remember this includes a brutal winter a few years ago.
    I don't run snow tires either.
    For 5 years prior to this I had a 2006 Chevy Colorado 4WD which was junk in snow even with 4WD, and no I didn't drive like a moron.
  6. Sep 3, 2021 at 8:29 PM
    ABA180
    East Bridgewater MA
  7. Sep 3, 2021 at 8:32 PM
    Markcal
    That gives me a little more hope if I have to go with 2wd this winter. I'm so used to not fishtailing with 4wd, Bishop84's advice of slowing down till I get used to it may help too.
  8. Sep 3, 2021 at 8:34 PM
    ABA180
    East Bridgewater MA
    My daily commute is 30-45MPH depending upon side street or main road, but I honestly have never had issues. Definitely drive a little slower but that's good advice on snow regardless.
  9. Sep 3, 2021 at 8:37 PM
    Markcal
  10. Sep 3, 2021 at 8:39 PM
    ABA180
    East Bridgewater MA
    Hmmm that could be. I do remember hearing that when I had the Chevy trying to remember to do that, though that was bought new and only kept for 5 years so not really sure how mine would have held up. Being it was a GM, I suspect it wouldn't have.
  11. Sep 3, 2021 at 8:45 PM
    Jose_Dirte
    Jose_Dirte Life's a garden, dig it
    Joey
    Green Acres, CO
    A Tacoma, just like everybody else...
    I drove a Nissan Titan rwd without snow tires for years as well as a firebird here in Denver without snow tires.
    It sucked but I got around for the most part fine (I avoided the mountains as much as possible).
    Get some blizzaks, drive smart and you'll be fine.
    AWD or 4WD makes life much less stressful for sure though.
  12. Sep 4, 2021 at 2:48 AM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    I only use 4wd to get out of my icy driveway. After that I only ever need it if I want to go faster than I really should given the conditions.
  13. Sep 4, 2021 at 3:42 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Throw a couple 50# bags of sand in the bed over the axle and you should be fine. If you get stuck you can use the sand to make sand castles.
    What do you got for tires? I have some 265/70/17 wildpeak at3 on 17" sport wheels talking up way too much space. But the mud guards you just did will have to come off.
  14. Sep 4, 2021 at 3:57 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I wouldn't sweat it too much. My last truck was exactly that. It had 4x4 but I rarely used it unless I absolutely had to since I learned to drive in the snow with rear wheel drive. Add weight, to slow, and don't "startle" the truck with the gas pedal. No need to reduce tire pressures or anything like that. The manufacturer ratings are what they are for a reason. You aren't rock crawling.
  15. Sep 4, 2021 at 4:51 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    With decent tires, on fairly level ground you shouldn't be handicapped much at all. In hilly areas you'll wish the 4X4 was working.
    I'd check into getting 4X4 working. Having 4X4 stop working isn't uncommon and is usually a fairly simple thing to fix. Often simply engaging 4X4 on a dirt or gravel road and putting a few miles on it will get it back.
    The most common reason 4X4 stops working is due to lack of use. Internal parts don't get lubricated and corrosion builds up in electrical connections if not used regularly. Often just disassembly and cleaning is all that is needed. Occasionally an actuator needs to be replaced, but that isn't a major repair.
    Once you get it fixed make a point to get on a dirt or gravel road at least once every month or 2 and drive a bit in 4X4. The owners manual suggests 10 miles/month. I don't always get 10miles, often only 1 or 2, and I sometimes skip a month. Other months may see 200-300 miles in 4X4. But the key is to use it, or lose it.
  16. Sep 4, 2021 at 5:18 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    That sounds like a good time in Denver…lmao.
    Like you, when living in CA we would take my Camaro to Heavenly to go Skiing/Snowboarding. Cable chains and I was good to go.
  17. Sep 4, 2021 at 8:45 AM
    devkurf
    devkurf Member at Large
    midwest
  18. Sep 4, 2021 at 10:33 PM
    Markcal
    Thanks for that advice and sorry for not replying sooner, as I'm just reading your comment. Tires are high on my list of things needing to be replaced, as they are over 8 years old. They were bought at BJ's and are BJ's Michelin x-radial lt2, so I would be better off spending money on a new set of tires rather than using the money to fix the 4wd.
  19. Sep 5, 2021 at 3:07 AM
    AllTacosFloat
    Boston ish
    Best idea would be to take my set of wheels, free fifty, and spend the money on fixing 4wd. If mine won't fit, yes tires over fixing 4wd. Are you 5 lug? I have a terrible memory.
  20. Sep 5, 2021 at 8:20 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Stopping isn't that much different, just do more planning, anticipation when starting from stoplights and stop signs. I drove rear-wheel-drive only for years with very few issues. Was only stuck once and that was at the end of the driveway. Four-wheel drive only gives you confidence or a secure feel at starts in slippery conditions.
    RedWings44 likes this.
