How does rear view mirror come off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kohan25, Apr 22, 2008.
  1. Apr 22, 2008 at 10:16 AM
    kohan25
    kohan25 [OP] Active Member
    06 TACOMA SR5 4X4 TRD Speedway Blue
    lebra tonneau cover, avs bugshield, firefighter goober lights, custom stereo/scanner install
    Maybe an easy question but I dont want to break it. How do you remove the rear view mirror from the windshield?
  2. Apr 22, 2008 at 10:23 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16 Firestone Destination AT2's
    First removed the little plastic cover at the base of the mirror, ( I used a really small flat blade screw driver) then there is a tab on the bottom inside of the mirror, press that then lift the mirror up. I just took my off when I tinted my windshield. PM me if you have any questions. :D
  3. Apr 22, 2008 at 10:26 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    THis is all out of memory.. and it ain't all that good of one. ;)
    (on a 2007)
    Look at the post that holds it to the window. Look at the backside (nearest window). There should be a little plastic cover piece that can be popped off.
    After you pop this off, the mirror should slide off.
    The windshield has a triangular metal piece in the window itself (so to speak). The rear view mirror has a similar sized and shape triangular piece that slides on the metal.
    Good Luck!
  4. Apr 22, 2008 at 12:26 PM
    kohan25
    Thanks very much. Thats what I needed.
  5. Apr 22, 2008 at 3:02 PM
    sawdust
    sawdust Unapologetic Texan
    Frisco, TX
    07 TRD Offroad Radiant Red V6 Auto DC
    Homelink mirror, tailgate lock, 2ndary air filter removal, Access LE tonneau, Bugflector II, hitch-based bed extender, vent visors, suspension TSB, stall mat
    Is that piece epoxied to the glass? I've got a homelink mirror, but I assume it's mounted the same way. I'd love to raise the mounting point higher, but I don't want to mess with epoxy.
  6. May 6, 2008 at 5:37 PM
    subcwo5nuke
    subcwo5nuke Member
    Newport RI
    Pre-Runner long bed
    I need to move mine up also. I keep finding collisions off the port bow when I have it folded down. My eye height is aty mirror height and it's either foled up or down and dangerous. Did you figure out if it could be moved? Thanks.
  7. May 6, 2008 at 5:38 PM
    subcwo5nuke
    subcwo5nuke Member
    Newport RI
    Pre-Runner long bed
    Sorry, Stbd bow (the other port)
  8. May 6, 2008 at 5:38 PM
    subcwo5nuke
    subcwo5nuke Member
    Newport RI
    Pre-Runner long bed
    Man, do I miss automatic spell-checker.
  9. Dec 13, 2010 at 12:03 PM
    krudawg
    krudawg Well-Known Member
    Ted
    Goodyear, AZ
    06 PreRunner V6 SR5
    Ok, now it's coming to me: "I Left Port" so STBD must be right. 40 years ago, the USMC taught me "squid" talk and it still resides in the far reaches of my brain housing group :)
