How does traction control button work?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Backroadbomber, Aug 5, 2012.
  1. Aug 5, 2012 at 5:46 PM
    Backroadbomber
    Backroadbomber [OP] Active Member
    Dan
    Hamburg, New York
    2011 4cyl 4wd 5sp Base
    Ok I know how the traction control works, and it sucks. I'm looking for a way to disable it without pulling abs fuses and without having to hold in the stupid button every time I start it. I'd like to keep my abs functional just in case I get into an accident I can't get sued for millions of dollars ( even though you stop faster without abs). Basically I'd just like an understanding of how the button is wired in and if it would hurt anything if I wired it to where it would be pressed in all the time so traction control turns off automatically. The other day I pressed and held the button for about 20 minutes while driving and my truck DIDN'T start on fire lol so I'm assuming it wouldn't hurt anything but I don't want to burn up any relays or anything. A wiring diagram would be sweet.
  2. Aug 5, 2012 at 5:51 PM
    jandrews
    '09 FourDubDee TRD OR
    Why do you want it off? You driving crazy enough to trigger it that often?
  3. Aug 5, 2012 at 5:54 PM
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
  4. Aug 5, 2012 at 5:55 PM
    03is300ztk
    Zach
    07 Tacoma 4X4
    Why cant we just offer good suggestions other then saying things like this?
  5. Aug 5, 2012 at 5:59 PM
    03is300ztk
    Zach
    07 Tacoma 4X4
    oh I know, agreed, however I can still try..
  6. Aug 5, 2012 at 6:01 PM
    jandrews
    1 - I'm an asshole.
    2 - VSC in these trucks really doesn't interfere with daily driving at all unless something starts to get abnormal. So, frankly, I'm curious as to what exactly the OP feels "sucks" about traction control. That's all.
  7. Aug 5, 2012 at 6:06 PM
    03is300ztk
    Zach
    07 Tacoma 4X4
    1 sounds good and fair, 2 fair enough, however maybe he is like some and likes at a moments notice to be able to break them loose, without having to hit a switch.
    I have never seen VSC or anything similar be better then my own throttle control in any situation personally, its more for those that get in vehicle and dont understand how to feather it when need be.
  8. Aug 5, 2012 at 6:12 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ehh.... Yes and no.
    In the early days of ABS, it made a huge difference in stopping distances for typical drivers, but did not make much difference for professional drivers.
    Now, either ABS systems have improved, or "professional" drivers have lost some of the edge and have begun to rely more on some of the automated systems, because modern systems will make a difference for any driver (and yes, a smaller difference for the professional).
    But regardless of the level of the technology, the automated systems do provide a significant advantage to the average driver, while providing no disadvantage to the professional driver, so long as he is aware of how the system is going to respond to a given situation.
    The only reason to disable these systems is when the vehicle is taken outside of the normal parameters of on-road driving....
    4 wheeling/crawling, drifting, etc.... automated systems may not be desired in those conditions.
    But I'm going with #1 :D
  9. Aug 5, 2012 at 6:16 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    can't entirely agree
  10. Aug 5, 2012 at 6:18 PM
    jandrews
    More than I felt like typing, but agreed. And thanks?
    It's true.
    Elucidate. I'm listening and willing to learn.
    Élucider. Je suis à l'écoute et prêt à apprendre.
  11. Aug 5, 2012 at 6:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I pushed the "trac" button in my Accord, and it was unreal.
    The car lowered about 2", the engine tone got deeper, AC/DC began playing "Thunderstruck". Then....as the light turned green......a laser emerged from the hood.
  12. Aug 5, 2012 at 6:18 PM
    NtacomaR
    NtacomaR Well-Known Member
    nick
    sparks
    2012 Tacoma Baja
    suspension, wheels, rims, trd exhuast, CAI
    what year do you have first off? and if you hold the trac control button down for 5 second while it is in park it will completely disable it. i.e for doing donuts, mobbin in the snow etc....once you turn off and back on the truck it will go back to being ON. try it, hope this helps.
  13. Aug 5, 2012 at 6:20 PM
    jandrews
    Fixed that for you.
  14. Aug 5, 2012 at 6:22 PM
    NtacomaR
    nick
    sparks
    2012 Tacoma Baja
    negative, i had mine completely off. and was doing 65+ it still stayed off.
  15. Aug 5, 2012 at 6:23 PM
    jandrews
    Because you didn't throw your ass around enough.
    Trust me, it's lurking, and if you're above 30 and get sideways, it WILL kick in.
  16. Aug 5, 2012 at 6:25 PM
    NtacomaR
    nick
    sparks
    2012 Tacoma Baja
    i promise you that it can be disabled, on my 2012 at least. i live on a ranch and was smashing doing donuts (in my yard) and it never went off...and then i read what you said with going over 30. so i went on a road wear the speed limit was 55. i was going 65 and it stayed off.
  17. Aug 5, 2012 at 6:26 PM
    NtacomaR
    nick
    sparks
    2012 Tacoma Baja
    where*
  18. Aug 5, 2012 at 6:26 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Freaking lazers on the hood???????
  19. Aug 5, 2012 at 6:28 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    you are wrong. it will kick in when you go over 30 even if you press and hold the trac button. and yes you can do donuts and shit, but its a 1 tire fire. i go to the track all the time and only burn the back passenger wheel
  20. Aug 5, 2012 at 6:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It may have been glare from the sun.....but it looked like I might have been able to envision a laser there.....
