How f'ed am I? Insert so many cuss words right here.
Discussion in '1st Gen. Tacomas (1995-2004)' started by yourrealdad, Jul 1, 2020.
  1. Jul 1, 2020 at 12:40 PM
    yourrealdad
    yourrealdad [OP] Well-Known Member
    Colorado
    2007 Red Tacoma DCLB TRD Sport 4x4
    I am getting sick of this crap.
    Power steering flush. Took 4 hours instead of 30 mins.
    Got done, everything looks ok. Started up the engine. Doesn't sound good. Popped the hood.
    A t-shirt that I had used to cover the belts had fallen down so I missed it and is now stuck under the belts.
    Can I loosen these easily or is it a remove the radiator job at which point I might just light the damn truck on fire?
  2. Jul 1, 2020 at 12:43 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Easy fix. Loosen tensioner and remove shirt.
  3. Jul 1, 2020 at 12:44 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    You don't need to remove the radiator to remove the belts. Just loosen them and remove.
    wilcam47, jammer and whoareyou133 like this.
  4. Jul 1, 2020 at 12:48 PM
    yourrealdad
    Colorado
    Thanks for the quick replies. Is there a torque value I need to get it back to?
  5. Jul 1, 2020 at 1:05 PM
    yourrealdad
    Colorado
    Alright I give. Can someone walk me through how to do this? I can't find anything online and I am turning a long bolt that seems to be doing nothing on the bottom most pulley
    Black DOG Lila likes this.
  6. Jul 1, 2020 at 1:15 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    There is a nut on the other end you have to lefty loosey first with a box end while holding the bolt head.
    It can be done.
    Splash pan gotta be off though if you have one.
    http://www.tacomaworld.com/forum/1s...nge-your-belts-p-s-c-alternator-2-4-2-7l.html
  7. Jul 1, 2020 at 1:17 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Hehehe, I thought that shit only happened to me!!!
    QMEDJoe, suaveflooder, jammer and 4 others like this.
  8. Jul 1, 2020 at 1:18 PM
    RubenZ
    RubenZ Well-Known Member
    South Texas
    2020 Cement Tacoma TRD Off-Road DCSB
    wouldn't it me easier to cut out the shirt and crank that bad boy and wait till shirt goes around pully?
    wilcam47, jammer, GQ7227 and 2 others like this.
  9. Jul 1, 2020 at 1:32 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    save the shirt so you can wear it later
  10. Jul 1, 2020 at 1:33 PM
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    Just keep running it til there’s no more shirt.
    Sebz13, rmorse, Lawfarin and 6 others like this.
  11. Jul 1, 2020 at 1:35 PM
    cornbread_wy
    cornbread_wy Well-Known Member
    W
    San Rafael, CA
    98 xtracab 3.4l Sr5 4x4 - copper mica
    5100 w/ 881
    Cmon guys - Shirt may be OEM.
  12. Jul 1, 2020 at 1:36 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Just put the shirt on. Once you get it on, you'll have it out of the belts.
    JasonLee, whatstcp, QMEDJoe and 7 others like this.
  13. Jul 1, 2020 at 1:38 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Toyota says this is normal?
    osterhagen, rmorse, wilcam47 and 3 others like this.
  14. Jul 1, 2020 at 1:42 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    it might be rusty like his bed hooks
  15. Jul 1, 2020 at 1:49 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    I would just turn the crankshaft pulley counterclockwise. Don't bother loosening all the belts.
    otis24 likes this.
  16. Jul 1, 2020 at 2:05 PM
    TacomanTurd
    TacomanTurd Well-Known Member
    David
    2004 Tacoma
    Stock for now
    Dude, this is not even registered on the piss off scale. 19mm socket and slowly crank it counter clockwise and you’ll be done in no time.
    come back and cry when you find hole in your frame that had been bondo’d over. Or your rear shock decided not to like where it mounted any more
    whatstcp, Rastopher, jammer and 3 others like this.
  17. Jul 1, 2020 at 2:16 PM
    yourrealdad
    Colorado
    Bed hooks were ironically Rustoleum bed lined yesterday.
    I cried when my 1998 4runner that I loved and had just personally installed a OME lift and got new tires was driven into a tree in the middle of BFE and I mean BFE Idaho by the shuttle company. I then used the money they gave me to buy a 1999 4runner that turned out to have a bent frame that couldn't be fixed. Was out of money so had to take a loan out to get a 2006 4runner. Sold that so the wifey and dog could have a camper van that I had to build out. Finally saved up enough to get a DD back and here we are.
    Rear shock on this truck also unthreaded itself from the lower mount on the way home from me purchasing it, so yeah I got to replace two rear shocks.
    So yeah over it and crying.
    Mostly crying because I am supposed to be writing papers for summer classes.
  18. Jul 1, 2020 at 2:18 PM
    yourrealdad
    Colorado
    The belts wouldn't loosen enough to pull the shirt out.
    Just cut the new belts and now get to pay $70 for more new belts.
    More tears, more money gone.
    Also found that the bolt that is supposed to hold the alternator in place on the slide is missing. Anyone happen to know the size and pitch?
    cruiserguy and whoareyou133 like this.
  19. Jul 1, 2020 at 2:19 PM
    whoareyou133
    whoareyou133 Well-Known Member
    Claremont Los Angeles
    02 Prerunner TRD
    No pre runner trim, no mud flaps,no step ups,I do have the Deck plate though. Kings @ 0 and 5100's in rear. stock leafs. Total chaos UCA.
    It’s irrelevant but one time one of the lube boys at work forgot to take the oil nosel out of the block and it sucked the whole rope and pump into the block toyota had to either replace the block or give them a new car haha customer prolly was like what the heck how does that happen
  20. Jul 1, 2020 at 2:30 PM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
    this is why I try’n stay out of dealers/shops! Recently picked up a new ride, (dealer sticker oil change).....GD...oil filter and drain bolt was
    cranked on to the point of almost no return.
    What is it with some of them? Almost called the dealer just to yell
    But then we have this here situation above- things happen,
    at least you saved some money and are learning! But oh no ! on the shirt, just try cutting it away and yankin on it with some vice grips
    whoareyou133[QUOTED] likes this.
