How hard is it to install a lift kit yourself?
Discussion in 'Suspension' started by NumNutz, Jul 25, 2008.
  1. Dec 22, 2008 at 8:38 AM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    Me and a buddy just took off my Toytec lift and put some Icons and new UCAs on. It's not hard. As long as you have the directions, basic mechanic skills, decent tools, a coil compresser, and enough beer. you will be fine. You can go to Kragen/Shuck's and "rent" a coil compresser. You have to pay for it, but when you return it they put the deposit back in your account. It's like 6 bucks a day. You should only need it for a couple of hours though. Good luck.:thumbsup:
  2. Dec 22, 2008 at 8:59 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    If you've never used a coil compressor before I would suggest going to a shop and have them put on the spacer for you. The compressor is a dangerous tool, not worth losing a limb or digit over. A compressed spring yields a whole lot of energy so be careful.
  3. Dec 22, 2008 at 9:00 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    +1000000000! There's a guy here on this forum that had to go to the emergency room for stitches after his failed attempt... I forget who it was though.
  4. Dec 22, 2008 at 9:47 AM
    br217398
    br217398 Crazy Person.....
    Orlando Florida
    06 Tundra Crew Cab 4WD
    Hornblasters horns,Strobe lights,Police Undercover Vehicle, Volent Ram air system, pro comp POS AAL, biltein all around, step bars.
    I asked around town where im at, and most shops are charging 20-40. THere is a penzoil express lube shop and they were the 20, my dealership told me $75(shocking..... huh)per side
  5. Dec 22, 2008 at 11:41 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I wouldn't trust those guys at the quick lube place nor would I take it to the dealer for that price, maybe find a good medium somewhere else?
  6. Dec 22, 2008 at 1:07 PM
    cbcs1987
    cbcs1987 Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
    I've used a spring compressor before working on other peoples vehicles. I'm just wandering what would be quicker and cheaper. I'm extremely busy and I have to install this lift quickly as possible without rushin through and half-assin it. I've got a fair amount of mechanical skills and have done suspension work before. How long would it take on average to do just the front if all goes smooth?
  7. Dec 22, 2008 at 3:16 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It's very easy...here's a couple writeups.
    It's much easier to have a buddy with you.
    If you're installing a SPACER lift that goes inside the coil assembly, I'd highly recommend NOT using a coil compressor. Take the entire assembly to the nearest shop with a wall mounted compressor and pay them to compress the coils. Much safer....
    http://www.lieblweb.com/tacoma/Mechanical/CornbredLiftInstall/CornbredLift.htm
    http://www.lieblweb.com/tacoma/Mechanical/DayStarLift/Daystar.htm
    And don't forget....if you disassemble the front coil assembly, I'm pretty sure this is what you need to put it back together properly. This came directly out of a 96 FSM.
    http://www.lieblweb.com/tacoma/Mechanical/96TacomaDiagrams/images/FrontSuspLineUp.jpg
