How heavy is a Gen 1
Discussion in '1st Gen. Tacomas (1995-2004)' started by FourWheelsofFURY, Mar 20, 2010.
  1. Mar 20, 2010 at 9:15 AM
    FourWheelsofFURY
    FourWheelsofFURY [OP] You want a toe? I can get you a toe...
    Charlie
    Texas
    07 4X4 Long bed
    Bull Bar, skid plate, nerf bars, LightForce 170s, Raider Viewfinder, Ludicrous speed-capable.
    I'm getting ready to PCS (move from one military installation to another) so the topic of weight tickets surfaces once again. I was just curious what the empty weight of a Gen 1 Taco is. I think my Gen 2 weighs about 4200lbs empty (I can't remember for sure because I weighed it in '07.
  2. Mar 20, 2010 at 9:33 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    You have to specify the year, model, engine, and transmission.
  3. Mar 20, 2010 at 9:35 AM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    depends on how fat the chick riding with you is...
  4. Mar 20, 2010 at 9:38 AM
    PacNWgen1
    PacNWgen1 NewHere
    Adam
    Oregon
    96' Tacoma Reg Cab 2.7l 4x4 5-speed 150,000+
    DynoMax ST, Deck Plate, Full Syn, Soon Header and Slotted Rotors
    My 96 Reg cab 2.7 5 speed w/ a canopy is 3750 with me and a full tank. Just went to the dump and they do it by weight here.
  5. Mar 20, 2010 at 9:41 AM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    If your instalation has a recycling center you can go down there and ask them if you can jump on the scale.
    I think the recycling center falls under the Directorate of Logistics?
    Ft Wainwright DOL: 361-7641
    Can't find listings for Ft Richardson (not sure where you are)
  6. Mar 20, 2010 at 12:15 PM
    FourWheelsofFURY
    Charlie
    Texas
    07 4X4 Long bed
    I know where to go to weigh. I was just curious to see how much heavier the '05s and later were compared to the older, yet still very capable and relevant models. To quote the first reply, I don't know anything about Gen 1. Please describe your truck when you reply with a weight, thanks!
  7. Mar 20, 2010 at 1:20 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    Exclusive of optional equipment, 1995.5 - 2004 Tacomas' factory spec curb weights range from:
    2560 lbs. (4-cylinder 5-lug Regular Cab; 1995.5 - 1997 era)
    ... to:
    3705 lbs. (6-cylinder 6-lug Double Cab; 2004)
  8. Mar 20, 2010 at 5:25 PM
    biggdog747
    biggdog747 Well-Known Member
    MI
    taco
    look on the door jam sticker it will tell you
  9. Mar 20, 2010 at 7:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    That gives Gross Weight. Not Empty weight.
  10. Mar 20, 2010 at 8:28 PM
    PharmerJon
    PharmerJon Member
    Jon
    Nebraska
    '03 Xtra Cab SR5 4x4, 2.7L 4cyl
    Deck-plate, black undercoating of pinch weld, clear corners and new tails, weathertech liners, billet grill w/ "TOYOTA" FJ emblem, OME all around, AAL, ashtray cb mount (Uniden), fender mount Wilson firestick antenna, Powerslot rotors, Hawk pads, Moto Metal 951 black, 265/75/R16 Duratrac's, Sockmonkey "SR5 w/ Mountains" bedside decal
    With my 180 lbs and my daughter's 21 lbs, my 2003 Xtra cab weighed right at 2 tons according to the feedlot scale. :)
