How involved is installing a trans oil cooler.
Discussion in '4 Cylinder' started by 97widerider, Dec 30, 2012.
  1. Dec 30, 2012 at 12:50 PM
    97widerider
    97widerider [OP] Well-Known Member
    Indiana
    02 Tacoma SR5 Prerunner
    I have a 02 Tacoma PreRunner TRD, 2.7l 4cyl and plan on pulling a camper that weighs about 1700lbs with cargo. I want to have a Hayden trans cooler installed and was hoping somebody could tell me how many hours will a shop typically charge to install one. I have a friend who charges 1/2 of a shops hourly rate and he is a certified mechanic. I plan on removing the grill and relocating the horn myself so that may save a little time. thx
  2. Mar 16, 2013 at 3:09 AM
    motoman515
    motoman515 Member
    tim
    Menifee, Calif.
    00 PreRunner XCab
    K&N Filter And Tube
    Get the Toyota TRD Transmission Cooler. $175 on Ebay. Bolts right on. You can do it yourself. The mounting holes are on the radiator support. No mounting it to the side of the radiator.
  3. Mar 16, 2013 at 6:39 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    it is not a big deal
    you need to be able to capture and store atf fluid
    and find a place to bolt the cooler, attach rubber hoses to it.
    and then be able to top off the transmission to the correct level
    any operation you do with an open hose or fill to the tranny should
    be clean-room conditions, so all new lint-free rags is mandatory
  4. Mar 27, 2013 at 12:50 AM
    guitar2323
    guitar2323 Well-Known Member
    clint
    saratoga springs new york
    2013 access cab TX Pro
    How much fluid do you think comes out when hooking up the cooler lines?
  5. Mar 27, 2013 at 6:24 AM
    gearcruncher
    Canadain bumper technician
    When installing a transmission cooler , you can loose up two cups of transmission fluid .
    As mentioned above ,using the pull straps that come with the cooler to install the transmission cooler really is not the best idea . Its better to bolt the cooler in rather than using the pull straps .Make sure you get 4 bolts with the kit .
    No more than 2 hours labor .
    Never used Hayden but I would recomend Tru-cool anyday .
    http://www.transmissioncoolers.us/category/trucool-coolers-hd.html
