How is the ride with a 3" lift vs. stock
Discussion in 'Suspension' started by EGtaco, Feb 9, 2009.
  1. Feb 9, 2009 at 10:51 AM
    EGtaco
    EGtaco [OP] Well-Known Member
    2009 Tacoma
    I have not been in a TACO with a lift and will be getting some billies 5100s soon and want to replace my stock tires with 275X70X17. I will probably just adjust to 1.5 and maybe add some spacers so I dont have to do any triming (unless I have to). How is the ride with a minor lift compared to stock suspension???? For right now I will probably leave the rear alone but with the budget allows I will replace the stock with new billie in the back too.
  2. Feb 9, 2009 at 10:52 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    With the Billys, it will ride stock(ish) -- it depends on whether or not you add spacers... :thumbsup:
  3. Feb 9, 2009 at 10:54 AM
    EGtaco
    2009 Tacoma
    what do spacers really do? I thought i would need them to fit the larger tires. Do I have too????? Will spacers make the ride worse? I have never lifted a truck or really ever modified a car but I just really like the look of the tacos with larger tires. I dont want to go up to 285s because I drive a lot and MPG is somewhat important.
  4. Feb 9, 2009 at 10:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Spacers aer about the worst thing you can do for ride quality. The Top Plate spacers dont affet the ride, but they lengthen the shock/spring assembly, and that can break things.
  5. Feb 9, 2009 at 10:58 AM
    Delmarva
    Tucson, AZ
    he know his shit too... :D
  6. Feb 9, 2009 at 12:14 PM
    EGtaco
    2009 Tacoma
    So i guess my question is do i need spacers or just the 5100s set at 1.5 to fit the larger tires? The 275s are a bit wider and I really have no idea what I am doing if I have to trim something....
  7. Feb 9, 2009 at 1:17 PM
    Delmarva
    Tucson, AZ
  8. Feb 9, 2009 at 1:18 PM
    Delmarva
    Tucson, AZ
    Just 5100s will be good for you. 265s = No trimming. 275s might work... not exactly sure there... :D
  9. Feb 9, 2009 at 1:20 PM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
  10. Feb 9, 2009 at 3:33 PM
    EGtaco
    2009 Tacoma
    yeah i guess i deserve that but I always like to ask around because you never know who is writting up reviews on the net. I have seen some very bias reviews and think it is probably someone with....maybe a conflict of interest writting them. I have friends that work for certain companies that go onto various websites and write 100% positive reviews to try and increase business. I know there are guys on this site that sell things but there are also others who have tried these products and they are highly recommended.
  11. Feb 9, 2009 at 8:16 PM
    TA06CO
    TA06CO TA06CO
    Arvada, Colorado
    06 TRD O/R, 3in. Pro Comp Lift
    Brush Guard, 3 Stage Tonneau Cover, Side Steps, Silverstar Ultras, 3in. Pro Comp Lift w/ AAL, ES3000 & ES9000 Pro Comp Shocks, 285/75/R16s Yoko GEOs, Differential Drop, Carrier Bearing Drop...
    I have a 3in. Pro Comp lift with all new coils and shocks and the ride has turned amazingly better, I like a stiffer ride and a stiffer ride i got. But at the same time it handles nicely on the turns and obviously over any potholes. I think it is also in the tires you are riding on, I have all terrain highway tires. Stock ride is more car like this turned it into more of a truck ride.
