How long does it take to install a lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Newfiebruh, Jan 23, 2019.
  1. Jan 23, 2019 at 7:45 AM
    Newfiebruh
    Newfiebruh [OP] Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
  2. Jan 23, 2019 at 8:01 AM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    This is a very very broad question with a lot of variables invovled. Depends on your tooling, experience and the condition of your truck. One things for certain I would not want to do it in the snow!
    When I did my lift it took about 6 hours and that included replacing the leaf packs, rear shocks, front coilovers, front upper control arms, removing front sway bar and adjusting the coilovers which was the most tedious part.
    It's great to do yourself though if you can, I would try to borrow a friend's garage or something or wait till there's no snow on the ground.
    Tacotj and outxider like this.
  3. Jan 23, 2019 at 8:07 AM
    Newfiebruh
    Tom
    Its basically an add a leaf and spacers for the front. I feel like it shouldnt be bad. But then again i've never lifted a truck before lol
  4. Jan 23, 2019 at 8:23 AM
    azzwethinkweiz
    Tucson, AZ
    The spacers up front shouldn't take very long at all honestly... the add a leaf would take longer but overall doesn't sound too bad.
  5. Jan 23, 2019 at 8:40 AM
    Newfiebruh
    Tom
    Cool, basically what im hoping for, is a somewhat warm day maybe do just the front or just the rear (and if its not too bad out do all of it in one shot)
  6. Jan 23, 2019 at 8:42 AM
    JaCado
    JaCado Well-Known Member
  7. Jan 23, 2019 at 8:49 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    I'd say this also if you aren't rushing. Sure it can be done much faster by someone who does this all the time or has a vehicle lift. Drive way and jack stands then yeah 4 hours. If you live in an area that rust is a problem, start spraying all your bolts with wd 40 or something similar and continue to do so each night. Long breaker bar maybe needed also. Drop the front skid and the sway bar on each side to make install easier. I'd suggest multiple c clamps for the aal install. Torque your ubolts down to atleast 80lbs and not the 37 lbs stated in the manual. May be easier to take your whole leaf off and apart to install the aal but doing it on the truck isn't bad either. Extra set of hands and 2 jacks help with moving the axle around and lifting it back up to meet the springs. Good luck!
    JaCado[QUOTED] likes this.
  8. Jan 23, 2019 at 8:51 AM
    Newfiebruh
    Tom
    Oh im sure theres gonna be some fun with rust :rofl:. Spraying the bolts in advance is a really good idea, thanks!
    JKU3000 likes this.
  9. Jan 23, 2019 at 8:54 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    On my wifes xterra i couldn't for the life of me break free her rear bottom shock bolts. Took 4 days of spraying and still had the 2 foot long breaker bar bending and feared it was going to snap but they finally broke free.(used to be a Colorado vehicle) Things as small as that one bolt can turn your 4 hour install in to 8 hours or multiple days b/c you can't move forward.
    JaCado and DavesTaco68 like this.
  10. Jan 23, 2019 at 8:58 AM
    Newfiebruh
    Tom
    I've been there, but in a different situation. Went to Mr. lube for an oil change when i first bought the truck (it was winter and i didnt want to risk old ass oil) which was all and well, until i went to do my next oil change. I swear to god they used thors grip to put on that damn filter. Took me 2 days, and 5 different tools to get that sucker off. I broke/ bent 3 of the tools and I ended up having to take the wheel off go through the wheel arch and get a fat filter wrench into there. I honestly thought i was gonna have to get it towed to a shop. Mr. Lube, not even once :bananadead:
  11. Jan 23, 2019 at 8:59 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Colorado Springs
    22 R1T
    Be sure to scrape the driveway down to bare pavement/gravel so the jack and stands have solid footing. The install is not a bad job but I’d give it a full Saturday on account of warm up breaks and getting pissed at rusty bolts. The cold and snow will make every little problem worse.
    WoodsGhost and Newfiebruh[OP] like this.
  12. Jan 23, 2019 at 9:04 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    2015 sporty dcsb 4wd
    Lifted, armored, lumenz w/ switches, positraked, long legged, big tars, debadged with a hood skewp
    Basiclly what you imagine how long it will take an double it. Take your time dont rush have plenty of beer breaks an make sure your lca cambolts are not seized before install.
  13. Jan 23, 2019 at 9:10 AM
    medic2230
    Murph
    Bama! Roll Tide
    After breaking the first tool I would have beat a flathead screwdriver into the side of the filter and gotten it off that way.
    JaCado and jv_74 like this.
  14. Jan 23, 2019 at 9:22 AM
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    I installed my 2in front spacer and Headstrong progressive 3 leaf AAL this weekend. First time ever doing a lift. Took about 7 hours.
    Advice in my experience:
    Spray all bolts a day or two before installation.
    If you access to impact wrench(air or electric) it will make it easier and faster. (I didnt lol)
    Take your time!
    Look up Kflo on youtube for front spacer install. Very good instructions and has torque specs as well.
    Newfiebruh[OP] likes this.
  15. Jan 23, 2019 at 9:33 AM
    therealmojoe
    therealmojoe Member
    Joe
    Los angeles
    2014 tundra
    6" coilover lift
    If you know what you're doing and have the right tools, the kit will only take 2 hours. If you're not 100% mechanically inclined and only have a small tool box you're looking at 4 hours.
  16. Jan 23, 2019 at 9:37 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I really don’t want to know how long it would take me. Probably weeks with the truck on a lift. Most of the time would be me staring at the truck trying to jedi mind install everything.
    I know my limits haha
  17. Jan 23, 2019 at 9:52 AM
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Bilstein 5100 w/521600 coils DAKAR EL096 HD LEAFS BILSTEIN 5100 (B110) AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 265/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    installing a lift out in the snow sounds rough... Do you possess the adequate tools, jack stands, floor jack, c-clamps, etc? I would suggest a 2nd person..... as some have stated, start pb blasting the fasteners now.... watching youtube videos ahead of time will also give you an idea of what to expect.... good luck
    Newfiebruh[OP] and WoodsGhost like this.
  18. Jan 23, 2019 at 1:31 PM
    Newfiebruh
    Tom
    Oh yeah i got all the tools needed. I do all my own work, just never worked on a lift before lol
  19. Jan 23, 2019 at 1:45 PM
    medic2230
    Murph
    Bama! Roll Tide
    It's not bad. Just take your time doing it and don't be in a rush.
  20. Jan 23, 2019 at 1:56 PM
    Muddinfun
    Muddinfun Well-Known Member
    Does the 5 lug have the same problem as the 6 lug, with the rusted alignment cams?
