How long for a mechanic to install front 5100's?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Priddle, Oct 7, 2010.
  1. Oct 7, 2010 at 4:25 AM
    Priddle
    Priddle [OP] And now for something completely different....
    St. John's, NL Canada
    2014 Tacoma 4x4 TRD Sport DCSB
    Current: Pelfreybilt front and rear bumpers, winch, icon front coils/shocks, Icon rear shocks, Dakar leafs, Camberg UCAs, Pumpkin Android stereo, custom sub box w/ 2x10" RF subs and Kicker amp, short shifter kit, Fuel Beast 18" wheels w/ 1mm offset, BFG AT2 285/65/18
    I just dropped my truck off to get stuff installed including 5100's. He said 2 front struts will be about 2 hours to install. Is that accurate?? I would have figured an hour tops for both! But what do I know!
    I hate bringing vehicles into garages because I always feel like I am being ripped off.
  2. Oct 7, 2010 at 4:30 AM
    uberlols
    uberlols I can fit 35"s
    Jake
    Va beach
    6" of lift
    I would say an hour tops. In fact I think that job only pays for 1 hour for mechanics. He probably said two because they have other stuff going on and to cover his back.
  3. Oct 7, 2010 at 4:35 AM
    Priddle
    As long as he doesn't charge me that extra hour for covering his back lol
  4. Oct 7, 2010 at 4:59 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    I could see it taking even longer than that depending on how corroded things are and you don't want them going at your struts with a torch. The nuts on the top of my struts barely look like nuts anymore and I couldn't budge them with a wrench and pipe extension so rather than take a chance at breaking something my 5100's get installed tomorrow along with getting the rear springs redone. Sometimes its just better to let someone else do it.
  5. Oct 7, 2010 at 5:11 AM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Actual time should be less than an hour. 2hrs book time sounds about right. That's how mechanics make money. Unfortunatly, it's how its done. I did my front and rear 5100s in alittle under 1.5hrs
  6. Oct 7, 2010 at 5:15 AM
    Priddle
    Ok, we'll see what happens.
    This truck is pretty much rust-free. So it shouldn't be that difficult.
    I believe this truck lived in Labrador for awhile because, oddly enough, they don't use salt on the roads there and there is little salt in the air from salt water.
    Anywho, I hope to post pics of the results later!
  7. Oct 7, 2010 at 5:17 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I think if he charged 120-140, it'd be fair
  8. Oct 7, 2010 at 5:37 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Well, I am guessing that he gave you a price before you cut him loose.
  9. Oct 7, 2010 at 5:39 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    does he have to remove the spring if so book time on front sturts
    is 1.7 hours pl the alignment
  10. Oct 7, 2010 at 5:42 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    If the price is reasonable, I'd rather have a mechanic take his time to do any job right.
  11. Oct 7, 2010 at 5:54 AM
    Priddle
    Like I said, I don't know. Maybe 2 hours is reasonable...thats why I asked here lol
    I know my brother lowered his car in his driveway in an afternoon. Different vehicle yes but I figure it would be the same principle.
  12. Oct 7, 2010 at 6:26 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    ^^^^ This is your answer. But since your a bit north of us, it may range, they should be charging you around 1.5-2.0 hours labor.
  13. Oct 7, 2010 at 6:27 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    it took me about 3 hours to get them off and on myself, i brought the coil assembly to a mechanic to swap out the shocks, that took him 10 minutes. 2 hours seems fair
  14. Oct 7, 2010 at 6:49 AM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    2019 TRD OR Cement
    Quikfix seat risers and lic plate mount, MESO interior and stage 1 tails, glove box and console dividers, shelf for center console, FACTOR 55 hitch link, TC bed stiffeners, OE bed mat,
    My "book" at work says 1.6hrs to do one side and 1.7 for both.......
    Remember his "time" includes paper work, going to the lot and getting the car, putting the car on the lift, doing the work, taking the car off the lift, finishing the paper work and spending 15 mins w/the customer on delivery. It all adds up and adds up quickly.
    On top of that here in CA the BAR has a new law..... We have to measure and record the tire pressures of every car that comes into the shop and then adjust the pressure and record the final number when the car leaves. If the BAR thinks this is going to be free they need to remember that we don't do this for fun, we do it for money. The fun part is just a bonus.
  15. Oct 7, 2010 at 7:58 AM
    tacobox
    ^^^ I hate when labor guides do that. 1.7 for both is about right on but to only get 0.1 of an hour for the other side is rediculous haha :p. Guess they're figuring that you'd do both sides anyway
  16. Oct 7, 2010 at 8:43 AM
    Priddle
    I just called for an update and they figure 7-8 hours to get the front struts in and rear airbags installed. He said there is drilling required for the no-drill kit. :confused:
    I wish now I had tried the airbags myself...
  17. Oct 7, 2010 at 9:21 AM
    David Tarantino
    N.J.
    08 tacoma
    You never said anything about airbags before
  18. Oct 7, 2010 at 9:25 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    It took me and a buddy an hour to do my coilovers. If they have to put the springs on i'd say 2 hours sounds about right
  19. Oct 7, 2010 at 9:47 AM
    Priddle
    I know...I had asked what the time was to get struts installed. Thats all I wanted to know really.
    As for the airbags, it seems that many mechanics I have talked to have not installed them before (at least around here) so its a learning process for them too. I can understand that taking somewhat longer than expected.
    Anywho, 1-2 hours seems to be the norm on struts.
