How long life are OEM Wheel bearings?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ExGunner, Aug 25, 2024.
  1. Aug 25, 2024 at 1:44 PM
    ExGunner
    ExGunner [OP] Well-Known Member
    Paul
    2017 Tacoma TRD Sport Blue
    2017 Tacoma . 205.000lkm/125,000 Miles and I'm still on original wheel bearings. One hand says replace (fronts) anyways soon because at 125,000 km it wont be long until i will probably need them. The mechanic at dealership says they are fine. I dont do any real hard off road at all and 99% of miles is all paved highways. Mainly jobsites and mining sites I teach at can get a bit dicey at times.
    How long are Front Wheel bearings good for? I just know that in my old Jeeps a 100,000 miles often was a bit of a unicorn and my mindset is still on that.
  2. Aug 25, 2024 at 1:58 PM
    TacoLC
    TacoLC Active Member
    23 Taco TE Fzj80
    You can keep on trucking if there’s no play in them. Are you running stock wheels/tires?
    ExGunner[OP] likes this.
  3. Aug 25, 2024 at 1:58 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Dude, drive them until they start talking to you. That could be tomorrow or never.
  4. Aug 25, 2024 at 2:00 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Keep on driving. They will tell you when it’s time to replace them. They don’t all fail at the same time so there is no reason to replace them ahead of time. They may last another 300K, or 3K.
    ExGunner[OP] and Chew like this.
  5. Aug 25, 2024 at 2:03 PM
    DoubleB
    DoubleB Well-Known Member
    Bakersfield CA
    22 TRD Pro / 06 PreRunner
    The front on my 2nd gen lasted about 90k. It now has 190k and they are still going strong. The rears have never been touched.
    I only have 40k on my ‘22, so don’t plan on them needing any attention for a while.
    You will be able to hear and feel them when they start going bad. I ordered a set completely assembled and they were super simple to replace.
  6. Aug 25, 2024 at 2:20 PM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
  7. Aug 25, 2024 at 2:34 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Infinite amount of variable, so there is no set mileage or timeframe.
    Follow recommended maintenance schedule, stop trying to fix what isn't broke, and enjoy life.
    RustyGreen and ExGunner[OP] like this.
  8. Aug 25, 2024 at 2:42 PM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    Most go very long. Mine went way over 125,000 on my 2nd gen. For my 3rd gen they wore out quicker due to wheel spacers and more off roading.
  9. Aug 25, 2024 at 3:55 PM
    ExGunner
    Paul
    Yes . I Have a level lift done only but stock tire size . I use the stock Tacoma rims with my winter tires and i have a set of summer rims with a slight offset to push the tires out a bit more for a nicer stance.No spacers,
  10. Aug 25, 2024 at 4:04 PM
    TacoLC
    23 Taco TE Fzj80
    I would keep on going like everyone said above! I’m pretty ocd about preventative maintenance and even I would leave that in the category of “if it ain’t broke don’t fix it.”
    ExGunner[QUOTED][OP] likes this.
  11. Aug 25, 2024 at 4:07 PM
    ExGunner
    Paul
    Sounds like a plan. I'm also ,obviously, a little OCD about maintenance so sometimes its good to get others opinions and alleviate any trepidation.
    TacoLC[QUOTED] likes this.
  12. Aug 25, 2024 at 5:43 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Just like everyone else says, they are good until they are bad and they generally make noise long before the point of leaving you stranded.
  13. Aug 25, 2024 at 5:46 PM
    Bishop84
    Bishop84 Well-Known Member
    Easiest way to check bearings for obvious wear is to smack them, they make a hollow sound on the bad ones.
    When you shake the wheel the cv axle will wobble with the play.
    That said, most tacoma bearings I diagnose are from sound when you turn while at speed it changes tone.
    RustyGreen likes this.
