how manhy quarts of oil u guys using??
Discussion in '1st Gen. Tacomas (1995-2004)' started by .Trdtaco315., May 13, 2010.
  1. May 13, 2010 at 4:17 PM
    .Trdtaco315.
    .Trdtaco315. [OP] Well-Known Member
    Will
    Santa ana
    03 Trd SR5 Prerunner
    how many are u guys putting in ur 3.4L
  2. May 13, 2010 at 4:36 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    5.5 qts with new filter each time.
  3. May 13, 2010 at 4:37 PM
    .Trdtaco315.
    Will
    Santa ana
    mine almost took 6 quarts is that bad? like i could have poured all of the 6th quart in, but i didnt
  4. May 13, 2010 at 4:42 PM
    Blumpkinson
    Blumpkinson Fuelled by plutonium and wild animals
    OR
    03 4x4 5spd
    Stupid question but did you check your dipstick?
  5. May 13, 2010 at 4:43 PM
    .Trdtaco315.
    Will
    Santa ana
    yes i did
  6. May 13, 2010 at 4:45 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    5.5 qrts
  7. May 13, 2010 at 4:46 PM
    .Trdtaco315.
    Will
    Santa ana
    guess ill stick with that.
  8. May 13, 2010 at 4:46 PM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    not sure... I buy my mobil1 by the gallon jug and fill until the dipstick says its full. I would say in between 5.5 & 6 qts sounds about right tho.
  9. May 13, 2010 at 4:47 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    Yep...I just looked in the manual and it says 5.5 quarts
  10. May 13, 2010 at 4:47 PM
    Blumpkinson
    OR
    03 4x4 5spd
    As long as your between the lines you should be fine. Another stupid question, did you check for any leaks?
  11. May 13, 2010 at 4:55 PM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_à²
    (Former Tacoma owner) 17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    I could have swore my manual said 6.3. I hope I didn't overfill it
  12. May 13, 2010 at 4:56 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    5.5 with filter every time. Always perfectly in the middle of the dipstick.
  13. May 13, 2010 at 5:22 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    I think it can take 6 qts if you drain it well and replace the filter, but extra oil is also hard on an engine so I stick with what the manual says.
  14. May 14, 2010 at 12:19 AM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    2004 TRD Offroad PreRunner 3.4L V6
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    x2, I thought they took more oil but they don't. I put a 5.5 qt jug of Castrol w/ a BG MOA and when I first checked it after I ran it it showed about .5 qt low. I checked it a few days later and then it was right at the F line.
  15. May 14, 2010 at 1:21 AM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    5 plus lucas.
  16. May 14, 2010 at 8:08 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    5.5 w/ new filter.
  17. May 14, 2010 at 5:45 PM
    .Trdtaco315.
    Will
    Santa ana
    Idiot! i totally failed. i was chaing my oil and forgot to change out the filters :rasta: damn my ways.
