HOW MANY MILES FOR FULL TANK STOCK TACOMA?????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JLUIS, Feb 2, 2013.
  1. Feb 15, 2013 at 10:43 AM
    #101
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    My driving is all rural roads , and I do get better mileage when I get off the island and run some highway speeds
  2. Feb 15, 2013 at 4:15 PM
    #102
    SNThorsen
    SNThorsen Well-Known Member
    Shelby
    Mobile, AL
    white 09 TRD Sport
    Sprayed black wheels/ bed lights/ fog light mod +yellow lens/ reverse light mod(changed to fog lights)/ 5100s x4 / under the hood lights/ driver seat flashlight holder/ bed fire ext./ next up will be some tires not sure type yet.
    I have the DCLB 4x4 stock and I get 280-300 city and 330 Hwy, i believe its a 20gal tank. I am usually pretty lite on the gas about 80% of the time all the time.
  3. Feb 15, 2013 at 4:58 PM
    #103
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    That's why my next Tacoma will be the auto like yours. Everything north of 55 mph is over 2000 rpm and freeway speeds activate that little toilet flushing lever on the fuel pump.
  4. Feb 15, 2013 at 5:00 PM
    #104
    focotacoma
    focotacoma Well-Known Member
    Fort Collins
    07 Speedway Blue 4x4 TRD off-road
    Im getting there......
    I have maxed at around 440-455 on mid-grade
  5. Feb 16, 2013 at 7:50 AM
    #105
    toyota25270
    toyota25270 Member
    USA
    TRD SPORT
    (2inch lift)Toytech ARE Hardcover,456 GEARS.Bully bar
    2007 4x4 V-6 AUTO (Tires 265-65-17)Gears 456 city 17.8 MPG......now can anyone PM me with a answer on this I have a sound when I put tranny in gear sounds like little stones ratteling and this is a ACCESS-CAB is it common to hear lots of air noise in rear of truck?Just got this need some answers.Private message me if you would please.Thank you
  6. Feb 18, 2013 at 1:02 PM
    #106
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    2012 double cab 4wd V6.
    after about 35 fill ups, my fuel indicator light turns on consistently at about 17.5 gallons down from full (i.e. when the light turns on, i go to fill up and it takes 17.5 gallons). i'll have to check on milage, but i'm pretty sure i'm getting right around 19.5 ave hiway/city. btw, how big is the tank? 21 gallons?
  7. Feb 18, 2013 at 1:05 PM
    #107
    NMTrailRider
    New Mexico
  8. Feb 18, 2013 at 3:48 PM
    #108
    yotaman90
    yotaman90 bröther may I have some lööps
    Taos, NM
    2012 TRD Offroad
    I've gotten my Tacoma to get over 400 miles a tank with all-highway driving and keeping my foot out of it. In town I get significantly less :(
  9. Feb 18, 2013 at 6:18 PM
    #109
    SAXD Taco
    SAXD Taco Well-Known Member
    Justin
    Atlanta
    2013 DCLB, 4X4, MGM
    N-Fab Steps, BakFlip F1, TRD Accessory Skid Plate, Toyota Bed Mat, Husky Liner Floormats
    I'm only on my 3rd tank of gas for my 2013 dclb, 4x4, but I've been able to get right at around 350 miles per tank (averaging about 18.6 mpg, roughly 18.5-19 gallons per fill up). Hoping that it will get little better after the engine breaks in.
  10. Feb 20, 2013 at 3:44 PM
    #110
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    tank, tank, tank... means nothing unless there is a standard gallon point. Surely you all don't drive until you run out of gas...??? as that would be a tank!!! (21.1 gallons)
    400 miles, 350 miles,... per what part of a 'tank'? (ie. the gallons)
  11. Feb 20, 2013 at 3:50 PM
    #111
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    according to his numbers he posted...
    about 18.8 gallons ;)
  12. Feb 20, 2013 at 5:30 PM
    #112
    Imageoguy
    Imageoguy Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
    When the pump at the station dissengages when fuelling up, is it filled to the 21.1 Gal (80 L) capacity? I was able to add another 10 L by topping it slowly right to the fuel cap a couple times but was told that wasn't a good idea.
  13. Feb 20, 2013 at 6:12 PM
    #113
    imartin
    imartin Well-Known Member
    Katy, TX
    2015 Tacoma Access Cab
    2013 4.0L V6, Auto, 4x4
    factory 18" upgraded to 285/65 - 18 Nittos
    level/lift kit (lost nose rake)
    323mi/18.67gallons = 17.3 mpg
  14. Feb 22, 2013 at 4:40 PM
    #114
    David K
    Excellent!! :D
  15. Feb 22, 2013 at 4:50 PM
    #115
    David K
    Who knows just when the pump disengages... There is likely a good gallon or more in the fill neck? Anyway, if you round it up after the pump first stops consistently, without overflowing, each time, then your mileage figures will be more true. If you really top it off, then next time you fill it, you don't add more after it clicks off... then you will be under-reporting, or using less gas than the true amount. Always re-fill to the same point for true mileage calculations.
    Sadly, you could be in Oregon or another state that won't let you put your own gas in, and the attendant isn't allowed to round it up. For figuring mileage, however... as long as you compare two fill ups to the same point, you will have a accurate mileage... regardless if you had 20 in the tank or 21 gallons in it the two times. You are only comparing the amount used between fill-ups... 16, 17 or 18 gallons usually!
  16. Feb 22, 2013 at 8:26 PM
    #116
    olatheneyens
    olatheneyens Member
    Doug
    KS
    11 Toyota Double Off-road
    Stock 2011 DC, manual, 4x4 and usually getting around 16-16.5 mpg. I usually fill up quickly when the light comes on or sooner if it is colder (KS). I don't pay attn to the overall distance that I went and I generally am driving city miles at 45ish and with some lights.
  17. Feb 23, 2013 at 5:35 AM
    #117
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    It is a very bad idea to "top up". I used to top up my '03 until I had gas forced into the charcoal canister which cost me $600 to replace. When the pump shuts off..I stop fueling.
  18. Feb 23, 2013 at 7:36 AM
    #118
    Imageoguy
    2012 DCLB SR5
    That's what I heard so not doing it again. I'm just wondering if the capacity of the tank takes this into consideration or not.
  19. Mar 12, 2013 at 5:02 PM
    #119
    dboz
    dboz Well-Known Member
    Access Literider Tonneau, GO RHINO Dominator II side steps
    First 300 mile road trip. 19.4. MPG. I can live with that.
  20. Mar 12, 2013 at 5:13 PM
    #120
    Hellomoto
    Hellomoto GPV Helicopters inc
    Cape Canaveral Fl
    05 SR5 Black
    6" Pro-comp with 3" body lift SS Side bars. SS Bull bar. Dark glass. HID's
    NOT SURE ON A FULL TANK BUT 13 / 14 CITY AND 20 HWY
    IS MY CAP LOCK PISSING ANYONE OFF?
