How many miles on your 2nd Gen?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4WDTrout, May 19, 2021.
  1. Mar 29, 2023 at 6:07 PM
    #201
    Littletinytaco
    Littletinytaco Member
    Silver 2008 tacoma 4cyl
    Working on it. I've been busy with family, school, and church I haven't been able to get around to it.
    bagleboy[QUOTED] likes this.
  2. Mar 31, 2023 at 4:20 AM
    #202
    Falcoholic87
    Falcoholic87 Active Member
    2005 Tacoma
    05 Tacoma Base model. 250,000 miles and I have a slight oil leak and my radiator is leaking... currently getting that replaced. I'm not knowledgeable enough to do it myself. I'm convinced if I fix the issues I'm having now that this thing will easily last me 5 years without any other major issues. But I've had U joint replacement, wheel bearing replacement. Other than the leaks she runs like a champ now. She is showing a catalytic converter code too but no issues with performance so I'll just get that fixed sometime after I get new tires on her...if I do indeed have an issue there. Put alot of work into my old Taco...but they are such reliable trucks if you take care of them that I think I can easily get another 5-8 years out of her. Put about 10,000 a year on it. And she's paid off so I'm all in on trying to make her last. Just got a new radiator installed and mechanic told me I actually do not have an oil leak...so we all good
  3. May 8, 2023 at 2:40 PM
    #203
    robbergeron23
    robbergeron23 Well-Known Member
    rob
    holland, ma.
    2014 TRD sport v6 4x4 access cab
    Last month reached 200K. Driver’s side power lock in its second year of ownership failed, and blower motor a few months ago. Great truck!
    TomTwo, ToyoTaco25, jackn7 and 5 others like this.
  4. Jun 3, 2023 at 1:24 PM
    #204
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Bought new in Jan 2009. No issues other than bad injector coil around 100k. Otherwise just normal wear items.
    Pics from Jan this year.
  5. Jun 3, 2023 at 7:51 PM
    #205
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [TO] V6 Tow Package [ED] Entune Audio Plus
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    2014 SR5 4x4 DC SB 4.0 Auto Purchased 2021 w/104,000 miles
    Current Mileage: 124,000
    Twice-inspected Original Frame: Good
    Routine maintenance per Toyota schedule
    Major repairs: None
    jon_elc, jackn7 and KLiK like this.
  6. Jun 3, 2023 at 8:44 PM
    #206
    Williston
    :eek:
    I hope that's because you want to save the Tacoma because it's your favorite and not the Datsun. ;)
    jackn7 likes this.
  7. Jun 4, 2023 at 6:13 PM
    #207
    Reids2TR-FE
    Reids2TR-FE New Member
    Southern Middle TN
    2009 Ext Cab Base 2.7L 260K+ miles
    Purchased new 2009 Extended Cab Base with 2.7L with 1.7 miles on it. Now 261K miles, no major issues until recently. Had to replace coolant bypass pipe last weekend, fun job. This weekend however, got stranded due to crank, no start issue and had to get it towed home. Swapped fuel pump relay with horn relay and it cranked right up today. Glad to have it back running. Loaded up a tool kit to have if needed. Was caught off guard with no tools or diagnostic equipment.
  8. Jun 4, 2023 at 6:34 PM
    #208
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    2015 AC base+ 4x4 2.7, auto trans. I got it almost 3 years ago, I'm at 123K on it, It took a LF wheel bearing last week, that was the 1st major repair since I've had it. I did front rotors/pads and swapped in a 3rd gen TRD OR suspension when I got it, the original coli overs and rear shocks/leaf springs were shot.
  9. Jun 5, 2023 at 8:25 AM
    #209
    Wilso14
    Wilso14 Active Member
    Philly Burbs
    2014 trd sport 6spd
    2014 with 59k.
  10. Jun 5, 2023 at 8:30 AM
    #210
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    2009 with 202,300
    bought used in '13 with 53k
    only "problem" so far was a busted AC condenser. Naturally, it happened in August during the 100 deg summer heat
    jackn7 likes this.
  11. Jun 5, 2023 at 8:35 AM
    #211
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Really nice looking ride you got there!
  12. Jun 5, 2023 at 8:37 AM
    #212
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    2013 95k miles
    I was putting on 18-20k a year consistently for the first few years but that came to a screeching halt in 2019 when I started working from home full time. Now most of its heavy lifting use is saved for occasional road trips.
    jon_elc, MSgt O and jackn7 like this.
  13. Jun 5, 2023 at 9:42 AM
    #213
    Wilso14
    Philly Burbs
    2014 trd sport 6spd
    Thank you Sir.
    jackn7[QUOTED] likes this.
  14. Jun 5, 2023 at 9:59 AM
    #214
    PatHenry52
    PatHenry52 Active Member
    New to me 2008 4cyl 5spd has 268K on it so far. Intending to get at least 3y 60K more out of it, but hoping for much more.
    Stelcom66 likes this.
  15. Jun 5, 2023 at 11:54 AM
    #215
    mastripo
    mastripo Well-Known Member
    Purchased new in January 2006. Currently sits at 186,700. No major mechanical issues other than maintenance items. Had the frame replaced about 6 years ago under the recall. Only issue is that my clear coat started bubbling this past winter and now it is peeling up on my hood and roof.
    jon_elc likes this.
  16. Jun 5, 2023 at 12:11 PM
    #216
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    2013 Bought new, now has 124K on it...nothing major ever has gone wrong..standard MX things, and she runs like the day I bought her washed waxed Taco.jpg
    Kolter45, jackn7 and jon_elc like this.
  17. Jun 5, 2023 at 12:33 PM
    #217
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    I got my 2011 SR5 from a relative in Oct2019 with 39k. It up to 73k now. I got a used color matched shell last month and I'm ready to keep this baby for another 200-300k.
    Kolter45, jackn7 and Williston like this.
  18. Jun 5, 2023 at 12:34 PM
    #218
    Azul
    Azul Member
    Beautiful color
    jackn7 likes this.
  19. Jun 30, 2023 at 2:47 PM
    #219
    nonohmic
    nonohmic Well-Known Member
    And now?
  20. Jun 30, 2023 at 4:03 PM
    #220
    greyeyezz
    greyeyezz Well-Known Member
    I got that beat. 2007 with 73,400
