How many miles on your 2nd Gen?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4WDTrout, May 19, 2021.
  1. Jul 26, 2025 at 1:20 AM
    #561
    Stubert90
    Stubert90 Well-Known Member
    First Tacoma - 2007 Dual Cab Pre-Runner 6ft
  2. Jul 26, 2025 at 6:52 AM
    #562
    Hay Lobos
    Hay Lobos Let's be friends.
    Ben
    The Great State of Maine
    2013 Tacoma SR5 Access cab
  3. Jul 27, 2025 at 4:46 AM
    #563
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    Nice.
    Hay Lobos likes this.
  4. Jul 30, 2025 at 5:44 PM
    #564
    oledragoon
    oledragoon Well-Known Member
    Don
    Oklahoma City
    06 Super White Tacoma TRD Off Road 4x4
    Super White Grille, and rear bumper on Off Road, TRD Intake System, TRD Cat Back Exhaust System, Custom bed bar for Emergency light bar, Overhead Console Temp/Compass Fix,rcbs Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Jumpers LED's in cab, Jotto Computer desk, Cobra 29 CB & Uniden Scanner on custom dash pad, Autometer gauges(oil press, oil temp, trans temp, Batt/amp), Front bush guard, Rear bumper guard, BamaToy1997 4x4 Custom Front Hubs, OTW Mod One Touch Windows.
    2006 TRD OR Bought new 439,939 When it hits 440,000 i'll post pics.....
  5. Jul 30, 2025 at 6:15 PM
    #565
    herecomesace
    herecomesace Well-Known Member
    2013 Tacoma TRD Offroad Access Cab MGM Supercharged
    Keep rollin', rollin', rollin'
  6. Jul 30, 2025 at 6:56 PM
    #566
    LarHawes
    LarHawes Well-Known Member
    Larry
    Vista CA
    2015 TRD OFFROAD ACCESS CAB
    217,000 on my (just purchased) '15 TRD OR AC. Runs like a champ but will have my mechanic triple check everything.
    kwanjangnihm and jackn7 like this.
  7. Jul 30, 2025 at 7:04 PM
    #567
    RollingHeavy4x15
    RollingHeavy4x15 New Member
    15 ACLB 4x4 2.7L manual
    ARB deer insurance bumper
    412,000 on the odo
    And...
    Maintenance through the miles...
    On third alternator
    Replaced valve cover gasket
    Replaced a few Front suspension components(control arm bushings, ball joints, tie rod)
    New front axles (old boots cracked)
    New AC compressor
    New O2 sensors
    In 2019 Dealer sealed the frame and coated.
    Very little surface rust in one spot nowadays
    Added the ARB front bumper, gotta little sag to her, maybe 1" sag, looking to upgrade springs and shocks
    Regularly scheduled visits to her favorite Toyota techs
  8. Sep 4, 2025 at 7:36 PM
    #568
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  9. Sep 5, 2025 at 12:16 AM
    #569
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB 1GR-FE
    Purchased at 99k, just rolled 198k.
  10. Sep 5, 2025 at 1:40 AM
    #570
    jrzjoe
    jrzjoe Well-Known Member
    Joe
    2013 trd sport 2023 trail edition
    1.75 in bilstien 5100 lift on the 2013 2023 TE OTT tune
  11. Sep 5, 2025 at 3:24 AM
    #571
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Im just about to hit 250K on my 08, I bought it used in 2017 with I think 160K. I think its still the factory drivetrain. Other then basic maintenance things I've replaced is - alternator, 1 valve cover gasket, u joints(three times), center bearing(twice), F pads and rotors(twice), both front wheel bearings, I did replace the entire factory suspension front end at 200K which included shocks(rears as well) UCA, LCA, outer tie rods, steering rack(leaking but wouldn't have bothered if I wasn't doing everything else), sway bar links, sway bar bushings.
  12. Sep 5, 2025 at 6:16 AM
    #572
    Wpperry83
    Wpperry83 Member
    07 Tacoma
    2007 4.0L
    186,xxx and going strong
  13. Sep 5, 2025 at 9:49 AM
    #573
    Not a golfer
    Not a golfer Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
  14. Sep 6, 2025 at 8:12 PM
    #574
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [ED] Entune Audio+ [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    Purchased: 4/2021 (pre-owned, one owner) with 104,000. Current mileage: +- 144,000
  15. Sep 7, 2025 at 6:52 AM
    #575
    dogpoke
    dogpoke Member
    2013 Tacoma DCLB
    IMG_4928.jpgJust went over 145k! Driven from Virginia to Alaska over a span over a few years!
  16. Sep 7, 2025 at 2:57 PM
    #576
    racer_kmk
    racer_kmk Member
    2007 Base Model Double Cab, V6,4x4, 6spd Stick
    269K. Love my '07 DCSB V6 4x4 6spd!
    No major problems so far.20250829_183654.jpg 20250823_151903.jpg 20250607_130541.jpg
    4WDTrout[OP], robm7, dborrer and 7 others like this.
  17. Sep 7, 2025 at 3:22 PM
    #577
    TacoReg2010
    TacoReg2010 Member
    Texas
    2010 Tacoma Regular Cab
    I bought mine used but it has been well maintained. Hit 100K this past week.
  18. Sep 8, 2025 at 4:39 AM
    #578
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    W:eek:W!
    way ta stick with that sh!T :cheers:
    jrzjoe and jackn7 like this.
  19. Sep 9, 2025 at 8:03 PM
    #579
    Pigpen
    Dan
    Northwest Montana
    My 2012 that I bought with 30 miles on it (10 were my test drive) just hit 200,000 last week.
  20. Sep 13, 2025 at 1:55 PM
    #580
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
