How many miles on your 2nd Gen?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4WDTrout, May 19, 2021.
  1. Sep 5, 2022 at 10:12 PM
    #41
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    2015 - 143,xxx miles
    I've replaced an axle seal and shoes on one side, and the t-case input seal
    Not one single warning light ever
    TnShooter likes this.
  2. Sep 5, 2022 at 10:49 PM
    #42
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Was it the left rear?
    That’s the one that likes to leak.
    Gid likes this.
  3. Sep 5, 2022 at 11:13 PM
    #43
    Gid
    Gid New Member
    Gideon
    2009 white Tacoma sr5 access cab
    Levelled. aftermarket rims Toyota frame replacement
    I have a 2009 with 215,000km.
    Had a front wheel bearing and abs sensor go at 150,000.
    New frame at 160,000
    alternator at 165,000.
    replaced my left rear axel seal, left rear wheel bearing and both rear brake assembly’s at about 190,000.
    CV axel at 210,000
    Tennis ball sized hail last week :/
  4. Sep 6, 2022 at 4:51 AM
    #44
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    It looks to me like something used to be welded to that frame and has been removed. You can see the welds all along the frame, both high and low, which isn't how it left the factory. Perhaps someone removed rock sliders and the painted frame. Might be worth asking the seller.
    4WDTrout[OP] likes this.
  5. Sep 6, 2022 at 7:12 AM
    #45
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yep. Looked like the lip of the seal was riding in the groove between the spacer sleeves on the axle. When I installed the new seal I purposely didn't push it in all the way. It's spaced out a little and makes better contact on a better surface. It's been good ever since
    TnShooter[QUOTED] likes this.
  6. Sep 6, 2022 at 5:33 PM
    #46
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    A bit of an outlier here, 2010 with 45k. Need to replace the belt tensioner due to internal clicking noise and sounds like a wheel bearing is on the way out.
  7. Sep 6, 2022 at 5:45 PM
    #47
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    2007... 33,750 miles. Other than routine maintenance and various upgrades i had to replace a taillight bulb once.
  8. Sep 6, 2022 at 5:48 PM
    #48
    AdamM
    AdamM Semi-pro aardvark wrangler
    Adam
    Edmonton, AB
    14 DCSB base 6MT 4x4
    Just about to hit 200000km (124000 miles). I've had to replace the blower motor resistor, drive belt pulleys, clock spring, and front left cv, oil seal and needle bearing.
    The needle bearing went when after I put third gen suspension on the front, with just 1/4" spacers, believe it or not. The cv axle replacement was a result of driving on the bad needle bearing for about a year, so that was on me.
    Oh, and I have oil seeping from one of my valve covers, so valve cover gaskets coming soon. I haven't experienced this legendary toyota reliability that people talk about.
  9. Sep 6, 2022 at 5:55 PM
    #49
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    2013 - 111xxx miles and the only necessary maintenance that’s been required outside of unnecessary modding has been the replacing of a single battery and that of the magnetic clutch relay (had the dreaded blinking AC light dilemma), replaced the relay, and good to fudging go!
  10. Sep 6, 2022 at 5:55 PM
    #50
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    66K on the 2012 DCSB, truck is seriously like brand new.
    325K on the 4Runner when I sold it, everything still worked, and it was a trail rig also.
    134K on the 2014 AC.
    Toyota's rock.
  11. Sep 6, 2022 at 5:57 PM
    #51
    10thMTNgrunt
    2013 TRD Sport
    You may have the youngest 07 on the planet, or would that be a stretch?
    DR2011 likes this.
  12. Sep 6, 2022 at 5:59 PM
    #52
    Brakes303
    Brakes303 Well-Known Member
    Denver
    2015 TRD sport
    TRD Supercharged ,TRD Quick shifter, TRD exhaust, King 2.5 adjustable suspension, URD fuel filter/pump kit . Brute Force fab high clearance rear plate bumper W swing out spare tire and rotopax mount.
    only 89500 young .. still drives like when I took her home from the factory with 0.
    10thMTNgrunt likes this.
  13. Sep 7, 2022 at 4:54 AM
    #53
    balls47
    balls47 Well-Known Member
    Western Colorado
    99 TRD OR, 2014 DCLB TRD Sport
    2014 with 204000, well maintained and not a single part failure to date.
  14. Sep 7, 2022 at 7:42 AM
    #54
    Greyhome
    Greyhome Well-Known Member
    Graham
    Richmond, VA
    2015 4Runner Trail
    2014 with 84k here. Many miles to go!
  15. Sep 7, 2022 at 8:52 AM
    #55
    Nicknaylo
    Nicknaylo Active Member
    2015 Base
    None
    2015 with 47K on it. 35K when I bought it 18 months ago. Nothing but scheduled maintenance. I might need to do front brakes at the next oil change but we'll see.
  16. Sep 7, 2022 at 11:42 AM
    #56
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    Doubt you'll need front brakes that soon. Always a good idea to take a look at 'em though.
  17. Sep 7, 2022 at 11:57 AM
    #57
    acparker12
    acparker12 Well-Known Member
    Penns Valley, PA
    2014 MGM Tacoma TRD Sport 4x4
    Still figuring it out…
    2014 4.0 I got her in March of this year with a little over 95k, took a vacation to NC and maybe, by the end of the month she will hit 98k.
  18. Sep 7, 2022 at 12:01 PM
    #58
    acparker12
    Penns Valley, PA
    My repairs or things I did is too long to mention, pretty much i just need to do the transmission drain and fill’s and also the brake fluid needs changed, everything else I pretty much did to her for maintenance wise according to the second gen thread.
  19. Sep 7, 2022 at 12:09 PM
    #59
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Taken this morning on the way home from picking up my camper over in Yakima. Yes, I know I need an oil change, lol. Bought new in October 2011.
    Blower fan replaced within first year of ownership. Original battery made it over 7 years. Alternator died in the last year. Replaced front brake pads... twice? Rear pads for drums replaced last year during a re-gear, transmission fluid change, T-fer case fluid change. Did plugs once, have another set waiting to go in... Think that's about all I've done to it for "maintenance" like stuff. Bzillion other mods though, haha.
  20. Sep 7, 2022 at 12:15 PM
    #60
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    234,000 miles. First owner.
    SWB 2009 TRD Sport DCSB 4.0 V6 4x4
    AMSOIL synthetic engine oil every 10k miles, Toyota oil filter every 5k miles.
    AMSOIL gear oil every 40k miles
    3rd battery
    4th windshield
    7th set of tires rotated every 5k miles (1 set, stockers, only had 4k miles and another set only had 15k as they were not to my liking)
    Cabin and engine air filters and wipers changed yearly
    3rd set of front brake pads, rears are original, 2nd set of rotors
    Spark plugs every 30-40k
    97k: Fuel system flush
    100k: Transmission fluid change
    102k: Injector coil/pack for cylinder #5
    105k: HVAC blower fan
    107k: Temp compass resistors and HVAC blower fan resistor
    122k: Front wheel bearings
    128k: Drive shaft U-joints and carrier bearing
    130k: Oil control valve
    128k: Serpentine belt and pulleys changed
    170k: Steering, brake, and coolant fluids flush and CV axles
    180k: All new shocks
    181k: UCA bushings and uniball
    184k: LCA with ball joint and bushings
    188k: new HVAC blower fan resistor, rear brakes cleaned
    190k: wheel studs
    205k: new starter
