How many miles on your 2nd Gen?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4WDTrout, May 19, 2021.
  1. Sep 7, 2022 at 12:18 PM
    #61
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    2012 with 136k.
    I need to do some preventative maintenance like replace the u joints, they all take grease just fine but I should probably just do them to be safe. Everything else is solid.
  2. Sep 7, 2022 at 12:58 PM
    #62
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    194k miles.
    LCAs, front wheel bearings, E locker actuator, U joints/carrier bearing.
    Everything else has been routine maintenance like brakes, fluids, tires, etc
    Road_Warrior likes this.
  3. Sep 7, 2022 at 3:04 PM
    #63
    Bosstones27
    Bosstones27 Member
    Massachusetts
    2013 TRD T|X Baja
    2013, just turned 95k this week
  4. Sep 7, 2022 at 3:12 PM
    #64
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Soooo clean and sooo many miles :drool:
  5. Sep 7, 2022 at 3:57 PM
    #65
    Bman562
    Bman562 Well-Known Member
    SoCal, CA
    2005 Radiant Red Tacoma Sport DCSB
    '12+ Facelift, TRD Baja Bilsteins, SCS Ray10's, K02's...
    2005 with 140k
    Repairs - U joints and carrier bearing. Other than that, the basics; fluids, battery, tires and brakes.
  6. Sep 7, 2022 at 5:28 PM
    #66
    Sonofliberty92
    Sonofliberty92 T O Y O T A
    Mark
    Maryland 4 South
    2014 DCSB TRD OR, 2005 Tundra V8 4WD
    45,300. 2015 double cab short bed V6 4x4.
  7. Sep 7, 2022 at 5:34 PM
    #67
    Sonofliberty92
    Mark
    Maryland 4 South
    Does that year have an issue with Ujoints or something? If you're greasing them, they should be good for many many miles. Check them for play and noise and you're good.
  8. Sep 7, 2022 at 6:40 PM
    #68
    acparker12
    acparker12 Well-Known Member
    Penns Valley, PA
    2014 MGM Tacoma TRD Sport 4x4
    Still figuring it out…
    Anyone have this beat for low miles? I was shocked to see this. $33k in todays market, not bad at all
  9. Sep 7, 2022 at 6:43 PM
    #69
    Sonofliberty92
    Mark
    Maryland 4 South
    Assuming that's a 2015, that's literally about 1000 miles a year. I'm almost scared to own it if it sat around that much.
    I paid $27k for mine with 36k on it.
  10. Sep 8, 2022 at 5:24 AM
    #70
    JMcFly
    Central FL
    2012 Tacoma SR5 4x4
    no issues, I'm just a preventative maintenance person. Ill keep greasing them until I detect slop in my quarterly inspections
  11. Sep 8, 2022 at 6:48 AM
    #71
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    2010 DCLB Prerunner, 89,000 miles bought new last day of 2009.
    Some stuff done.
    BAMF sliders, front / rear brush guards, Tru Trac rear diff, ICONs on each corner, Camburg upper arms, Spyder Trax wheel spacers, DTLT headers, URD Y Pipe, URD MAF and O2 black boxes, intake plenum spacer, remote trans filter, remote trans cooler (no fluid to radiator), oem trans cooler is power steering cooler, Volant intake duct to handmade into oem airbox, Wet Okolie seat covers, Weather Techs front and back, TC bed supports, Rocky Mounts for bicycles, bed bar for trials bikes, debadged, rerouted AC drain, frame corrosion protected with Corr-Ban 22, AlphaRex crystal headlights, AlphaRex tail lights, Morimoto 4 Banger fog lights. Maybe more. About 7000 miles per year.
  12. Sep 9, 2022 at 6:37 PM
    #72
    67 Series IIA
    67 Series IIA Active Member
    Ed
    Green Harbor, MA
    08 4X4
    Bed Tie down's, Heated Mirrors, HD radio, Wet Okley seat covers, Intermittent wipers, side rails, tailgate cap.
    2008 2.7L 2TR-FE, Manual, with 380,000.
    Wheel bearings
    Brakes
    Couple of batteries.
    Clutch
    Water pump
    A/C compressor
    Unfortunately I am now having consumption issues ~ 1qt/1k miles and low compression.
    I have been looking for a re-manufactured long block without success and have changed course and am now looking for a good used motor.
    bevo2000, Stelcom66 and R0dzilla75 like this.
  13. Sep 9, 2022 at 6:38 PM
    #73
    Sonofliberty92
    Mark
    Maryland 4 South
    V6 or 4cyl?
    Please everyone, state your engine.
  14. Sep 9, 2022 at 6:41 PM
    #74
    67 Series IIA
    Ed
    Green Harbor, MA
    08 4X4
    Sorry about that. I have edited my post.
  15. Sep 10, 2022 at 8:07 AM
    #75
    SC Taco
    SC Taco Active Member
    Orange County
    2012 4x4 DCSB Offroad
    Icon Lift, Pelfreybilt Front Bumper, Shmellmopwho Sliders, Prinsu, Bestop Supertop, X20 winch, Cali-raised and Rigid lighting,
    2012 4.0 V6. 86k. Used to drive it a lot but been babies the last 5 years.
    Sonofliberty92 likes this.
  16. Sep 10, 2022 at 8:21 AM
    #76
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    I see you're in New England like me, so that must be 380,000 miles, not kilometers! Sorry about the oil situation. But wow, that's an amazing amount of miles.
    If that list is it for repairs, that's amazing as well, especially if just one clutch.
    About 148,900 on my 2007 2.7L. Got it in May 2022, just had the air A/C compressor replaced.
  17. Sep 10, 2022 at 8:42 AM
    #77
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    2010 V6, 122k. Same normal maintenance, got a new frame in 2019
  18. Sep 10, 2022 at 8:53 AM
    #78
    Sonofliberty92
    Mark
    Maryland 4 South
    I'm curious what was/is your oil change interval?
  19. Sep 10, 2022 at 8:55 AM
    #79
    67 Series IIA
    Ed
    Green Harbor, MA
    08 4X4
    380,000 trouble free New England miles is correct.
    Yes that is the replacement clutch still going strong after the original needed replacement at 254,751 miles. Just checked paperwork, NAPA clutch pack Part#1116088 $320.49 back in 10/31/2018 Flywheel Part#88449 would have cost an additional $276 but was not needed.
    I did qualify for a frame replacement and at that time I opted to change out the steering rack although there were no issues with it.
    Re-manufactured Long blocks are near impossible to find. I even checked with Yota1 knowing that shipping would be expensive and found that they are taking orders for 8 months out to start work. Currently using Car-Part.com to locate a used motor preferably in NH (Bow auto parts) to avoid Massachusetts taxes plus I can save on shipping by picking it up.
  20. Sep 10, 2022 at 9:05 AM
    #80
    67 Series IIA
    Ed
    Green Harbor, MA
    08 4X4
    My oil change interval was on average ~6000 miles using regular dino oil.
    In the image below you can see the Blackstone reports for some of those oil changes which is weird because all the numbers still appears good but can't deny what I am seeing on the dip stick.
