how many miles per tank?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bino9905, Sep 28, 2012.
  1. Jan 11, 2013 at 1:43 AM
    #41
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  2. Jan 11, 2013 at 7:03 AM
    #42
    WuTang
    WuTang Well-Known Member
    SOMD
    2000 Tacoma v6 5 speed 4x4
    Deckplate Grey wire 2" Spacer lift 32's Retrofit
    Pun intended? :rasta::rasta::rasta:
    I normally get around 300 to the tank i also have a v6 manual, Only mods are a 2" lift 31" tires and a 6inch deckplate
  3. Jan 11, 2013 at 7:06 AM
    #43
    06sr5prerunner
    06sr5prerunner DILIGAF
    luis
    midland tx
    2006 sr5 prerunner
    bhlm paint wheels duplicolor plasti dip white grill. billies 5100. bf goodrich at 285's 75 16 black valence led corner lights expedition bed rack by anb fabrication spidertrax wheel spacers rotopax fuel tanks 4gal mounted on bed rack quickfist mounts for shovel. ddm hid kit 35watt 6000k hi/low beam
    300 miles leveled on 285s
  4. Jan 11, 2013 at 9:08 AM
    #44
    skybob
    skybob Well-Known Member
    I'm looking to fill up around 200 miles in my 02 dblcb, if I get over 210 that's a good tank. But it's 12 degrees here and it's mostly city 3" lift 265/70/17s
  5. Jan 11, 2013 at 9:14 AM
    #45
    Yamaha Dave
    Yamaha Dave Well-Known Member
    2003, 120k miles, 16" Method wheels, Michelin AT2 265/75/16, Aero Turbine and custom 2.5" piping, all maintenance up to date, no Check Engine Lights.
    305-310 miles per tank.
  6. Jan 11, 2013 at 9:30 AM
    #46
    AggiePilot12
    AggiePilot12 Well-Known Member
    Texas
    03 4x4 6" Double Cab
    6" Fabtech, All-Pro Leafs, Cold Air, Cat Delete
    Double Cab, 4x4 3.4L, 6" lift, CAI, 295 Trail Grapplers..
    260 (w/ clogged cat)
    280-310 (w/ no cat :))
  7. Jan 11, 2013 at 9:30 AM
    #47
    bearfan1985
    bearfan1985 Active Member
    Brad
    Tulsa
    '95 4wd
    Bone stock (except a lil' stereo) and awesome
    Would my '95 have a gas light on it? I almost never go below 1/4 but I might need to sometime...
  8. Jan 11, 2013 at 12:58 PM
    #48
    mikegli
    mikegli Well-Known Member
    Orlando
    04 Tacoma TRD
    I seem to get 270 to the tank regardless of how I drive or where I drive.
    When my tires get low, I dip down in to the 250 range when the light comes on.
    Bone stock, 04 3.4.
  9. Jan 11, 2013 at 1:05 PM
    #49
    Madjik_Man
    Colorado Front Range
    Winter gas sucks.
  10. Jan 11, 2013 at 1:07 PM
    #50
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
  11. Jan 11, 2013 at 1:18 PM
    #51
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Everybody blames the gas, but it the cold and short trips in the cold that hurt the most. I'm just getting warmed up when I get to work. If I had a 50 mile commute the cold and the gas wouldn't seem so drastic.
  12. Jan 11, 2013 at 2:23 PM
    #52
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    300 to the quarter tank. Stock winter tires with a 3 inch lift. Don't see much of a change when I change to my summer rims. Maybe that's cause they are not much bigger than stock 265-75-16
  13. Jan 11, 2013 at 4:09 PM
    #53
    Jiggerman
    Jiggerman New Member
    Toby
    Carson City, NV
    2002 Regular Cab Taco
    2wd regular cab 15 gallon tank. 320 miles ish, give or take an ish or two.
  14. Jan 11, 2013 at 6:39 PM
    #54
    Buy1Get1Freee
    Buy1Get1Freee HERP DERP
    PEI
    2001 Tacoma TRD
    Grey Wire Mod, Bilstein 5100s, Eibach Coils! 255/85/16 KM2. DDM HID 35W 6000K, Homemade Rear Bumper, Trail Gear Rock Sliders
    Around 500-530 Kms, too lazy to convert it to miles. :D
    01 AC TRD 4x4 on 255/85/16 KM2s
  15. Jan 11, 2013 at 7:06 PM
    #55
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    I used to get 300 without pushing the needle. But now after the 31's it is just freakin terrible, CURSE these 3.91 gears!!!:mad:
  16. Jan 11, 2013 at 7:31 PM
    #56
    Nunavut
    Nunavut Eh oh, Canada go.
    Canada
    My record is 350 miles. On average I get about 310. This is with a 2003 V6 auto, 4x4.
  17. Jan 11, 2013 at 7:52 PM
    #57
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    150-200 a tank city/wheeling
    190-220 hwy
  18. Jan 11, 2013 at 7:55 PM
    #58
    worthywads
    560 miles on 19.453 for 28.8 mpg.
    5-lugs rock.
  19. Jan 11, 2013 at 8:01 PM
    #59
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    Nice numbers on the winterblend. I've been working a WAI for the last few weeks and I'm not seeing the improvement I was hoping to see. As Madjik says, winterblend sucks!!!
  20. Jan 11, 2013 at 8:08 PM
    #60
    worthywads
    Been waiting for any results you found.
    I haven't bothered to try a grill block, should just try a piece of cardboard and see if I see any warm up difference.
