How many of you have brake pad slap?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by js312, May 22, 2015.
Do you have brake pad slap?
  1. Yes
    124 vote(s)
    79.5%
  2. No
    32 vote(s)
    20.5%
  1. Aug 14, 2017 at 5:15 PM
    #41
    Goldentaco12
    Goldentaco12 Member
    Rob
    2011 4cyl 4x4
    Billet grill, Brembo brakes, plastic dip wheels, 32" tires
    Where do you get the shims???
  2. Aug 14, 2017 at 5:23 PM
    #42
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    If you buy a quality set they come with everything you need.
  3. Aug 14, 2017 at 5:25 PM
    #43
    Goldentaco12
    Goldentaco12 Member
    Rob
    2011 4cyl 4x4
    I bought Brembo pads and rotors. And getting the slap still. They didn't come with the shims
    scottalot likes this.
  4. Aug 14, 2017 at 5:27 PM
    #44
    george3
    New Jersey
    If they don't come with the new pads use the old ones.
  5. Aug 14, 2017 at 5:28 PM
    #45
    Goldentaco12
    Goldentaco12 Member
    Rob
    2011 4cyl 4x4
    Yeh lmao. All good appreciate all the replies. Definitely going to take the pins out and lube them. We shall see
  6. Aug 14, 2017 at 5:28 PM
    #46
    Goldentaco12
    Goldentaco12 Member
    Rob
    2011 4cyl 4x4
    This is where I'm an idiot and I threw them out 3 years ago, didn't have the slap then lol
    Kolter45 likes this.
  7. Aug 14, 2017 at 5:56 PM
    #47
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    My third gen does it. Not gone in the newer gen either.
  8. Sep 1, 2017 at 9:20 AM
    #48
    TacomaArto
    TacomaArto Well-Known Member
    Wisconsin
    2015 White DCSB SR5
    This was an item I had my dealership look at last week. Standard response of "it's completely normal".
    I explained that I have owned a dozen vehicles of all makes and never, ever owned on that made this noise. When I asked how this normal sound is happening on our Ford they said "well, it's a normal Toyota noise".
    I'm not mechanic by any stretch...how could be just a Toyota noise, yet it's a noise coming from a brake system that I have to assume is common across all manufactures?
  9. Sep 1, 2017 at 10:42 AM
    #49
    Kerrigan911
    Kerrigan911 Well-Known Member
    Dan
    05 TRD OR, AC, 4x4, V6
    There is a TSB that basically says to put this special toyota grease on the pad edges and calipers. I just got the grease but havent put it on yet, can update everyone afterwards if interested
    NAAC3TACO and TacomaArto like this.
  10. Sep 1, 2017 at 11:03 AM
    #50
    TacomaArto
    Wisconsin
    2015 White DCSB SR5
    Please do! I know it's "not the end of the world" but when I go to brake and it sounds like 2 metal bars slapping together, I feel like I'm driving a beater. Not a truck I bought new 2 yrs ago.
    NAAC3TACO likes this.
  11. Sep 1, 2017 at 1:01 PM
    #51
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I did a second pad spring on both front calipers. Only slap i have now is from forward to reverse the first time.
    There has to be some slop so the pads can move in and out, pad slap will never fully go away.
  12. Sep 1, 2017 at 1:11 PM
    #52
    Kevmeistah21
    Kevmeistah21 Well-Known Member
    Kevin
    Pasadena, CA
    2015 DCSB TRD SPORT 4x4
    5100/887 LR UCA HS 3-Leaf AAL's SCS Stealth 6's BFG Ko2 285/70/17
    I have it. 15' with the rotors/pads that came off the lot. It didn't starting happening until 35k miles, i have 45k now.
    TacomaArto likes this.
  13. Sep 1, 2017 at 1:20 PM
    #53
    skullver
    skullver Well-Known Member
    Ventura, CA-Carpinteria, CA, La Conchita, CA.
    2006 Tacoma 4wd double cab, short bed, black. 2007 Sequoia SR5 Silver.
    Race calipers do not have anti-rattle clips because it inhibits proper piston retraction to some degree. The only force acting on the pistons causing them to retract when you disengage the pedal is the wound up tension from the piston seals. So the anti-rattle clips will cause a little bit of brake drag, it's all a trade off. The rattle won't hurt anything, in fact, it lets you know your pistons are retracting:). The oem front calipers are actually not a bad unit(Tacoma is opposed piston), most oem vehicles come with a floating caliper which is not nearly as effective, but much less susceptible to knock back due to bearing wear/runout.
  14. Sep 1, 2017 at 2:24 PM
    #54
    TacomaArto
    Wisconsin
    2015 White DCSB SR5
    So you are saying essentially: yes, there's annoying noise....but it's not a big deal because it's actually a better design than silent braking systems?
  15. Sep 1, 2017 at 5:37 PM
    #55
    drop4205
    drop4205 Well-Known Member
    Windham, Maine
    14 TX Baja
    Pioneer 8201 nex Id cxs 6.5 component front Id cs 6.5 rear Jl audio hd 600/4 Jl audio 10” micro sub+ Ram mat Tinted windows Debaged Plasti dip front emble
    Ebc pads i replaced on mine took that noise away. Nonew rotors yet. Have to agree toyota service is terrible. I get better more informative help on these forums and do the work myself
  16. Sep 2, 2017 at 5:32 PM
    #56
    TacomaArto
    Wisconsin
    2015 White DCSB SR5
    How many miles u have on EBC pads now? Just asking cuz pad slap didn't start on my oem pads until 25k miles or so....
  17. Sep 2, 2017 at 5:39 PM
    #57
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I did until I just changed them with new OEM pads.
  18. Sep 3, 2017 at 6:26 AM
    #58
    js312
    js312 [OP] Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    It actually worked for me. The stuff is very different from normal brake grease. It's much thicker.
  19. Sep 3, 2017 at 10:11 AM
    #59
    drop4205
    Windham, Maine
    14 TX Baja
    My pad slap started at 15,000 miles. Toyota service blows. Have 37,000 miles on truck so 22,000 on front pads now with no slap or if there is its not echoing off buildings anymore that I can hear lol. They get a lot dustier than stock but let me tell you they stop a lot better.
    TacomaArto[QUOTED] likes this.
  20. Sep 4, 2017 at 8:11 AM
    #60
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Is there a recording of this noise anywhere on the forum? I also have something i am trying to troubleshoot. Had a few mechanics look at it, not especially in depth, though enough that they suggested it seemed to be more of a nuisance noise than a 'dangerous' one. Still, i really want to figure it out to be sure.
    BillsSR5 likes this.
