how many people just ordered 4 wheels and tires?
Discussion in 'Wheels & Tires' started by udrunk2002, Jul 27, 2020.
  1. Jul 27, 2020 at 12:34 PM
    udrunk2002
    udrunk2002 [OP] Well-Known Member
    I did, mainly b/c of cost. So I have an issue. 2018 OR with factory spare. My TPMS light came on. Went to Pepboys and the tech said my 4 tires are all good...35 psi and sensors all reading. Could not get a read on spare tpms. I thought spares had TPMS sensors. Anyway, it's probably a matter of time until the ECU cant get a read on the 5th sensor and the indicator light comes back on. Has anyone else experienced this and/ or what would you do?
  2. Jul 27, 2020 at 12:42 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    4 for me. I don't even know if a 285 will fit where the spare is stored.
  3. Jul 27, 2020 at 12:49 PM
    udrunk2002
  4. Jul 27, 2020 at 1:04 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I'm thinking 2008 or 2009 was the last year they put sensors in the spares. Unless they started doing it again with 3rd gens.
    The batteries in the sensors typically are good for 8-10 years. I've heard of some going bad sooner, and all 5 are still working after 13 years in my 07. I'm certain they will die soon.
    I wouldn't buy new wheels just because a $15-$25 part goes bad. Next time I need new tires for my Tacoma I'll order new sensors and take them to the tire store. They will install them free when mounting new tires. Otherwise plan to spend $10-20 per tire for them to break down tires and install them.
    Unless you were real unlucky I doubt the sensors are bad on a 2018.
  5. Jul 27, 2020 at 1:06 PM
    Filip38507
    Filip38507 Well-Known Member
    Filip
    Lynnwood Washington
    2019 Tacoma TRD Offroad
    I fit a 34 inch tire in the spare tire spot with a sledge hammer anything is possible lol
  6. Jul 27, 2020 at 1:07 PM
    udrunk2002
    I got 4 new wheels and tires with TPMS...didn't touch the factory spare though. i'll ask in 3rd gen forum if there is a spare tpms
  7. Jul 27, 2020 at 1:09 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I don't get any reading on my 3rd gen spare so I don't think they add them. Although I've never tried adding the tire and re-syncing but I still don't think it has one. After all, it is just a spare.
    udrunk2002[OP] likes this.
  8. Jul 27, 2020 at 1:11 PM
    udrunk2002
    thanks something triggered my tpms indicator. All 4 new tires are good at 35psi and sensors reading good. Only thoughts are spare has something to do with it
  9. Jul 27, 2020 at 1:15 PM
    RedWings44
    Michigan
    My last truck had an issue with the TMPS where the sensors just wouldn't talk to the computer. I decided not to bother with it after every tire shop told me they weren't able to fix it. It wasn't a Toyota, but I imagine TPM systems don't work that differently. A dealership would probably be your best bet.
    Could it be possible you have too much air? I wouldn't think it would matter, but my truck recommends 30 PSI in the tires when cold, but I've also never had an issue when the tires read even 38 psi on the dash during hot days.
  10. Jul 27, 2020 at 1:23 PM
    udrunk2002
    i didn't have any issues with my stock tires. In fact the dealership would always inflate to like 38psi every service for some reason...of course they would heat up to like 41psi when driving. I would air down but same story after each service. anyway, no issues. Now I have 4 new wheels and tires I've got issues. They were working fine for about 3 weeks, went to the mountains and the indicator light came on. I tried researching if altitude would be an issue but apparently not at Shenandoah's 4k altitude.
  11. Jul 27, 2020 at 1:29 PM
    udrunk2002
    I should also add that I couldn't get the tpms to reset using the button or by disconnecting the battery. Which is why I'm trying to troubleshoot this b/c its a p.i.t.a to get a pro to reset the ecu.
  12. Jul 27, 2020 at 2:57 PM
    RedWings44
    Michigan
    This is a long shot, but could there be a compatibility issue between the new sensors and the computer? I wouldn't think they'd be that different.
  13. Jul 30, 2020 at 2:51 PM
    udrunk2002
    You have to goto a tire shop. They need to program the new TPMS ID's into your Tacoma. The truck ECU needs to be programmed with the new sensors.
    Njrx7T2 likes this.
  14. Jul 30, 2020 at 3:40 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    35psi seems high for a Tacoma.
    Island Cruiser likes this.
  15. Aug 1, 2020 at 5:42 AM
    RedWings44
    Michigan
    My door panel suggests 30 when cold, but that doesn't stop the dealership from filling them to 35.
  16. Aug 1, 2020 at 6:11 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    My winter wheels have no sensors I just ignore the light.
  17. Aug 1, 2020 at 8:26 AM
    Maticuno
    2011 Suburban 2500
    There's your problem.
    RedWings44[QUOTED] likes this.
  18. Aug 1, 2020 at 8:31 AM
    loyaltothetaco
    loyaltothetaco It's part ATV, part SUV, and certified by the DMV
    Adam
    Bay Area
    Radiant Red 2006 DCSB SR5
    2.5" OME lift, Fox 2.5 coil overs, all pro expo leafs, ubolt flip kit w/ upgraded bump stops, 1.25" wheel spacers, 16" Bronze KMC Impact OL wheels, 295/75/r16 Nitto grapplers, beige Softopper, Brute force front bumper w/smittybilt winch, RCI rear bumper, caliraised rock sliders, TRD IFS skid plate custom swingout tailgate w/spare tire mount, TC bed stiffeners, Magnum force CAI, KC spotlights, tacomabeast headlights, rear seat molle panel odds and ends, hi lift, MESO interior lights, and a fuck load of patches… more planned for later.
    My buddy has a third gen and he fit a 285/75r16 up under his bed. It was a tight fit but he didn't have to modify anything to make it fit
    Thunder Fist[QUOTED] likes this.
  19. Aug 2, 2020 at 7:06 PM
    udrunk2002
    the door panel sticker psi is usually a less than ideal pressure because the factory value gives a softer, cushier ride. They are less worried about tire longevity.
  20. Aug 3, 2020 at 6:35 PM
    RedWings44
    Michigan
    Not so sure about that. In my last truck, I ran the tires at the PSI the dealership gave me when I bought it (35psi). The tire wear showed they were overinflated and they didn't last very long. Granted, they were winter tires, but still. The recommendation was 30psi and I had much better luck with that.
