How many tires are you buying ?
Discussion in 'Wheels & Tires' started by darktaco, Aug 19, 2012.
  1. Aug 19, 2012 at 2:27 PM
    darktaco
    darktaco [OP] Active Member
    N.E. , Pa...U.S.A.
    08/Sport
    scangauge/c.b.-cobra 29/ BO chrome badges/Demello bolt on sliders/rcbs 4x4 led mod/rear tsb / relocated trailer plug to plate light hole/ Toytec U.L.K./L.R. UCA's/AFE-pro-dry air filter/LEDS -plate,dome,map lites /rear diff breather/ImMrYo's mirror lift/redline hood lift,
    Ready to buy new tires,going up to 265-70-17 .
    Already reasearched the brands ,narrowed it down to two .
    Are you buying 5 ? One of course for the spare .
    I thought you were not to run two different sizes , especially on a limited slip rear .OEM size is 265-65-17 , new size is 265-70-17 . a difference of about 1 inch in diameter.I still have my original Dunlop (hate em )as spare .
    I also have 4 Toy A/T's 265-65-17 mounted for winter/off road use.
    So how many did you buy when you went up a size ?
    Do you care about a spare ?
  2. Aug 19, 2012 at 2:34 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    When I buy tires, I only buy 4. If you off road and have aggressive tires, it might be worth having a full size spare with the same tread to get you home, otherwise, 4 will do. I carry a tire plug kit as I'm more apt to plug the tire than I am to put the spare on.
    With a limited slip rear, if you get a flat in the rear, you'd need to put the spare on the front, and rotate the front tire to the rear. You can't run different sizes across the rear with a mechanical limited slip.
  3. Aug 19, 2012 at 2:42 PM
    Junebug55210
    Junebug55210 2011 TRD Sport 4x4
    Kyle
    Gainesville, FL
    11 DC TRD Sport 4.0
    Cat back magnaflow, toolbox, camo seat covers
    x2
  4. Aug 19, 2012 at 2:44 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    If you get a rear flat, put your spare on the front and move the front tire to the rear..."problem solved, problem staying solved.....rangers lead the way!"
  5. Aug 19, 2012 at 2:46 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    And get a lot of funny looks on the side of the road when people see you changing the front tire with the flat one in the rear :D
  6. Aug 19, 2012 at 3:01 PM
    darktaco
    N.E. , Pa...U.S.A.
    08/Sport
    Thanks all ,especially for the quick replies !!!!!!
    Looks like it 4 for sure . And some money in my pocket .!
  7. Aug 19, 2012 at 3:02 PM
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    I also would troll for when people buy new tires....see if they will give you one of their close to bald ones for a hand shake or nominal fee...;)
  8. Aug 19, 2012 at 3:10 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    +1
    It's always nice to have a similar sized spare.
    Even if it's a different width and profile.... Maybe you can get an 85 series tire with a less aggressive tread that's a lot cheaper but will do the job. That will be my plan when I upgrade my wheels to a lower profile 17"... I still want to go a bit larger on the diameter, so I'll likely move the spare up to a 225/70 or 75 from the stock 215/70-15.
  9. Aug 19, 2012 at 3:19 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I still have the stock spare that came on my Sport. Running 265/75/16 now. When these need replacing I think I'm going to keep one of them for a spare to at least have one the same size, albeit with less tread.
  10. Aug 19, 2012 at 4:51 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    I always buy 5 and rotate the spare in when doing tire rotations to get my money's worth out of it instead of losing the spare to dry rot. Of course, that requires matching rims all the way around.
  11. Aug 20, 2012 at 2:11 PM
    anotherreject
    anotherreject Well-Known Member
    when i upgraded my tire size i went to local used tire place and got a cheap $20 used tire in the new larger size to have a same size spare. it would suck to get a flat on the rear and have to swap one off the front on the side of the road
  12. Aug 20, 2012 at 5:32 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Still running a stock sized spare, but plan on picking up a Treadwright in the proper size to use.
  13. Aug 21, 2012 at 7:20 PM
    darktaco
    N.E. , Pa...U.S.A.
    08/Sport
    ...........for the other ideas. I'll look to the used tire shops for a used tire in 265-70-17 . And a steelie wheel for the spare . At least I'll have a same size tire for replacement , instead of doing the front to back swap .
    Thanks again , tires will be ordered this saturday .Coopers - Discoverer ST/LT - C.
