How many u joints when removing propeller shaft to do carrier bearing replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Avsfreak24, Oct 25, 2016.
  1. Oct 25, 2016 at 1:36 PM
    Avsfreak24
    Avsfreak24 [OP] Member
    San Tan Valley, AZ
    08 TRD Off-Road
    ICON 2.5" extended travel coil-overs with SPC Light Racing UCA's up front, replacement leaf spring lift with Bilstein 5100's in back, Rear E-locker with VIair onboard compressor and ARB front locker, Full Relentless Fab skid plate, welded on rock sliders, baja roof rack, bed rack, bull bar with 20" white/amber light bar, round pods on ditch brackets, and yellow pods on roof rack, 40" light bar on roof rack
  2. Oct 25, 2016 at 1:38 PM
    Avsfreak24
    San Tan Valley, AZ
    08 TRD Off-Road
    Another question and depending on the answer I might need to replace all of them.
    I have the Bilstein 5100 adjust struts up front to fit 33's so their is that angel difference. I do not believe it is an issue as it has been in this configuration for 75K miles and just now, at 227k, is the carrier bearing squealing and causing the intermittent vibration at acceleration and various speeds.
    What are you all's opinions who may have experience with this. Should I look at a shim at the diff?
  3. Oct 25, 2016 at 8:47 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You can't just remove the front half of the drive shaft.
    You will have to remove the entire drive shaft to replace the Carrier Bearing. Then you can also get access to all three universal joints.
    Some Prerunners also have zerk fittings for grease. The only way to know is to look.
    Scrubber3 likes this.
  4. Oct 25, 2016 at 11:01 PM
    Avsfreak24
    San Tan Valley, AZ
    08 TRD Off-Road
    Yeah, I realized I'd read a tutorial on the 1st gen Taco. When I watched the right one I saw I have to take the whole thing out, so I'll just replace all 3 while it's out to replace the carrier bearing.
    Thanks for the heads up
  5. Oct 26, 2016 at 12:27 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  6. Oct 26, 2016 at 12:47 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Is that part described in the first post what is needed for all 3? I ask because I'll be replacing my carrier bearing soon and need to make sure I have all the correct parts before starting work.
