How much does your Tacoma *WEIGH*?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Key-Rei, Oct 22, 2020.
  1. Jan 31, 2025 at 7:26 PM
    #61
    racer_kmk
    racer_kmk Member
    2007 Base Model Double Cab, V6,4x4, 6spd Stick
    I weighed my truck today out of sheer curiosity.
    2007 DCSB 4x4 Base model 6spd.
    Modifications include full sound deadening and subwoofers, which I weighed before installation, at exactly 100lbs, and 265/75R16 BFG Trail-Terrains, which weigh 10 pounds more than the original tires, times 4, so, 40 pounds.
    Still have the spare tire in it. Truck does have a hitch on it, too. Not sure if original.
    No gear inside, just my porky self (230 pounds).
    And a full tank of gas.
    Came out to 4,540 pounds.
    Minus me and my modifications, the original weight of the truck, as it rolled off the assembly line with a full tank of gas, was 4,170 pounds.
    It's definitely possible to get a sub-4,000 pound crew cab Tacoma without much work, if anyone is interested in a "lightweight" build, which I am.
    Just thought I'd share.
  2. Mar 10, 2025 at 7:58 PM
    #62
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    I’m a 3rd gen owner but this 2nd gen thread had more recent activity so I read it, after weighting my 2016 DCSB for the first time. SoftTopper (30#?) full tank of gas (150#?). steel sliders (150#), me inside (maybe 170#) … that uses up a lot of GVWR with no extra tools or gear. 5120 lbs total, 2320 of that on the rear. Mine is TRD OR with sunroof and that big JBL subwoofer.
    Slashaar likes this.
  3. Mar 10, 2025 at 9:28 PM
    #63
    Pigpen
    Dan
    Northwest Montana
    My truck has never weighed less than 6K when I've run it across a scale. Armor, 33" load E tires, etc... but it has also had either the fiberglass topper and all of my forestry and recovery gear, or my slide in camper loaded for elk hunting. I'm adding the 3rd skid plate and a bumper, so she needs to go on a diet. Ditching all of the steel recovery gear, only packing tools for MY truck, putting a tool box in the bed so I fill that, not the entire bed and topper. We'll see what the numbers are next time I roll over the scales.
  4. Mar 10, 2025 at 9:33 PM
    #64
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    4870 lbs. Around 5k loaded for the trails
    Screenshot_20250310_183148_Chrome.jpg Screenshot_20250310_183132_Chrome.jpg Screenshot_20250310_183116_Chrome.jpg Screenshot_20250310_183058_Chrome.jpg
  5. Mar 13, 2025 at 1:48 PM
    #65
    racer_kmk
    racer_kmk Member
    I think this explains the "Taco Lean". Curious to see if anyone else has this issue and can weigh their truck...
    skee likes this.
  6. Mar 14, 2025 at 6:22 AM
    #66
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    The rear side to side was only 20 lbs different. The bigger difference would be the battery up front among other stuff.
    Toyota should've put the battery diagonal from the tank to help offset the weight.
    racer_kmk[QUOTED] likes this.
  7. Mar 14, 2025 at 4:28 PM
    #67
    rockothetaco08
    rockothetaco08 Well-Known Member
    Think my access cab was around 4500lbs with a half tank of gas. including rubber bed mat, with some tools and recovery stuff in the cab too.
    racer_kmk likes this.
  8. Mar 27, 2025 at 2:17 PM
    #68
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    It’s been a few years but it was 5780# with both tanks full, 7 gallons of water, myself and packed for a 3 week trip.
    I’ve removed some things and added some things since then.
    Edit: just realized this is the 2nd gen forum. Oh well.
    racer_kmk, Slashaar and rob1208 like this.
  9. Mar 28, 2025 at 6:06 AM
    #69
    Slashaar
    Josh
    Kansas City, MO
    No worries, this thread became a melting pot of gens.
    racer_kmk and otis24[QUOTED] like this.
  10. May 11, 2025 at 8:10 PM
    #70
    racer_kmk
    racer_kmk Member
    If anyone is interested in a fun experiment with weight reduction... I managed to get my 2007 DCSB V6 4x4 Base model 6spd Tacoma to weigh 4,080 pounds. When I started, I weighed 4,540 pounds. It was just me (230), a rear sway bar (25lbs), a full tank, 265/75/16 BFGoodrich Trail-Terrains (10lbs per tire heavier than stock), and 100lbs worth of sound deadening and subwoofers/amps/box, etc.
    I lost 460 pounds!
    And there was more weight to save, such as the headliner, door panels, etc. It could go under 4,000 pounds if I tried.
    Anyway, here's some weight numbers...
    Spare tire- 55lbs
    Jack+tools- 15lbs
    Rear seats+brackets- 65lbs
    My audio equipment- 55lbs
    Under Rear seat storage box- 5lbs
    Miscellaneous trim+hardware- 5lbs
    Drained washer fluid- 10lbs
    Passenger seat- 50lbs
    Tailgate- 33lbs
    Gas light was on (only 2 gallons of gas)- 110lbs
    Carpet- forgot
    Center console- forgot
    The truck liked it. It would spin when I jammed it in 1st, pulled noticeably harder, and it rode way stiffer in the rear, similar to a heavy-duty truck from the lack of weight in the back. Definitely a fun experiment!
  11. May 13, 2025 at 9:33 AM
    #71
    offroad&ontap
    offroad&ontap Well-Known Member
    Ted
    San Diego, CA
    2015 MGM ACLB 4x4 V6 6MT
    I got my truck weighed in preparation for CA registration last week... it was 4,130 pounds. 2015 Access Cab V6 4x4
  12. May 13, 2025 at 3:24 PM
    #72
    ChaCha
    ChaCha Well-Known Member
    Sandy, UT
    13 DCLB
    Are you the grinning fool (haha-loved those pics!) with the <30k mile Tacoma from Washington? Congrats on that find if you are the same. Sorry for the assumption if you are not.
    I'm at 7300 fully loaded with my fat ass, my wife, 2 boys, the dog, extra fuel/water and a week's worth of food. We have a Habitat, steel bumpers, homemade drawers, etc. Prolly should look at Tacoma weight watchers, but where's the fun in that? haha
  13. May 13, 2025 at 3:29 PM
    #73
    offroad&ontap
    Ted
    San Diego, CA
    haha yes that is me, I am that fool. Still grinning... won't be for long once I see my taxes and registration cost at AAA.
    Sounds like you've got a hell of a ride there. Enjoy.
    ChaCha[QUOTED] likes this.
  14. May 13, 2025 at 3:32 PM
    #74
    ChaCha
    Sandy, UT
    13 DCLB
    Let's see how long you last at "stock." Enjoy your ride!
  15. May 13, 2025 at 3:36 PM
    #75
    offroad&ontap
    Ted
    San Diego, CA
    Haha I'm trying to resist... :facepalm:
  16. Jun 4, 2025 at 5:35 AM
    #76
    Slashaar
    Josh
    Kansas City, MO
    Might as well ditch the whole bed too.
  17. Jun 4, 2025 at 5:45 AM
    #77
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    When I had my 2006 Titan Quad, I weighed it - 5,550 lbs. Easy number to remember.
    I'm shocked that our Taco's weigh in close to that.
