How Much Lift With OME Kit?
Discussion in 'Suspension' started by Sprink21, Mar 15, 2011.
  1. Aug 8, 2011 at 10:46 PM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    first pic is with 885's and billys at 0 the second is when it was just the billys at 2.5. I had talked to toytech earlier today, and they told me to measure from the center of the hub to the fender well. Stock is 20", and obviously 23" would be a 3 inch lift. Just measured outside and it is 22". Does anyone know if maybe I got got some bad springs? Im so confused
  2. Aug 8, 2011 at 10:55 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    maybe you got 884 coils? did you add the top plate?
  3. Aug 8, 2011 at 10:56 PM
    Banff2007Tacoma
    Banff2007Tacoma Well-Known Member
    Dave
    Alberta
    2007 Tacoma Black Sand Pearl TRD Offroad.
    GPS Navigation System, Old Man Emu complete lift with Dakar springs. Light Racing UCA's. BFG AT tires, KMC Enduro rims, Allpro E-locker guard. ARB Portable Air Compressor CKMP12. Backflip Tonneau Cover. Wet Okole seat covers.
    I am interested in getting OME as well so subscribed. Thank you.:popcorn:
  4. Aug 8, 2011 at 10:57 PM
    csjumper2003
    Savannah, GA
    Not yet there on order. I was guaranteed more than 2.5 lift with 885s. How would I know the difference
  5. Aug 8, 2011 at 11:18 PM
    CopDoctor
    08 335i
    yea you should with an AC for sure..the plates are just silver spacers on top of the coil. they don't add much, but for double cabs, it gets you the extra umph to bring you up to 3"
  6. Aug 8, 2011 at 11:35 PM
    csjumper2003
    Savannah, GA
    I know so ifs that's the case I wonder wtf
  7. Aug 9, 2011 at 12:26 AM
    CopDoctor
    08 335i
    is there still a tag on your coils? should be near one of the ends
  8. Aug 9, 2011 at 7:26 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I got exactly 2.5" of lift with 885x springs on my DCLB 4x4 , no top spacer , my centre of hub to fender measurement is 22 1/2"
  9. Aug 11, 2011 at 7:53 AM
    DigB
    DigB Go Jets GO!!!!!!
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    Any need for a diff drop kit with this kind of lift?
  10. Aug 11, 2011 at 8:18 AM
    OZ-T
    Peter North
    British Columbia
    I didn't install the diff drop with mine , from what I've read they don't do much for the 2nd gens
  11. Aug 11, 2011 at 8:56 AM
    csjumper2003
    Savannah, GA
    Rhey change the diff angle quite a bit. And without it it definetely gonna see some major wear on it cv's it a 40 part to save cc axles why wouldn't u
  12. Aug 11, 2011 at 10:26 AM
    OZ-T
    Peter North
    British Columbia
    On the 2nd gen , they only rotate the diff and change the cv angles by a degree or two , tons of threads on this , but like you say , it's a cheap part .
  13. Aug 15, 2011 at 8:34 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    So if you get the 885/884 and billys what do you set the billys at? .85 or 0 thats if you get the 885s 0r 884s
  14. Aug 15, 2011 at 8:45 AM
    OZ-T
    Peter North
    British Columbia
    Some people run either set up , but at 0 will be less stiff because there will be no preload on the spring
  15. Aug 15, 2011 at 9:32 AM
    #35
    Blackshirts
    TX
    Stuff
    How much lift would the 884s give? And how much would the 885s give? If you set the billys at .85? I am thinking of getting new coils?
  16. Aug 15, 2011 at 3:42 PM
    #36
    csjumper2003
    Savannah, GA
    Running stock ucas and ball joints going over 0 on the billies ur truck us gonna ride really ruff. When u set ur prerunner with 885's and billies on 0 ur gonna get close to 3 inches. The little bit off the 3inch u get a 1/4 inch top plate spacer to get rid of the taco lean.
  17. Aug 15, 2011 at 10:03 PM
    #37
    Kougr
    Kougr Active Member
    Antelope, CA
    06 Tacoma DC 4x4 TRD
    5100's w/OME-885s
    After 2 years...5100's set on 0" perch with OME 885s (no spacers or anything)...
    Center Hub to Inside Fender Well
    Driver Front: 22 3/8" Passenger Front: 22 5/8"
    Lift Difference over stock:
    Driver Front: 2 1/4" Passenger Front: 2 1/8" (passenger side was higher at stock to begin with)
    (DC 4x4)
  18. Aug 15, 2011 at 10:49 PM
    #38
    csjumper2003
    Savannah, GA
    I Know that. That is why I returned mine and ordered a eibach adjustable coilover sleeve from toytec. But a prereunner would be fine
  19. Aug 15, 2011 at 10:51 PM
    #39
    OZ-T
    Peter North
    British Columbia
    I got 2 1/2 " up front from the 885x springs and OME Nitrocharger fronts on my DCLB 4x4
  20. Aug 15, 2011 at 11:27 PM
    #40
    csjumper2003
    Savannah, GA
    Better than me
