How much of a task would it be to remove a body lift?!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Honey badger, Jun 25, 2011.
  1. Jun 25, 2011 at 3:07 PM
    Honey badger
    Honey badger [OP] Honey badger hits whatever tree he wants to hit!!
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    So I bought my truck with it on and with my coilovers I really like the look of the 5-6 inch lift. Only thing is I want to get bumpers and sliders all that good stuff you know but do not want a gap in it so thinking about taking it off. Does anyone know how hard this will be or what I will need once it is off? Any help will be good thanks.
  2. Jun 25, 2011 at 3:28 PM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    You are going to need either the stock bolts or shorter ones. And from what my friends have done they lifted the body and pulled the spacers out, I can't find a guide but from my understanding you have to keep the body aligned and your good to go.
  3. Jun 25, 2011 at 3:31 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Cool that should not be hard at all. I will try to get stock bolts. So what about any extenders it may have come with do you know anything about that?
  4. Jun 25, 2011 at 3:34 PM
    Night
    Canada
    Depends what kit it is, do you happen to know what body lift it is?
  5. Jun 25, 2011 at 3:40 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    No I will try to contact the guy I got the truck from and see if he knows.
  6. Jun 25, 2011 at 4:03 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    I think it may be a performance accessories body lift they seem to be the most common.
  7. Jun 25, 2011 at 6:41 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    Parker
    Birmingham, AL
    04 taco 4x4 TRD Debadged
    Shrockworks front bumper Shrockworks sliders Tacoma sport rims painted grey 285/70/17 BFG KM2 AEM cold air intake Grey wire mod Donahoe/Icon coilovers 4crawler 1'' BL CBI cutbed rear bumper Bud-Built skids Inchworm e-locker skid
    If its a 3'' or 2'' then it will probably have radiator brackets you will need to take off. It will also have a steering spacer you need to take off. If thats your truck in the picture with the BL then you will need to take off the front and rear bumper brackets as well as the brackets for the steps I think. I might be wrong, but you can check and see if it has the brackets and if you need to take them off.
  8. Jun 25, 2011 at 6:43 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Yea the steps will go if the BL goes for sure. I have not thought of all that with the other brackets and stuff. May be an aggravating task but think it will be worth it in the end.
  9. Jun 25, 2011 at 6:45 PM
    newskooler
    newskooler Well-Known Member
    Nick
    Lake Shastina,ca
    03 Tacoma x-cab TRD SR5
    881/5100 front, 5100 rear, AAL, K&N intake, Diff breather, grey wire mod, tg Low pro and sliders, Custom tube bumper, pinch weld mod, and more... smoked taillights, fabtech tire carrier, sony headunit, 12v always power mod, #70 unhappy clutch spring mod,
    From prior experience the job isn't too hard but it gets expensive. The factory hardware I had from the previous owner cost him close to 200 bucks plus the the 80-something for new cab bushings from energy suspension but other than that its unbolt, remove and lower slowly.
    i suggest you do the bed first the only thing back there is the bumper and the gas filler neck extensions.
    when doing the cab your have the front bumper brackets, radiator extensions steering extension, and possibly fuel lines to remove/move. be sure to strap your steering wheel to the oh shit handle so when you disconnect the steering wheel so the wheel won't move and you dont snap your clockspring. other than that its not too bad.
    make sure you got plenty of friends to help lift it up
  10. Jun 25, 2011 at 6:49 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Just leave it on dude, how do you plan on fitting those tires without the bl ? Also I believe relentless fab makes brackets to raise the bumper
  11. Jun 25, 2011 at 7:02 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Ok cool if I get around to doing it I will do it slowly to make sure it is done correctly and I figured it would cost a lot.
    I did see that relt. fab. does make a bumper for a Bl and I will go to a 33/10.5 of 11.5 tire if I take it off. The reason I want to take it off is I have seen and read all the stories about them coming off and snapping I do not want that to happen to me at all.
  12. Jun 25, 2011 at 7:58 PM
    Rebel Taco 22
    Parker
    Birmingham, AL
    Do you have 35s?
  13. Jun 25, 2011 at 8:03 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    No they come out to be a 33/12.5/R16
  14. Jun 26, 2011 at 5:24 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    I took a three inch bodylift off my 98, wasn't that bad but was a bit tedious and you need to be careful with brake lines and the steering shaft extender.
  15. Jun 26, 2011 at 10:05 AM
    mcguire
    mcguire Well-Known Member
    andrew
    Rothesay New Brunswick, Canada
    99 tacoma
    sky jacker leaf pack,crappy crap spacers,3"body lift,33" trail diggers,K&N intake,magnaflow muffler and high flow cat.
    Also kind of thinking about removing mine,my bed and cab have alot of movement over even the smallest bumps
  16. Jun 26, 2011 at 10:22 AM
    Rebel Taco 22
    Parker
    Birmingham, AL
    Those tires should be fine. They will rub a little bit when take off the body lift but nothing some minor trimming cant fix.
  17. Jun 26, 2011 at 11:37 AM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Yea when it takes place I will take my time with it all. I want it done right. The kit was put on very well but don't want stuff coming off when I start wheeling hard.
  18. Jun 26, 2011 at 11:38 AM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Yea I will trim if needed def not afraid to hack a lil sheet metal off.
  19. Jun 28, 2011 at 4:04 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    So do you think that taking the BL off will be worth it in the long run or just to much to even worry about?
  20. Jul 3, 2011 at 10:14 AM
    Rebel Taco 22
    Parker
    Birmingham, AL
    I think it would be worth it. Im taking mine off this winter and getting a tube bed.
    The reason i got the BL was so the rear bumper could fit because it was made for a 1'' or 2'' BL. I didnt know that and it was cheaper at the time to go ahead and get the BL. So now im lined up to buy a tube bed, and when i get it, i will take off the BL. I just dont like it and there is an ugly gap between my front bumper and my sliders.
