How much room under the seat? 05+
Discussion in 'Audio & Video' started by Johnson8537, Dec 9, 2007.
  1. Dec 9, 2007 at 8:31 PM
    Johnson8537
    Johnson8537 [OP] Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
  2. Dec 9, 2007 at 9:34 PM
    PatheticJoe
    PatheticJoe Well-Known Member
    Sacramento, CA
    07 Prerunner SR5 TRD Sport - Access Cab
    At 3.375" I don't think it will fit. My 2.25" amp does not have a lot of room and I previously estimated 0.75" was about the most extra I could get. You might be able to return it if it doesn't fit, call Crutchfield and ask.
  3. Mar 8, 2008 at 2:56 PM
    richie822
    richie822 Member
    07 access cab
    so did it end up fitting? just wondering........
  4. Mar 8, 2008 at 5:07 PM
    ZonKs
    ZonKs Can speak french in Russian.
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    thats good news. the one i got is 2 11/16" high so it should fit.
  5. Mar 10, 2008 at 4:58 PM
    Jake
    Jake Member
    2007 Access Cab - Silver
    Bed D-Rings, Speaker Upgrade using TacoTunes Kit, Hitch w/ wire kit, Suspension TRB, More mods in process...
  6. Apr 3, 2008 at 3:14 PM
    Jake
    Jake Member
    It wont fit, not even close. And... It sounds like shit. Just installed one and am taking it out.
  7. Apr 3, 2008 at 3:34 PM
    Big Guns
    Big Guns Well-Known Member
    Temecula, CA
    07 PreRunner SR5 4.0L Indigo Blue
    Aero Turbine 2525 exhaust, Black Headlight Mod, DO Rock Sliders
    Do you think one of those blapunkt combos might fit in the storage under the access cab seats? I saw someone using it to hold all their amps and what not. I would like to add another sub, i just dont want to hack at anything, nor do i want it sitting on the seat.
  8. Apr 3, 2008 at 6:34 PM
    06tacoma
    06tacoma Well-Known Member
    Tampa FL
    06 PreRunner SR5 XS-P Trd Longbed Double Cab
    20" enkei wheel,BFG G-Force tires, BHLM, Smoked tail lights, 2 RE Audio 10s, Quantom 900watt amp,10000K HIDs headlights and fog lamps,Borla exhaust, Borla drop in filter,Debadged tailgate,Painted black tacoma badges
    I was thinking off doing the same thing of putting a sub underneath the seat in the storage but after i thought about it and spoke to a good source air space would be a big issue i would just use it to put amps in if anything
  9. Apr 3, 2008 at 10:42 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    I've got a JVC CS-BB2 installed underneath the driver's seat. Its dimensions are:
    11-5/8"W x 2-1/2"H x 7-7/8"D
    It has plenty of room around it, even the rear floormats clear it by about 1/2" or so.
    I'm no audiophile, and have no idea what "good" sound is, but for a 6", it fills in the lows enough for me until I can decide on a head unit to run the components that I already have.
    Here's a link to one (refurb) for about a hundred bucks:
    http://www.sonicelectronix.com/item_10512_JVC+CS-BB2+Factory+R-B.html
    I hope at least the measurements help.
    EDIT: Check out this link:
    http://www.customtacos.com/forum/showthread.php?t=88678&highlight=access
    Look at Post #3. That seems to be a great compromise for the people that need the seat, but not necessarily the storage.
