How much weight in bed before it is a problem w/ 3-leaf springs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JKD, Dec 5, 2010.
  1. Dec 5, 2010 at 5:42 PM
    mrbadwrench
    mrbadwrench Well-Known Member
    Cleveland Ohio area
    2014 GMC Sierra 4x4, 1988 Mitsubishi J53
    We put 2,000 lbs in ours every now and then, it doesn't quite bottom out on the bump stops just sitting parked, but when you drive it around and over bumps (especially off-road) it does. And you feel it through the whole truck.
    So it depends on what your definition of "a problem" is.
    Keep in mind 2k lbs is well over the factory suggested load limit, and for liability reasons I have to of course say you shouldn't do it.
  2. Dec 5, 2010 at 5:46 PM
    olgzr
    olgzr Well-Known Member
    Denton, Tx
    Before the TSB, I brought home a yard of cedar mulch, approx 700#. The truck bottomed out on a few bumps but not bad. The next trip I had 1 1/2 yards of mulch, just over 1000#. The rear bottomed out frequently on the way home. After the TSB, I've purchased 1 1/2 yards of mulch a couple of times, no bottoming and the truck drove and handled much better with the load than it did before.
  3. Dec 5, 2010 at 5:48 PM
    chugchug
    chugchug Well-Known Member
    Will
    Frederick MD
    2012 Toyota Tundra
    The tailgate must be reinforced. Mine would have broke with one.
  4. Dec 5, 2010 at 5:54 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    :notsure: I don't carry loads very often. Take trash to the recycle center 1 - 2 times a month, go to Lowe's and bring stuff home, but usually not much weight.
  5. Dec 5, 2010 at 5:58 PM
    JKD
    JKD [OP] Well-Known Member
    This is what is puzzling me. I had 300+ pounds in the bed, and had no extreme suspension compression, maybe an inch. Add in me and the other guy loading those appliances, that's about another 450 pounds -- we had 750 pounds in the bed without hitting the bump stops (just sitting there). I know it was compressed a bit then, because it de-compressed when he and I jumped out, but only about an inch.
    I'm having a hard time finding data on rear leaf spring rates for the Tacoma, but some replacement springs are listing 220 to 250 pounds per inch. If true, that means that every 440 to 500 pounds in the bed of the truck should compress the rear suspension one inch (assuming the shocks don't contribute and you don't have a helper leaf or bags). If your truck was on the bump tops with 450 pounds in it, the springs just about had to be broken or from the wrong application.
    If the Tacoma has four inches of rear suspension travel, it shouldn't rest on the bump stops until you have around 2000 pounds in the bed. Obviously it will contact during normal driving with less weight than that, since it is rated at 1400 pounds (+/-).
  6. Dec 5, 2010 at 6:00 PM
    Rbohno
    Rbohno Well-Known Member
    Richard
    Charlotte,NC
    2010 DC TRD OffRoad
    Viper remote start alarm 2.5" Spacer in front, 1.5" spacer in rear, rear TSB performed N-Fab Nerf bars 16" x 8" Vision Warrior wheels 265/75/16 Dura Trac tires
    I have had a pallet and a third of ceramic tile in the bed and hauled it about 15 miles. That was about 2700 lbs, my front tires were barely touching the ground. I was more concerned about popping a rear tire than damaging suspension. I wouldn't reccommend that much weight but had a crew on a jobsite waiting on material.
    TRD Off Road 4 x 4 DC "before" the tsb.
  7. Dec 5, 2010 at 6:00 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Oh. My. God. WHY?!
  8. Dec 5, 2010 at 6:07 PM
    fortyniner
    fortyniner Active Member
    Seattle
    08 tacoma 4x4
    When the snow hit here in Washington I put 6 60lbs bags of sand in the bed to help with traction and I had less then a 1\2 inch of bump stop clearance. The truck bottomed on almost any bump. It must really depend on the luck of the draw when they spring the truck. I took my truck into my dealer and showed them the clearance and the TSB and the service writer said no problem and ordered the parts and said he would call me as soon as they were arrived. 2008 4X4 15,000 miles, I have only had it for three months so hadn't had a chance to carry much weight usually pull a trailer when using it for work.
  9. Dec 5, 2010 at 6:22 PM
    Hogzilla
    Hogzilla Well-Known Member
    Michael
    DFW, Texas
    04 Prerunner sr5
    Oh god thats disgusting...
  10. Dec 5, 2010 at 6:33 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    1000lbs didnt bottom out also have the tsb and toy tec tsb aal
  11. Dec 5, 2010 at 9:16 PM
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    How much?? Not much at all with my cheap ass 3 leaf springs. 6 Ludwig Drums in cases. One anvil
    case, one bass amp and a 60LB stack of Zildjians and BAM! Hit a 1/2" crack in the road and they bottom out. We are only talking about 350 LBS.:mad:
    BTW Toy, thanks for that visual! I have to try to sleep.
  12. Dec 5, 2010 at 9:35 PM
    tsilliker
    tsilliker Well-Known Member
    London, Ontario, Canada
    '05 SR5 V6 4x4 6spd
    Tundra wheels, Access roll-up tonneau, D-rings in front of bed floor, tinted glass in doors to match privacy glass, synthetic oil, Husky floor liners, fog lights, constant power mod for 12v plugs, heated mirrors, brake controller, billet grill, radio aux input mod.
    Is there a parts list for the TSB springs and billies?
  13. Dec 5, 2010 at 10:51 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    ^This
  14. Dec 6, 2010 at 10:17 AM
    sleepdr
    sleepdr Active Member
    ID
    09 DC TRD OR, Black Sand Pearl
    450lb of dumbbells/plates, a weight bench, and a dumbbell rack hauled to the storage unit. I could tell where it hit the bump stops. It's winter, and I run 2-3 60lb sandbags. There is definite sag that I notice disappears when removing them to carry cargo.
    Rear TSB is getting installed tomorrow. The service advisor balked and said they wanted to run a bunch of tests. I explained that I had pics of the amount of weight in the back and the problems - he said, "no problem; you've already done the tests. I'll order the springs."
    I'll be asking Santa for some 5100s for the front... and sliders. A guy can ask, but my wife's had 3 surgeries in 3 months for baby & cancer. Those bills will hit around Christmas. We'll see.
  15. Dec 8, 2010 at 8:54 AM
    #35
    tegdog
    tegdog Taco Lover
    Indiana
    09 Tacoma Dbl TRD Sport
    ventvisors,seatcovers, bug shield,TRD CAI,TRD CAT BACK,blacked out emblems,bed extender, TSB leaf pack,Pro Dry filter, Grill craft upper, lower, & triangles, Hella 500 Black magics
    300-400lbs for me & it rode like shit, 700-800lbs it was down right unsafe IMO, too each his own, I just prefer my truck to be a truck not a mall crawler.
  16. Dec 8, 2010 at 10:07 AM
    #36
    rolltyd
    rolltyd Well-Known Member
    Jay
    Overland Park, Kansas
    2013 Off Road 4x4 Hankook Dynapro ATM
    That made me laugh my ass off. Needed it today... Thanks.
  17. Dec 8, 2010 at 10:10 AM
    #37
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    1200lbs worth of concrete pavers and about the same weight in mulch. Done this a couple of different times, truck rode heavy but handled better than expected, never bottomed out. Did sag in the rear. My truck is a SPORT and less than 4 months old. No TSB, no AAL.
  18. Dec 16, 2010 at 5:38 PM
    #38
    Tacozoid
    Terry
    Katy Texas
    Do miles effect the chance of getting a TSB spring replacement? I have 127,000 on my 06 Taco but it has been bottoming out for years. I just thought it was natural with a load. But 400# ?? I am going to pitch a bitch and hope for the best. My Billy's helped.:D
  19. Dec 16, 2010 at 5:45 PM
    #39
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    About 600lbs on mine before the frame/bumpstop contact during dips and bumps.
  20. Dec 16, 2010 at 11:36 PM
    #40
    bcmedic13
    bcmedic13 Well-Known Member
    Langley, BC
    11 Dbl Cab TRD 4x4 A5
    Canopy, Tailgate Mod, Many more to come
    While towing a tandem trailer with 1100lbs of scrap steel, and approx another 600 lbs in the box, plus myself, yes the headlights where a tad high, no bottoming out, or light steering,
