How normal is idle vibration?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fishbear11, Mar 13, 2017.
  1. Mar 14, 2017 at 1:50 AM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    Sounds like a worn out motor mount(s).
    When the engine is under load it won't vibrate.
    Kolter45 likes this.
  2. Mar 14, 2017 at 5:49 AM
    Fishbear11
    Fishbear11 [OP] Well-Known Member
    Some interesting feedback. A lot of mixed opinions. Other then worn out motor mounts what else should I look for that could be lose or worn out that may cause it. I'll do some looking myself before I have the dealer look again.
  3. Mar 14, 2017 at 5:51 AM
    Fishbear11
    Just seems to make a noise..maybe more of a clicking rather then a chatter. I did look it up and seems toyotas in general have had a problem of that.
  4. Mar 14, 2017 at 5:57 AM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    Try cleaning the throttle body. Possibly some carbon build up behind throttle plate. Check out technical chat for "how to". Easy peasy. No vibrations on my 09.
  5. Mar 14, 2017 at 6:33 AM
    Fishbear11
    Ill give that a shot...probably would be beneficial for the truck even if thats not that culprit. Thanks.
  6. Mar 14, 2017 at 7:15 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Probably the easiest thing to try, and can only benefit your truck either way, is run some fuel injection cleaner (I use Techron) through a fresh tank of gas, and go out, and do an Italian tune up (take it for a spirited ride, and blow out all that carbon build up).
  7. Mar 14, 2017 at 7:46 AM
    Fishbear11
    Haha I like that..Italian tune up
  8. Mar 14, 2017 at 7:54 AM
    Armkb
    09 TRD Sport DCLB
    That certainly will help clean injectors but doesnt do squat for throttle body. No fuel spray thru TB.
  9. Mar 14, 2017 at 8:49 AM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    No shakes on my 05 V6. The one time it did shake it ended up being that the air intake was disconnected :anonymous:
    Hooked it back up and shakes were gone.
  10. Mar 14, 2017 at 11:50 AM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    I dont know if this helps but I found this: https://www.tacomaworld.com/threads/heater-fan-vibrates-on-higher-speeds.212387/ seems he had shit stuck in the fan itself and caused an imbalance in the fan causing a clicking...
    127.0.0.1 likes this.
  11. Mar 14, 2017 at 2:34 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Did you get maintenance records with the truck? I know the V6 requires new plugs every 30k miles (likely some other items too) which, if not done, could cause poor idle. If you don't have it already, get proof that all previous maintenance was done on your rig.
  12. Mar 14, 2017 at 4:33 PM
    Lthompson
    Lthompson Well-Known Member
    Mine 2011 does.. worse in Drive. And vibrates to a drone sound around 2k under load . Felt everywhere. Extremely annoying!
    Lameman157 likes this.
  13. Mar 14, 2017 at 5:33 PM
    Lameman157
    Lameman157 New Member
    2005 Pre-runner
    I have 2005 pre runner and IT just started doing the rough idle in drive at stop light tonight
  14. Mar 14, 2017 at 5:39 PM
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    There should never ever be any vibration in a steering wheel of any car, truck, suv or tank. Well... if you are vibrating in a tank, you are SOL!
  15. Mar 15, 2017 at 6:12 AM
    #35
    Fishbear11
    They were changed somewhere around 30k. Ill check them though, maybe they need to be changed out a little early.
  16. Mar 15, 2017 at 6:15 AM
    #36
    Fishbear11
    One thing I noticed this morning while driving was while stopped there was a slight load on the engine, i assume from the defroster being used and the rpms jumped up very slightly and the vibration went away. When I got home put the truck in park the rpm's increased slightly and it went away.
    Is it possible that it is idleing too low? Probably idels around 550-600 rpm. When put in park and the vibration went away it jumps up to around 700, maybe 750.
  17. Mar 15, 2017 at 6:19 AM
    #37
    Fishbear11
    PapaBear[QUOTED] likes this.
  18. Nov 25, 2019 at 1:00 PM
    #38
    Cconrad
    Cconrad Member
    2019 Tacoma Double Cab Limited
    None
    I just returned from the dealership with mine. They had it for 5 days. Took in for unacceptable vibration/shaking when idling.
    Vibration happens when truck is in gear and stopped, like at long traffic signal. Vibration starts after about 5-8 seconds after stopping
    and gets progressive worst the longer stopped. This happens each and every time while stopped with truck in gear. Does not seem to
    happen when engine is cold. Tacoma has ~1680 miles.
    Was told all Tacoma 3.5 has the vibration, even started up a new one. It did have a slight vibration but not like mine. They are escalating to next level with Toyota. We'll what they say. May have to keep escalating up to President of Toyota.
