How quickly things can go wrong
Discussion in 'Off-Roading & Trails' started by Fightnfire, Dec 29, 2015.
  1. Dec 30, 2015 at 11:11 AM
    la0d0g
    running for the hills
    For crawling not hauling
    I posted this earlier in a different thread but applicable here.
  2. Dec 30, 2015 at 12:15 PM
    Fightnfire
    Fightnfire [OP] Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Aye, those are cool. Great for relatively stock trucks without winches, plate etc.
  3. Dec 30, 2015 at 12:24 PM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    Come alongs work awesome in pulling situations, you can use them as a winch, they also work great to pull one end of the truck sideways, something that can be tricky even with snatch blocks. They should be in everyones off road gear.
  4. Dec 30, 2015 at 12:41 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Agreed. But if you do have a winch, a snatch block is a great thing, not just for off-axis pulls. Double-line pull is also helpful in some scenarios.
  5. Dec 30, 2015 at 2:58 PM
    Nickel
    Diego
    2013 T/X TRD
    For sure a winch is a hugely useful tool!
    I've just been in situations where the winch was useless, or the winch was being used to pull and the Come along was used to stabilize the truck from sliding sideways.
    Sometimes it's so much simpler to use the come along to pull one axle out of the ditch than to try to come up with a snatch block combination that would pull the direction you want.
    EDDO likes this.
  6. Dec 31, 2015 at 12:09 AM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    I carry a length of 2" webbing, usually a tail end from a heavy duty ratchet strap for various reasons. Great around trees, tie a short loop, and run it through a rim and lift a wheel with a hi-lift, good for a soft way to pull a stuck vehicle that doesn't have readily available tow points. The list goes on
  7. Jan 1, 2016 at 1:06 PM
    Fightnfire
    Marysville, WA
    Sad, but like I said.. he wouldn't be found alive... this guy was very experienced:
    http://komonews.com/news/local/resc...-missing-hiker-at-granite-mountain-01-01-2016
  8. Jan 1, 2016 at 6:26 PM
    2big4arunner
    2big4arunner Well-Known Member
    Tyler
    Vernon BC
    2015 tacoma dclb
    3/2 leveling kit, 275/60r20 duratracs on xd128 20x9 rims, AFE stage 2 intake, trd exhaust, duel electric fan w/dakota digital controller
    That is sad. I can't imagine what the other hikers must be going through
  9. Jan 1, 2016 at 10:28 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Nice write up OP. I've "saved" dozens of people from bad situations that resulted from their poor planning. It is a mindset issue more than anything else. They don't properly prepare and they panic when "it" happens.
    On a side note, the Delorme InReach is the best piece of gear anyone who ventures into remote areas can get. $300 and $10 monthly, and you can send text messages from anywhere in the world and can trigger an SOS beacon that will see immediate and competent SAR response.
    EDDO and Fightnfire[OP] like this.
  10. Jan 1, 2016 at 10:30 PM
    Mxpatriot
    Traction boards, such as those sold by MAX TRAX and TREDs, are great. They're quick, easy, and safe. That's really all I use anymore.
    I would not venture offroad without a hi lift, a shovel, a recovery strap(s), and an ax. Now that I have had traction boards for a year, I would include those in the list as well. Those five tools are the fundamental tools of recovery and there aren't many situations you can't get out of with them.
    EDDO likes this.
  11. Jan 3, 2016 at 9:53 AM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    Good story, some buddies and I helped recover a couple people last week that were woefully unprepared for the conditions they were out in. Everyone gets stuck, but not everyone properly prepares.
  12. Jan 3, 2016 at 10:25 AM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    If you have a hitch I'm sure you can use the hi lift on that as well. Also, you could probably have some kind of adapter for the hitch that would catch the hi lift better.
    I'm wondering why you checked the kids pockets? Make sure he didn't have any weapons?
  13. Jan 3, 2016 at 3:19 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    I would do the same. Check for weapons or drug paraphernalia.
  14. Jan 3, 2016 at 5:18 PM
    la0d0g
    Really?! What? Did you want to get high?
  15. Jan 3, 2016 at 6:01 PM
    #35
    Subway4X4
    Lloyd
    NY/NJ
    Speaks to the character of the stranger. If I did see any signs of drug use and I was with my children as the OP described, then I'd leave the stranger in a millisecond and likely help him via a phone call to law enforcement.
    Fightnfire[OP] likes this.
  16. Jan 3, 2016 at 6:06 PM
    #36
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Spent 4hrs this weekend recovering a 1ton dodge which had a rookie driver ad no recovery gear got himself wedged on the frame and front pumpkin on a ice shelf which dropped into a pond crossing which was about halfway up the door. Lucky for him we had the tools to get him out of a bad situation (myself and 2 other trucks) we were prepared for the cold and snow we had a tiger torch and melted the dice away from the truck and cut up some logs to give him some traction. Things go south fast in the snow and ice... because we ended up coming down the mountain in the dark the Trail turned to ice and several times it was steer, pray and aim for the snow bank...
  17. Jan 3, 2016 at 10:51 PM
    #37
    Fightnfire
    Marysville, WA
    In this area there are some rough people. The thing about Washington is you can go from the 12th biggest metropolitan area in the country to the complete, deep wilderness in an hour or less. The people who live on the fringe want to live on the fringe... I'm not saying there's anything wrong with that at all. I respect the rugged lifestyle... but I also know I have a duty to protect my kids and not put myself in a situation that could leave them alone.
    As a FF in this county for years I've dealt with a lot of people in and around the area. Some of the best people in the world, and some shady people. Actually, I armed myself, let him know I was doing so, and then asked him to empty his pockets and then offered to help. I still made him ride in the back of the truck :D
    technolust likes this.
  18. Jan 7, 2016 at 8:53 PM
    #38
    technolust
    technolust Erudite Polymath
    Zack
    Lehigh Valley, PA
    2016 Black Tacoma Off-Road
    315 Maxxis RAZR, SCS F5, Bilstein 8112, Dakar Leafs, Tepui Tent, Leitner Design Rack
    Smart move! Good read.
  19. Jan 27, 2016 at 3:38 PM
    #39
    BradyT88
    BradyT88 Well-Known Member
    A Hi-lift is a great multi-use tool, but a little sketchy in most situations. If you can only afford one tool I think I would pick a hi-lift though.
  20. Oct 2, 2016 at 3:05 PM
    #40
    Fightnfire
    Marysville, WA
    Looking over some old threads of mine and realized we're rolling back into the fun of winter weather off roading time.
    Be careful and be prepared!
    dtaco06 likes this.
