How the f do remove the HU
Discussion in 'Audio & Video' started by NormLC, Mar 12, 2013.
  1. Mar 12, 2013 at 7:39 PM
    NormLC
    NormLC [OP] Member
    San Francisco
    13 TRD OFF ROAD
    Can anyone please help trying to remove hu and can't seem to get it out. Is there some screws or just have to pop it out. 2013 non entune.
  2. Mar 12, 2013 at 11:26 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    there are a ton of threads on this...
    1. Use a slim plastic tool to pop out the 3 control climate panel...
    2. Once the climate controls are out you will look into the base of the radio and see 4 10mm bolts (use a socket wrench w. an extension). Remove those 4 bolts....
    3. Use the plastic trim tool to "pop" the top of the radio forward where it meets the dashboard...
    4. Reach your hand in under the radio between where you just removed the bolts and pop it out by lifting up and towards you...
    5. Disconnect the clipped harnesses from the rear of the radio and the hazard lights..
  3. Mar 13, 2013 at 9:39 AM
    NormLC
    NormLC [OP] Member
    San Francisco
    13 TRD OFF ROAD
    Thank you I will try this later after work.
  4. Mar 13, 2013 at 9:43 AM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
  5. Mar 13, 2013 at 10:56 AM
    TreeFortRichard
    Brian
    maybe he is blind and can't see that video...
  6. Mar 13, 2013 at 11:03 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Welcome to TW,
    if the above posts don't help give me a shout, see I can help you find what you're looking for.
  7. Mar 13, 2013 at 6:53 PM
    NormLC
    NormLC [OP] Member
    San Francisco
    13 TRD OFF ROAD
    Thanks for the link. Saw the video but at the beginning the guy looked like he was going to pull out just about everything. Wasn't to sure if he knew what he was doing.
