How the heck do i get this bed bolt out....or in...or anything!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaPrime, Dec 31, 2011.
  1. Dec 31, 2011 at 5:27 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    If I was just missing one bolt I wouldn't stress over it for the short time it would take to replace it.
  2. Dec 31, 2011 at 5:30 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The bolts are very long there is a lot of thread exposed run it back in then use a thread chaser up the bolt to clear the threads then take it out.
  3. Dec 31, 2011 at 5:47 PM
    TacomaPrime
    TacomaPrime [OP] Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    I can't run it back in. It wont come out or go back in.
  4. Dec 31, 2011 at 5:51 PM
    TacomaPrime
    Gregory
    Illinois
    LOL. Luckily, the bolt im having trouble with is still connecting the bed to the frame.
  5. Dec 31, 2011 at 6:05 PM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    Dry ice might be a last option too. Packed around the visible shank of the bolt. Just a thought. If nothing else works.
  6. Dec 31, 2011 at 6:38 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    If the torx portion is not stripped use a long breaker bar if it is stripped use a pipe wrench.
    You will far exceed the ft lbs of your impact with sheer force.
    As I stated I had the same problem.
    I did drive around for about three days until the new bolt came in at the dealer. No problems with it missing or not tightened.
    They will likely have to order that bolt for you as well.
    The new bolt went in with no problems.
  7. Dec 31, 2011 at 8:15 PM
    Scalded_Dawg
    Scalded_Dawg Not as new as my post count would appear
    Brent
    Yorktown, VA
    Stripped Steel and Sex Appeal
    Tacoma daily and 4Runner to play
    JFlan - I've never taken these bolts out... Are these 'self locking' nuts? If so, then I would agree to anti seize, and no Loc-Tite req'd... otherwise you run the risk of vibrating loose.
    Also, There is nothing better than new parts when appropriate. Chasing the damaged nut with a tap will make it usable sure but it also removes even more of the threads and degrades the integrity of the nut.
    Personal opinion of course but I always replace rather than repair.
  8. Dec 31, 2011 at 8:29 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    I would try the breaker bar to put it back, then soak it some more. I would work it in and out using the breaker bar trying to get it out a little further each time, soaking each time. I have a bad feeling you are going to break the bolt if you try to force it.
  9. Dec 31, 2011 at 9:06 PM
    TacomaPrime
    Gregory
    Illinois
    Good to know. The torx part isn't stripped. Have been very careful to not do that.
    The nut I believe is welded to the frame, or part of a plate that is welded to the frame. Don't quote me on that, but I believe that is the case.
  10. Dec 31, 2011 at 9:36 PM
    TacomaPrime
    Gregory
    Illinois
    damn. Well the torx part is stripped now. Went back out there to try the breaker bar. It turned it about 5-6 total turns, but then the torx part of the head stripped. Can't turn it anymore with that bit. Gonna go at it with my grinder and a pipe wrench tomorrow with my buddy I think. and maybe some heat.
  11. Dec 31, 2011 at 9:50 PM
    Scalded_Dawg
    Brent
    Yorktown, VA
    I found some pics on another thread you posted yesterday... they do appear to be captive or attached to the frame.
  12. Dec 31, 2011 at 10:19 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Try to thread the bolt back into the nut. Then crawl under the truck and take a wire brush to the exposed threads. Another option is cutting off the exposed threads. What is most likely causing this is corrosion on the bolt. The more you turn it, the more of this mess you are pushing into the nut, and the less likely you'll be to reuse the nut.
  13. Dec 31, 2011 at 10:20 PM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    Surprised no one has brought this up but be careful using a pipe wrench or breaker bar. You get much more leverage which if the breaker bar was working is a good sign, but if it binds up again be careful... if it breaks inside the threads you will play hell trying to get it out. Most likely it will be have to drilled out at that point.
    Other than that, try working it back and forth with whatever method you choose. you should be able to get it to back out more and more each time.
    Good luck and keep us posted.
  14. Dec 31, 2011 at 10:54 PM
    jflan
    Vancouver, WA
    Don't let this cascade into a cluster f*ck and melt your bed. :eek:
  15. Dec 31, 2011 at 10:59 PM
    #35
    jflan
    Vancouver, WA
    I believe that they are.
  16. Dec 31, 2011 at 11:15 PM
    #36
    jflan
    Vancouver, WA
    This would be my Plan A for the morning.......
    This is a very good idea. If you can thread the bolt in far enough to see clean threads (under the bed), cut the pig off in the area where the clean threads are.
    A peanut grinder or a Sawzall would be my weapons of choice.
    At this point you're just a few turns from victory.
    With the peanut grinder (4" angle grinder) use a "cut-off" disk. They are those thin ones that are designed for cutting off bolts and misc. steel.
    Make sure that the peanut grinder doesn't walk out and slice up your pretty face.
  17. Jan 1, 2012 at 1:04 AM
    #37
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    If all else fails get yourself a cheapo 1/2 HF socket. Get someone to weld it to the bolt head. Wail on it with breaker bar and a cheater pipe. Work it like a tap (1/2 turn forward - 1/4 turn back or so) though and spray PB every few turns.
    I'd try the pipe wrench first though. Then grinding the sides.
  18. Jan 1, 2012 at 4:07 AM
    #38
    dfxdig
    dfxdig Well-Known Member
    myrtle beach, sc
    06 trd offroad sr5
    k&n intake, custom bed rack
    put a pipe wrench to it, it'll either snap off or come out. if it snaps, drill out the rest of it and use a new nut/bolt.
  19. Jan 1, 2012 at 6:07 AM
    #39
    Large
    Large Red
    Sawzall
  20. Jan 1, 2012 at 8:05 AM
    #40
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I've got a two foot monkey wrench with nasty teeth that would love to bite into that exposed bolt. The long handles give you wicked leverage too. I've used it to overpower lots of stuff in the shop, includin seized-on gun barrels. I'd recommend one to anyone.
