HOW TO: 400W Anytime Mod 3rd Gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kashtyaatsi, Jun 13, 2016.
  1. Jun 16, 2016 at 2:34 AM
    JasonT87
    JasonT87 Well-Known Member
    Southern California
    '16 TRD Sport DCSB
    Total Chaos mid-travel front. JD Fab SUA rear.
    Does the automatic work the same way with the shift knob removal?
  2. Jun 16, 2016 at 5:09 AM
    kashtyaatsi
    kashtyaatsi [OP] DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Yep.
  3. Jun 16, 2016 at 7:15 AM
    neoogeoo
    neoogeoo Well-Known Member
    geo
    2016 mgm taco trd off road
    Billies 5100 ome 885 springs nv wheels w/ duratracs
    The pink wire that you cut what is that for, is it the ground for the shifter allowing you to shift from park to drive when you press on the brake?
  4. Jun 16, 2016 at 7:23 AM
    damnfingers
    damnfingers Well-Known Member
    Gene
    Mississippi
    2016 Limited 2x4 DCSB
    I don't understand the need for this...is it "just because"?
  5. Jun 16, 2016 at 7:39 AM
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    So you can be pushing out 400w while driving. Biggest thing I use it for now is the crock pot. I'll have it plugged in when I go do trails and it's ready by lunch time. Got that from some of the guys I've ran with here. Could also be used to plug in your laptop while driving. Just whatever you want really.
  6. Jun 16, 2016 at 7:41 AM
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Not sure I quite understand your question. From my understanding it's the wire that actually tells your truck it's in park/neutral. So having one end grounded makes the truck think it's always in P/N.
  7. Jun 16, 2016 at 11:38 AM
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
    I can't speak for sure, but it appears to be something that measures continuity. As in, when in park or neutral the signal is grounded, when in a drive gear the signal becomes broken.
  8. Jun 16, 2016 at 2:27 PM
    neoogeoo
    geo
    Ok I understand it it tricks the computer into thinking it's in p, enabling you to use the inverter at 400......right?
  9. Jun 16, 2016 at 3:01 PM
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Yep.
  10. Jun 16, 2016 at 7:07 PM
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
  11. Jul 28, 2016 at 9:17 AM
    RHelton10
    RHelton10 Well-Known Member
    Atlanta, GA
    '16 DCLB MGM TRD Sport 4x4
    Predator bars, Revolver X2 tonneau cover, SwingCase tool box, Husky mats, HID conversion Fuel vapor 17” wheels, 2” front /1” rear lift with Bilstein 5100’s, 285/70R17 Nitto grappler 2’s
    Questions for guys that have done this mod; does grounding the pink wire affect anything else in the truck? I know there is a similar hack that enables you to access menu / navigation functions that are grey'd out when in motion, but the GPS does not update since it does not believe the truck is in motion. You have to switch it back off for the GPS to update. Does the pink wire affect any of this?
    C41n and IphonePirate16 like this.
  12. Jul 28, 2016 at 9:26 AM
    IphonePirate16
    IphonePirate16 Well-Known Member
    2016 Tacoma 0ff-Road
    ^my question also ^
  13. Jul 28, 2016 at 9:31 AM
    Username:
    Username: I wear adult diapers at music festivals.
    CJ
    Pacific USA & Canada
    16 TRDS 6M w/ TRD Humidor
    "She's into malakas, Dino."
    even though i will never have any need for this write-up; i appreciate people like you taking the time to do it.
    imhop,
    you should be recognized and thanked by mods and the admin because this is really valuable content for a auto forum.
  14. Jul 28, 2016 at 10:49 AM
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Nope. Didn't make any difference to the head unit. Would've been nice if it had disabled the gps being grayed out while moving.
    RHelton10[QUOTED] likes this.
  15. Jul 28, 2016 at 7:28 PM
    #35
    DrVonEvilSatan
    Toyota Truck
    Nothing changed on mine either.
  16. Oct 10, 2016 at 5:54 PM
    #36
    GregUte66
    GregUte66 New Member
    Greg
    2017 Tacoma Limited
    Has anyone figured out witch wires to tap for in-cab 110v AC? I tried the ones from the 2nd gen thread and no luck with that pair.
    Thoughts?
  17. Oct 10, 2016 at 6:14 PM
    #37
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    I saw one of the guys did. I believe it was @mr_ash ??
  18. Oct 10, 2016 at 6:19 PM
    #38
    motorsport36
    motorsport36 Black Lights Matter
    Furnace, AZ
    98 SR5 AC 4x4
  19. Oct 10, 2016 at 7:55 PM
    #39
    GregUte66
    Greg
    2017 Tacoma Limited
  20. Feb 4, 2017 at 7:47 AM
    #40
    Greg Hall
    Greg Hall Well-Known Member
    Greg
    Pittsburgh PA
    2016 Tacoma OR
    Thank you. this is great. I quickly learned how the 400w doesn't run while moving during a kayak fishing tournament. Trying to to make coffee on the move and it didn't quite get there. lol. Going to give this one a go this weekend.
