HOW TO: 400W Anytime Mod 3rd Gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kashtyaatsi, Jun 13, 2016.
  1. Mar 1, 2019 at 5:10 PM
    #101
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    Thanks for the reply ....... any additional info / link ? TIA
  2. May 7, 2019 at 8:52 AM
    #102
    Atl-atl
    Atl-atl Well-Known Member
    Phoenix+Flagstaff
    2024 Ram Power Wagon
    Fox, Thuren, 40s, other stuff
    Petition to rename the thread to "anytime the truck is running"
    Just read through this and got excited to do the mod until I came across the fact that its not actually anytime, oh well.
  3. May 7, 2019 at 11:06 AM
    #103
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    The truck engine doesn’t have to be running. Just the key or aux on with the 400W button pushed to on.
    You wouldn’t want 400W with your truck off, especially with an open bed. Someone could use your AC in the bed and drain your battery if that were the case.
  4. May 7, 2019 at 11:19 AM
    #104
    Atl-atl
    Phoenix+Flagstaff
    Yes I do want that. I have a dual battery setup Im working on so Im not concerned about draining the battery, Ill turn it off when Im not with the vehicle and I have a kitchen slide/sleeping platform that fills up the entire bed as well as a locking tailgate so nobody will be getting in there to use the outlet when Im not around. Plus, its switched, they aren't going to use it when you have it switched off. "Anytime" makes me think it would work any time the switch is turned on, not literally all the time. I would like to use the outlet when Im camping for running misc. things like phone chargers, lights etc. without having to go inside the truck and turn the accessory or engine on every time I want to use it.
  5. May 7, 2019 at 11:29 AM
    #105
    Grossomotto
    2017 4WDV6LB6MT
    If you have a dual battery, just run your own setup. Plus you can run solar to an AGM quite affordably.
    02Duck and foodforbears like this.
  6. May 7, 2019 at 11:44 AM
    #106
    Atl-atl
    Phoenix+Flagstaff
    Thank you for continually telling me what to do with my truck but no I dont want to do that. Why call this "anytime" when its not actually anytime? Why reinvent the wheel and wire up my own entire plug when one is already there?
  7. May 7, 2019 at 11:53 AM
    #107
    Grossomotto
    2017 4WDV6LB6MT
    It’s not engineered to run 400w all the time with the truck off, especially with a regular lead acid battery and the thin wiring that runs in and out of the converter.
    That’s why a lot of members run AGM batteries with solar and separate outlets outside the truck. They can be discharged several hundred times.
    I’m not telling you what the do, just suggesting what others have done. Do whatever the hell you want.
    JDKred, C41n, scottalot and 2 others like this.
  8. May 7, 2019 at 12:06 PM
    #108
    Atl-atl
    Phoenix+Flagstaff
    It would not be running 400W to the outlet all the time, only when you turn the switch on. Im not sure why thats so hard for you to understand. The title of the thread literally says 400W anytime yet that is not what this mod does. This mod only allows you to run the outlet when the vehicle is in ignition on or when the vehicle is running, that is not "anytime" so the title is confusing. Stuff gets shit-canned for a lot less around here.
  9. May 7, 2019 at 12:09 PM
    #109
    Grossomotto
    2017 4WDV6LB6MT
    :thumbsup:
    foodforbears likes this.
  10. Jul 7, 2019 at 4:01 AM
    #110
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
    @kashtyaatsi
    My truck comes with a usb power adapter from factory/port option in the back of the center console, what modifications do I need to be able to use the power that's already there?
    Thanks!
  11. Sep 24, 2019 at 10:25 AM
    #111
    Crash_aka_John
    Crash_aka_John Member
    Looking
    What is the benefit of 400w anytime? I mean, what do you plug in while driving that uses over the normal 100w while driving?
  12. Sep 24, 2019 at 10:37 AM
    #112
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Two months on the road with fridge and Goal Zero lithium battery (using mulitport cord) charging while driving. Stock will only power one. When parked or overnight, switching device (my hands) moves fridge and battery input to flexible solar panel on roof of topper.
    cmacblue42 and tonered like this.
  13. Sep 24, 2019 at 5:23 PM
    #113
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Used it to Finish dinner in a crock pot in the back bed on low for a 2 hour drive ;)
    and i have 2 kids so i have a lot of shit plugged in on road trips.
  14. Sep 26, 2019 at 9:10 AM
    #114
    Crash_aka_John
    Looking
    So you run some sort of multi outlet strip out of it? Then just plug in multiple things Into it? I have a goal zero 400 and was wondering if the 100w would be enough to get it charged. Then I started wondering if I could run an outlet strip from it and plug in multiple things. Or if the 400w is needed for that?
  15. Sep 26, 2019 at 9:19 AM
    #115
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Remember that you are talking about wattage on 115V. So, the amp output is really low. 400W at 115V is about 3.5A. 100W at 115V is less than 0.9A.
  16. Sep 26, 2019 at 9:22 AM
    #116
    snickers
    Yes, I have a outlet strip coming out of the truck's inverter outlet. Goal Zero charge controller has 70 watt input limit. My fridge can use up 50+ watts. With stock it is either one or the other. With 400 watt anytime mod it can be both as long as the ignition is on. Two months on the road, no problems.
  17. Sep 26, 2019 at 9:26 AM
    #117
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    Or just take a generator camping. You know. Different strokes. Whatever...
    Grossomotto likes this.
  18. Sep 26, 2019 at 10:03 AM
    #118
    speedracer4
    speedracer4 Well-Known Member
    Troy
    Indiana
    2019 TRD Off Road Tacoma and 4Runner
    I'm going to start taking my Instant Pot everywhere, just pull over and eat some roast.
    Graydog, C41n and tonered like this.
  19. Sep 26, 2019 at 10:21 AM
    #119
    Grossomotto
    2017 4WDV6LB6MT
    The bigger issue is how fast it drains your battery. Most everything is fine when your truck is running. But when you’re sitting at a campsite, I wouldn’t use it, since it’ll quickly drain your battery.
    Be a good American and get a rather loud, carb polluting generator for all of your needs (only during the day).
    Dryfly24 likes this.
  20. Sep 26, 2019 at 10:45 AM
    #120
    snickers
    It's workable with that setup with a solar panel to keep the battery topped off when parked. Just need constant attention switching power sources.
