HOW TO: 400W Anytime Mod 3rd Gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kashtyaatsi, Jun 13, 2016.
  1. Nov 9, 2020 at 6:20 PM
    #141
    Jonnyfive5
    Jonnyfive5 Active Member
    2019 Tacoma 4x4 Trd sport
    *Locate the 12vaccessory port to the rear* Im doing the manual transmission one. I dont have a 12v port mine is usb port. Should I assume its the same instructions for this port as well?
  2. Dec 5, 2020 at 10:37 PM
    #142
    CAtacoWaves
    CAtacoWaves Active Member
    2019 MT DCSB OR
    Rhino Rack Gutter Channels & Rack, Thule Bed Rack (old model mod), Bed Platform,[Switches: Stereo Brightness, NAV Bypass, White Noise Backup Alarm], Interior AC plugs w/400W anytime, Gate King, Bed & Underhood Lights, SPIKER Eng Hood Struts, MICTUNING Tailgate Light Bar, Blinker Genie 2 Mod for side mirrors and side markers. CBI 0deg Rock Rails, Riccochet Al Full Skids, Bed Divider Rear Window Block, Rostra Front Rock Crawl Camera, Rostra Front/Rear Dashcams, [Alarm Upgrades: Glass Break Sensor, and Tilt Sensor, Shock Sensor, Tailgate Sensor with off switches]. Snail Armor Tailgate Insert. Pop&Lock Tailgate Lock. SaBellCo Tailgate Security Lock. Wheeler's OR 1.5" Prog Add-a-leaf with stock Overload spring. TIMBREN Active OR Rear Bump Stops. FOB free key. HitchSafe. TUFFY Lock Boxes in Center Console & Rear Seat. Toyota Wheel and Spare Tire Locks. In progress: Bilstein 5100s & OME 886 coils, Durobumps Front Bumpstops, CBI hidden front hitch, Hitch mounted winch with front and rear wiring, Eco Gapshield, War Fab Inc Sheridan Hitch Skid, Battery Upgrade. Make me stop...
    I figured out a way to add a switch for the 400W anytime mod, so it can run like stock till you need 400W while driving. Or you can always run it at 400W, and turn it back to default when you have a trailer's electric hooked up. Either way, I'm doing this on a manual transmission. There could be a few switch options, but I went this route because it used more commonly available switches and relays, and used a non illuminated switch because this mod technically works when the switch is off, and the stick dash switch gives a status indication.
    A diagram would be better (I'll add one to a later update), but spelled out...use a SPST switch (2 terminal) on the Purple Speed Sensor wire, then use a SPDT relay (5 terminal), using the SPST switch's output Purple wire as the signal wire (terminal 85-downstream ground, and 86 upstream positive), upstream Blue In (from the white harness) goes to terminal 87a, and the Blue Out downstream wire that feeds the inverter goes to terminal 30. Tap the nearby accessory Yellow 12V wire and run it to terminal 87.
    How it works:
    Purple speed sensor runs power when the 400W is to turn off. You can interrupt this signal with the on-off switch.
    The Blue clutch sensor wire is set up stock to lose power when the 400W is to turn off, so when the relay sees that Purple doesn't have power, it connects the Yellow 12V (87) to the Blue out (30), thus keeping Blue energized and maintaining 400W.
    If Purple has power (by a flick of your switch and you start driving), then the relay sees the power and connects Blue In (87a) to Blue Out (30), and the wiring and safety's run with the stock wiring configuration.
    According to other's posts, the 400W/100W dash switch will illuminate to indicate that the 400W is engaged, so you'll know which mode you're in once you start driving or push in the clutch. If it jumps to 100W, just flick your added switch.
    I'm going to do the install in the next few days and will update. It's possible that terminals 87 and 87a might need to be reversed, depending on the relay.
    Parts list from O'really's Autoparts
    Pics of parts
    PNWWanderer and tonered like this.
  3. Dec 6, 2020 at 9:29 AM
    #143
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    ? what :tumbleweed: the 2 have nothing to do with each other.
    There is nothing bad that can happen if it is only on 400W I'v have been running it that way for 4 years now. it will only USE 400W IF it needs it, so if you only have a draw of only150 watts that's all it will pull.
    your not going to burn anything out by having it linked to 400W all the time when it is on.
    sorry but thats a lot of work and a switch to install for 0% gain.
    Maybe i am missing something?:notsure:
    Its a 30 min job or less to do this mod, someone said it took them under 10 min to do?
    save your time for all the other mods you may add.
    really, I'm not trying to be a dick about it, just simplifying things up.
    :santa: :santa2: :santa: :santa2: :santa: :santa2: :santa:
    And welcome to TW
  4. Dec 6, 2020 at 9:48 AM
    #144
    CAtacoWaves
    2019 MT DCSB OR
    I like your thinking better, but I'm still hesitant.
    I'm no electrician, and some people in these threads asked the unanswered question if a switch could be installed. I think I figured out how, so I thought I'd share (and give people a chance to tell me if I'm wrong too). I would think there's got to be some real reason the safety is in place. Best reason I saw was the extra loads from electric hookups when trailering. I figure the safety is in place for only a few rare circumstances that many people wouldn't experience, hence the general success with this mod. So to be safe, this could give the option to run it stock, but still have the benefit to run 400W if you know you don't have a lot of other heavy electric loads running.
    But really, do we have a credible Tacoma insider or sparky that can credibly and definitively explain why Toyota would bother with the extra expense to install this safety in the first place?
  5. Dec 6, 2020 at 1:34 PM
    #145
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    if you are scared or want to be “safe”, then it’s in your best interest just to leave it alone and keep it how it came from the factory...
    jerkwithkeyboard likes this.
  6. Mar 17, 2021 at 4:46 PM
    #146
    ivanza
    ivanza Well-Known Member
    Bay area, CA
    2017 MGM TRD OR MT
    Mobtown skids Fox 2.5 DSC OME heavy leaf
    Is there a way to have this drain an accessories battery? I don't want to add a separate inverter
  7. Apr 13, 2021 at 8:36 PM
    #147
    CAtacoWaves
    2019 MT DCSB OR
    Yea, ended up going with the 400W anytime. The lower power wasn't enough power for my electronics.
    Grossomotto likes this.
  8. May 30, 2021 at 8:12 PM
    #148
    rooney2oons
    rooney2oons Well-Known Member
    Dallas, Tx
    2016 TRD Off Road Silver
    Nothing yet....im a poor bastard.
    This will sound dumb, but what am i doing wrong? I cant get the outlet to come on in ACC only at all. Whats the trick? I even read the damn manual.
    Was going to do this mod, and I dont need it at the moment. But now it may become adding an outlet in the cab instead. Just for fun.
  9. May 31, 2021 at 5:31 AM
    #149
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    The outlet in the bed has no power?
  10. Aug 14, 2021 at 10:33 AM
    #150
    stocktoyotachallenge
    stocktoyotachallenge New Member
    I don't want to move the outlet but only to get the outlet in the bed to stay on while I'm driving.
    I cut the purple speed sensor wire this morning and took it for a drive, no change? The 400W and 100W come on when I am idle, in Park. The 100W will stay on for a few seconds if I turn it on when I am in gear, but turns off nearly immediately when I start moving?
    Is there a way to get the outlet in the bed to work when driving rather than adding a new outlet in the cab?
  11. Oct 11, 2021 at 6:22 PM
    #151
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    Question for those who have done this mod. If you happen to plug in too much current draw, where is the fuse that (hopefully) will pop? Is it one of the fuses under the driver side dash? Or is it one of the fuses under the hood? Or is there a fuse in/on the inverter itself?
    EDIT: No replies in three months... :-(
    EDIT2: no replies in six months... :-( :-(
    EDIT3: no replies in twenty months... :-( :-( :-(
  12. Aug 31, 2022 at 6:25 PM
    #152
    Finanz
    Finanz Well-Known Member
    Sierra
    2021 Pro MGM
    Great tutorial. One of the best mods I've made to my Tacoma
    tonered likes this.
  13. Apr 18, 2023 at 6:49 PM
    #153
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Subbed
  14. Jun 20, 2023 at 1:49 PM
    #154
    moonjack
    moonjack Member
    Rob
    Mesa, AZ
    2017 Tacoma TRD Offroad
    Still a very useful thread tutorial & thread. I didn't need an AC outlet in the cab, but damn it's annoying when the bed outlet kills your fridge power in the middle of a drive.
    My only challenge was that the extra wire I had laying around was either 6 gauge or 22 to ground with. Doubled up the 22 since I wasn't sure if that's what the stock wiring was, or if it was a little thicker.
  15. Aug 29, 2023 at 11:09 AM
    #155
    JDKred
    JDKred Well-Known Member
    JD
    16 MT KDMax Tuned
    Sorry if discussed...
    Has it been confirmed as to what wires to tap for 110V in the cab for a manual transmission?
    I saw two posts with some conflicting info and wanted to verify.
    665.0coupe likes this.
  16. Aug 30, 2023 at 4:59 AM
    #156
    NorrinRadd
    WA
    JDKred[QUOTED] likes this.
  17. Aug 30, 2023 at 5:51 AM
    #157
    JDKred
    JD
    16 MT KDMax Tuned
  18. Aug 30, 2023 at 1:35 PM
    #158
    caribe makaira
    Caribbean, Puerto Rico
    Automatic Transmission
  19. Aug 30, 2023 at 5:00 PM
    #159
    JDKred
    JD
    16 MT KDMax Tuned
    same as manual?
  20. Aug 30, 2023 at 5:02 PM
    #160
    caribe makaira
    For the A/C wires, yes.
