How to: AC outlet in cab + 400 Watt Anytime Mod 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by adriancast, Mar 28, 2014.
  1. Jan 2, 2015 at 10:16 PM
    #221
    Bpassmore8
    Bpassmore8 Brian13DCSB
    Brian
    Vacaville, CA
    2013 Super White TRD Sport
    Debadged, N-Fab step bars, LED cup holder lights, LED dome and map lights, TRD stickers, HID retrofit (Morimoto Mini H1 6.0, BHLM, HomerTaco ghost raptor grill, OME 885s with 90021 up front, 60091 in the rear with trim spacer
    The charger has a positive and negative but no ground. Should I be doing something more? The video is what happens when the charger is hooked up. When it is hooked up there is a faint electrical burning smell so connection wise I assume I have a decent connection as far as that goes
  2. Jan 2, 2015 at 10:40 PM
    #222
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Why would you wire a 12vdc charger to a 120vac outlet?
  3. Jan 2, 2015 at 10:44 PM
    #223
    TacomaG26
    TacomaG26 Well-Known Member
    Nic
    Goldsboro NC
    4.0v6 4x4 TRD Sport
    2.5in spacer leveling kit with Toytech AAL in the rear, Brute Force Fab front and rear bumper, AFE stage2 CAI, Alpine headunit with Rockford Fosgate amp and sub, tibted windows, KC lights.
  4. Jan 2, 2015 at 10:56 PM
    #224
    Greenbergler
    Greenbergler Well-Known Member
    Corey
    Orange County, CA
    2017 trd sport DCLB 4x4
    this. pretty sure that is for dc and thats why there is no ground. dc is only positive and negative. the inverter makes the power from 12vdc to 120vac so you are pumping 120vac into something meant for only 12vdc which is probly overloading that socket which is the burning smell.
  5. Jan 2, 2015 at 11:22 PM
    #225
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    uh, what did you connect that extra 12VDC lighter socket too??
    It definitely should not be connected to the output of the Toyota inverter.
    It should only be connected to a 12VDC source. I gather the thingy you are putting into the auxiliary lighter socket is the USB adapter?
    Burning electrical smells are never good. If in doubt, disconnect what you have done, before you burn your truck up in flames.
  6. Jan 3, 2015 at 4:16 AM
    #226
    Bpassmore8
    Brian
    Vacaville, CA
    I was trying to get something I thought looked cleaner than the regular wall socket but I guess I'll just have to go get one. I'm putting it in the storage compartment behind the drivers rear seat anyways so I won't have to look at it. Thanks guys. I'll let you know if a different socket fixes my problem. If I wanted to wait, this would work since it has a ground right? http://pages.ebay.com/link/?nav=item.view&alt=web&id=361167266164
  7. Jan 3, 2015 at 7:18 AM
    #227
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    12 volt wiring has a + and a - the - IS the ground there is no need to have two. If you have it connected to the inverter output it will smoke any thing you plug into it. The ebay one you listed is a 12 volt device it does not get connected to the inverter output unless you like the smell of burning electrical parts.
  8. Jan 3, 2015 at 7:25 AM
    #228
    el topu
    el topu Well-Known Member
    Juan
    SLC, Ut
    Tundra Limited CM TRD Off-road
    Nice write up!
    I defenetly have to do this too!
  9. Jan 3, 2015 at 9:02 AM
    #229
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    The device shown has two USB ports, one of which provides a charge when connected to 12VDC (red and black wires), the other is used to provide an input to car audio system. It will not provide a charging output unless it is connected to an audio system that does.
    the Regular wall socket folks are adding to the inside of their truck is used to provide 120Volts AC, (like in your house) and that is the only type of socket that is connected to the inverter output. Do not connect the USB socket you described to the inverter output leads.
  10. Jan 3, 2015 at 6:03 PM
    #230
    ThomasDean
    ThomasDean Active Member
    Dean
    Pearland, TX
    2014 Grey Metalic PreRunner
    black leather seats, nerf bars.
    I installed a 600 watt inverter and rigged outlets on both kick panels.
  11. Jan 3, 2015 at 6:10 PM
    #231
    adriancast
    adriancast [OP] Well-Known Member
    Adrian
    Ontario, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Front/RearWheeler Super Bumps -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
    Looks good. Never seen that before.
  12. Jan 3, 2015 at 6:11 PM
    #232
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Cool idea, I'd like to do this for Game or tablet charging etc. without having to take one of the plugs in the front.
    Sub'd.
  13. Jan 3, 2015 at 7:05 PM
    #233
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    Put everything in my Amazon cart. Now just waiting for the heat to be hooked up in my shop so I can do this and a few more projects. Nice write up and great thread!
  14. Jan 3, 2015 at 7:52 PM
    #234
    jguns2002
    jguns2002 Well-Known Member
    Make sure you do the 400W anytime mod while you're in there!!!
  15. Jan 4, 2015 at 10:20 AM
    #235
    Bpassmore8
    Brian
    Vacaville, CA
    Thanks for the answers earlier. I don't know much about wiring, AC or DC which is why I made that stupid mistake which was obvious to everyone else apparently. This is what I ended up doing. I hadn't seen this on this thread so I'm posting it. It is a little more work but i can't deal with looking at non factory looking mods. I only have one kid so it isn't a big deal to fold the seat down to plug her iPad in. If i had 2 kids I may not do it this way
  16. Jan 4, 2015 at 12:51 PM
    #236
    adriancast
    Adrian
    Ontario, Ca
    Better.
  17. Jan 4, 2015 at 12:51 PM
    #237
    adriancast
    Adrian
    Ontario, Ca
    UPDATED OP
  18. Jan 10, 2015 at 9:35 AM
    #238
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    I finally did this yesterday. I spent 10+ hours on this project. 1. I go slow. Real slow. 2. Ran into a hiccup doing the 400 watt anytime mod. I grounded the wrong violet wire and ended up shorting out the starter fuse which caused the truck not to turn over. A internet search led me back to this site where I found a solution to my mistake.
    When doing the 400 watt anytime mod make sure you *ground the connector side violet wire to a ground* not the wire leading back to wiring harness.
    I used a Leviton brand USB/AC outlet. The USB gives 3.6 amps and the AC is 15 amps. 3.6 is more than enough amps to quickly charge just about any USB connected device.
    I found mine at Home Depot but here's a link for one online.
    http://www.leviton.com/OA_HTML/ProductDetail.jsp?partnumber=T5632-E&section=63676&minisite=10251
  19. Jan 10, 2015 at 11:09 AM
    #239
    Greenbergler
    Corey
    Orange County, CA
    You're not going to get the full 15 amps or 3.6 amps from it tho just to let you know. Max you'll get is 3.33
  20. Jan 10, 2015 at 11:11 AM
    #240
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    USB output is 5VDC@3.6Amps available. He'll be able to charge two iPads, or a tablet and a smart phone at the same time.
