How to: AC outlet in cab + 400 Watt Anytime Mod 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by adriancast, Mar 28, 2014.
  1. May 12, 2015 at 6:57 PM
    #341
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    I recorded a video of myself demonstrating that the 400w turns off as soon as I start rolling. Now I just need to figure out how to upload it on imgur
  2. May 22, 2015 at 1:45 PM
    #342
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Video uploaded
  3. Jun 6, 2015 at 2:53 PM
    #343
    rb799
    rb799 Member
    Chesapeake, VA
    '13 Prerunner TRD Offroad
    Ham radio with direct power, Pop 'n Lock 8521, ImYrYo mirror bracket
    I was all set to take on this project, and ran into a snag before starting. Been a long time since I've used the bed outlet and I wanted to test first to ensure it is working properly before I do anything. I press the switch on the dash and nothing happens - If I hold the button, the lights on the switch light, but the switch won't lock on. Any suggestions?
  4. Jun 9, 2015 at 7:38 PM
    #344
    adriancast
    adriancast [OP] Well-Known Member
    Adrian
    Ontario, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Front/RearWheeler Super Bumps -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
    Switch is most likely broken.
  5. Jul 10, 2015 at 6:01 AM
    #345
    DrFunker
    DrFunker Well-Known Member
    Coming at this soon.:rolleyes:
  6. Jul 10, 2015 at 6:42 AM
    #346
    DrFunker
    @Dj Suisav Did you see this thread?
    I know you are done with yours. I found this one too.
  7. Jul 10, 2015 at 6:58 AM
    #347
    Dj Suisav
    Dj Suisav Well-Known Member
    Saul
    San Antonio, TX
    2011 MGM DCSB Trd Sport
    RIP 2009 Super White DCSB Trd Sport
    Just read thru it, its a great mod and super easy only flaw i see is that its still tied in to the power converter so if something goes wrong on the outlet side its gonna hopefully just blow the converters fuse and not damaging the converter itself. that's why i made it a dedicated circuit with an inline fuse! But this is still badass!! kudos
  8. Jul 10, 2015 at 7:12 AM
    #348
    DrFunker
    If I dropped an inline fuse tapping from the converter, would it work?
  9. Jul 10, 2015 at 7:33 AM
    #349
    Dj Suisav
    Saul
    San Antonio, TX
    Yes that would work, but if you blow that fuse, your always gonna have to take apart that center console to get to it.!
    also that wire looks like 18 gauge or 16 which is super thin. and only has an amp rating for 2.3 amps (18) 3.7 amps (16). If you got your usb totaling at 3.1 amps and that 12v socket max is about 10 amps ( i could be wrong). 13.1 amps total, if your using all the outlets at once which i doubt you will. you will be way over the amp rating and could possibly burn up that wire going to the converter.!
    http://www.powerstream.com/Wire_Size.htm
    that's why i would definitely run a dedicated circuit straight to the battery!
    I ran a 12 gauge wire which is a bit much but i had it at home already but only put a 5 amp fuse!
    ERMB likes this.
  10. Jul 10, 2015 at 10:24 AM
    #350
    DrFunker
    See, this is why I said "watch for the flash"
    :laugh:
    Thanks Saul.
    Dj Suisav[QUOTED] likes this.
  11. Jul 10, 2015 at 12:18 PM
    #351
    Dj Suisav
    Saul
    San Antonio, TX
    Hah dude, youll be fine! haha
  12. Jul 18, 2015 at 2:57 PM
    #352
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    Can someone point me towards the wiring diagram or knows how LEDs in the dashboard inverter switch are powered? Im installing a plug out of a Ford and it has a green LED built in. I would like to wire it up too
  13. Jul 20, 2015 at 11:41 AM
    #353
    MotoMoose68
    MotoMoose68 Well-Known Member
    Ed
    Southwestern Colorado
    2014 Tacoma TRD Sport
    Strut Spacer and block lift, w/33" tires on custom wheels.
    Maybe a Scentsy. Just have to take out easy over bumps, so as to not spill the wax.
  14. Jul 20, 2015 at 12:00 PM
    #354
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Anyone?
  15. Jul 20, 2015 at 12:05 PM
    #355
    Dj Suisav
    Saul
    San Antonio, TX
    Whats the back look like? i'm guessing there's 3 wires coming out of it. 12v+ red, a ground (black or green) and maybe another "Power" wire for the led.?
  16. Jul 20, 2015 at 5:40 PM
    #356
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    I am not worried about this outlet. I have the wiring diagram for it. It has 4 pins. 2 for LED and 2 for 110v.
    What I am trying to figure out is if there is some sort of wire for the inverter switch green and amber LEDs or not.
    Just found this old post on FJ forum, and it does look like there is a power indicator wire somewhere. Just need to find it.
  17. Jul 20, 2015 at 8:01 PM
    #357
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    Seek and you shall find.
    Dj Suisav likes this.
  18. Jul 24, 2015 at 12:07 PM
    #358
    Brizzlerice
    Brizzlerice Well-Known Member
    Bryce
    Folsom, California
    2011 Toyota Tacoma
    -Leveling kit -285/75R16 BFG KO2's -AllProOffroad HD Rocksliders -Jumper LEDs all the way around -After market Fog Lights -K&N Cold Air Intake -Quick Fist bed clamp Mod for Shovel and Axe -KENWOOD IN-DASH DVD/Bluetooth/XM Radio/USB Sterio system
    Good Write up! :thumbsup:
  19. Aug 24, 2015 at 7:41 PM
    #359
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    I tried this and had an issue... anyone have any ideas?
    I began the project, ran the wires, spilled a shake in the back seat. I did not know it originally but found out after I started tapping into the wires, but the shake perfectly shot inside the center console grill thing on the back, which left a puddle under the inverter and all over the back mesh area of the inverter, suggesting it probably got some inside.
    I finished up the wiring, turned on the truck, and when in park, when I push the inverter switch, the 100w and 400w lights illuminate for about 5 seconds then turn off. I disconnected the wires from the new outlet and just left them hanging (not touching) and it does the same thing. Did the effing shake short out my inverter?
    The wires I used to extend the stock wires to the outlet are 14awg, stock look like 16awg. I ran out of 14awg for the two power wires, and used two 16awg wires from the outlet to a ground.
    Its dark out and I am starving since the easy project turned into a longer project, so its all apart in the parking lot so I can hopefully troubleshoot it tomorrow morning before work.
    Update, went out to check the fuse (assumed it was fine since the lights on the switch were coming on). It was indeed fine, started the truck just to see and now it works (lights on the switch stay on). The wires are not connected to the outlet so I guess I'll mess with it in the morning and see if it still works and try to connect the outlet again.
    Second update for future issues:
    I reconnected the wiring like I had it last night and it works fine. I am guessing something (wiring/shake) caused it to have an issue last night the first time I fired it up and since I did not restart the truck in between messing with it, the ECU still said no way... thats my only guess. Theres no way that I had the wires on wrong since I triple checked (and also when I took them off during troubleshooting, one had the screw still on it so it went back on the same side).
  20. Sep 3, 2015 at 8:00 AM
    #360
    Justn868
    Justn868 Well-Known Member
    Justin
    Kansas City
    14 4x4 TRD OR
