How to add factory DTRL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toku58, Jun 9, 2009.
  1. Jun 9, 2009 at 11:06 PM
    toku58
    toku58 [OP] Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Here is a DIY for the installation of the factory DTRL.
    Part # 82241-04030 and # 81980-35020 Relay and jumper. You can order it from here: http://www.trdparts4u.com/oem_parts.html
    Here are the tool I used.
    start by removing the rocker panel cover. Just pull up it is held on with clips.
    Then remove the Foot pad; this is also held by clips; just pull:
    There is a small plastic nut which needs to be removed:
    Remove the kick panel by pulling it towards the back it is held on by 2 clips.
    Then remove the 2-10 mm. bolts from the lower panel. Then pull out the little storage tray on the right side. (Just pull straight back) It is held on with clips.
    Then pull the lower panel out. It is held on with the 2-10mm bolts (Which you removed in the previous step) and 3 clips which can be seen in the photo. Remember to remove the wire harnesses and the hood release.
    Now remove the 3-10mm bolts that hold on the fuse box. Remove any wire harnesses that impede you from pulling the fuse box out. For me it was the 3 on the front left & one on the rear top portion. Use a needle nose to remove the clip without damage.
    Now tilt the fuse box outwards and you will see the original relay. A square Tan relay.
    Remove that and the gray plug that is located at the bottom of the rear of the fuse block. Below the flasher relay.
    SORRY! The picture below is kind of confusing because the gray Jumper plug is already in the slot for the flasher!
    Here is a picture of the 2 parts that you need to remove.
    Now you need to assemble the new jumper and the new relay.
    Now plug the gray end of the jumper into the slot where the old relay was located and the white plug into the slot where the gray blank plug was located. (This is how it should look when your done)
    Now clip the new relay on to the holder which is located on the side of the fuse block near the steering:
    And secure the wire with the clip that came on the jumper to the hole located on the back of the fuse block.
    When you are done it should look like it came from the factory that way.
    Now simply revers the process to put your panels back together and you are done!! DTRL work exactly like the factory install!!
    If you have any questions please fell free to ask!!
    Good luck!!
    O.K. Remember that when you test it out, and turn your truck on? You need to release the parking brake for it to come on!
  2. Jun 9, 2009 at 11:18 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Very nice toku!!
  3. Jun 9, 2009 at 11:21 PM
    toku58
    Mall Crawler!
    Thanks! I'm transferring the DIY files I think could help out here. So Sticky any ones you want to keep for the members.
  4. Apr 19, 2012 at 2:20 PM
    TOYOTA 09
    TOYOTA 09 Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    the pic links have all been disabled....can anyone point me out a DIY to mod a 2009 to have DTRL?
  5. May 22, 2012 at 5:01 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
