How to bypass traction control without factory switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NateMulls11, Oct 29, 2017.
  1. Oct 29, 2017 at 2:35 AM
    NateMulls11
    NateMulls11 [OP] Member
    2005 Blue Tacoma TRD Offroad
    Can I put in a toggle switch in to bypass my traction control because my truck didn't come with a factory switch to allow me to turn off my traction control? It's really upsetting when I go to break it loose and it comes on... no fun!! :(
  2. Oct 29, 2017 at 3:20 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you sure you even have it? I have a 2005 as well and don't have any traction control. The only difference is that I have an SR5 vs your trd offroad, so that may be the case.
  3. Oct 29, 2017 at 5:49 AM
    Ncskeeter
    Ncskeeter Well-Known Member
    North Carolina
    2005 Silver Tacoma Prerunner DCSB SR5
    Mostly stock
    No traction control in 2005 other than the mechanical LSD in the TRD sports.
  4. Oct 29, 2017 at 10:29 AM
    NateMulls11
    If I'm on a slick road when I go to break the tires loose it stops me and only allows it to move without spinning them. It turns off when I put it in 4wd. Maybe I could trick the ecu to think it's in 4wd so it could turn it off?
  5. Oct 29, 2017 at 11:55 AM
    Ncskeeter
    North Carolina
    Mostly stock
    Are you braking while on the throttle?
  6. Oct 29, 2017 at 1:14 PM
    NateMulls11
  7. Oct 29, 2017 at 3:11 PM
    Ncskeeter
    North Carolina
    Mostly stock
    There was an ECU flash that doesn't let you give both throttle and brake at the same time. It was part of the toyota sudden acceleration recall ( in addition to the gas pedal neutering and the dealer trying to steal door mats).
    I don't know what else would cause what you're describing, unless you're hitting the engine rev limiter.
  8. Oct 29, 2017 at 3:38 PM
    Ncskeeter
    North Carolina
    Mostly stock
  9. Oct 29, 2017 at 4:17 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Abs kill switch. There are write ups for trd and non trd models in the cheap free mods thread
  10. Oct 29, 2017 at 4:57 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Learned something new today. I didnt know they offered a neuter package that far back. So glad i didnt get stuck with that crap.
  11. Oct 29, 2017 at 5:20 PM
    Pigpen
    Dan
    Northwest Montana
    This is the answer
  12. Oct 29, 2017 at 6:18 PM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
  13. Oct 30, 2017 at 9:25 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I had a 2005 TRD Off Road 4WD and it did not have any electronic traction limited slip system. It had ABS brakes and the rear locker.
    However, when I traded it for this 2010 model with the traction controls, the truck off road was BETTER by a long ways. Limiting slip (TRAC and after 2012: TRAC OFF) in 4WD keeps you moving instead of power being wasted on the easiest to spin tires.
    There was some use of TRAC in pre-2009 Tacomas, you should have a button and a dash light for it, I would think? It works in H2 and H4, so your going into H4 wouldn't kill it, as you describe. Your traction doubles and that may be the improvement you are experiencing?
