How to Change a CV Axle on an 01-04 ADD Tacoma
Discussion in 'Technical Chat' started by JimBeam, Dec 15, 2008.
  1. Dec 15, 2008 at 9:39 PM
    JimBeam
    JimBeam [OP] BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Here’s my little writeup on how to change a CV axle on a 01-04 ADD Tacoma
    Tools required:
    36mm Socket
    Breaker bar or Air-gun
    Small chisel or sharp strong screwdriver
    Rubber mallet
    Metric socket set
    Jack
    Jackstands
    Small or needlenose pliers
    Step 1
    Jack up the front side of the truck where you’ll be changing the axle. Be sure to NOT jack on the control arm as you’ll need that to have a smidge of play in it later
    Step 2
    Remove tire/wheel/skid plate
    Trust me on the skidplate – ESPECIALLY if you have aftermarket skids
    Usually I like to place the tire underneath the front of the truck so that God-forbid the jack/jackstands fail the truck doesn’t crash completely to earth. I chose NOT to do this during this axle change. I also did not use jackstands as I was unable to locate mine. I did however use 2 jacks for that just-in-case factor
    Step 3
    Once you’ve removed the wheel, you’ll see a black metal cap at the center of the hub
    You’ll want to remove this carefully so as not to booger up the edge too badly because we’re going to reuse this. The best way to remove it is with a chisel or sharp screwdriver. I used a small chisel and a rubber mallet and it popped right off
    Step 4
    Once you’ve removed the black dust cap from the hub assembly, you’ll see a large nut and a cotter pit and quite possibly a cotter pin lock? Im actually not sure what you call it but it’s the green thing in my picture
    Remove the cotter pin and cotter pin lock and then using a 36mm socket and a breaker bar or air gun (what I prefer) remove the large nut. This can get a bit tricky as the hub will want to spin while you unscrew the nut. It’s handy to have a 2nd pair of hands to help you but I wasn’t so fortunate today. I angled a screwdriver between 2 of the studs and braced the hub from spinning while removing the nut with the air gun.
    Step 5
    Once you’ve removed the cotter pin and nut, move around to the backside of the hub assembly and disconnect the 4 screws holding the spindle to the lower ball joint. There are 2 at the front and 2 at the back. IIRC this is a 12mm socket.
    In my picture, I’ve already removed the bolts but the arrows are pointing to where they were.
    Step 6
    Pull the spindle out and separate it from the cv axle. It should slide out fairly easily but you may have to bump it slightly to get it to separate. Swing the spindle around to the backside towards the cab of the truck.
    Step 7
    Remove CV from diff. This is probably the most difficult and time consuming part of the change. You’ll need a prybar (preferably a skinny one). There is a lip on the CV next to the diff that you can use to pop the CV out. Use the prybar to pop the CV loose. You’ll know when it pops free. It’s held in there by a little c-ring around the end of the axle (denoted by the GREEN arrow in the picture below, with the lip marked with RED arrow).
    Now that you’ve successfully pried the CV out of the diff, you’ll probably lose a little bit of gear oil…no biggie…it shouldn’t be that much. If you lose a lot be sure to add some.
    Step 8
    Now you’re ready to slide the new CV in. This can also be tricky because you have to line up the splines, but just keep trying and turning it till it slides part of the way in. It will more than likely stop before going all the way in. Using the prybar and rubber mallet, gently tap it all the way into the diff. The c-ring will lock it in once it gets in there good.
    Step 9
    Bring the spindle/hub assembly back around to where it should be and push the end of the CV thru it. Once again be sure to line up the splines as you don’t want to booger those up in any way. This should slide most of the way thru with no problems.
    Step 10
    Button up the spindle to the lower ball joint/control arm with the 4 bolts you removed previously
    Step 11
    Put the large nut onto the CV axle and tighten down. Place cotter pin lock onto the CV axle and then push cotter pin thru the hole to finish locking the CV in. Check the backside of the hub where the CV joint meets the hub to make sure it’s seated properly. There’s a gasket and lip there that should meet flush with the hub assembly.
    Step 12
    Using the rubber mallet, gently tap the dust cap back into place. Replace skid plates, tire/wheel. Lower jacks. Recheck lugs on the wheel. Take her for a test drive!
    [FONT=&quot]That’s it. Pretty easy DIY. It took me about 2 hours including gathering my tools and putting them away.[/FONT]
  2. Dec 15, 2008 at 10:57 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You really should put that in an HTML format. I wish I had time, or else I'd do it for you. Nice write-up!
  3. Dec 15, 2008 at 10:59 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Nice write-up Tiger!!!
    Sticky maybe?
  4. Dec 15, 2008 at 11:33 PM
    Tacoma02TRD
    Tacoma02TRD Well-Known Member
    Walla Walla WA/ Klamath Falls OR
    02 Tacoma TRD
    3inch Revtech lift,Flowmaster Muffler, K&N cold air intake, 33x12.5 Maxxis Bighorns, TRD stock locker, Hella 500 Fog lights, Scanguage II, 6k HIDs, Painted Black Rims
    Great write up. I too think it should be a sticky
  5. Dec 16, 2008 at 6:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Good job, Copper!!!!
  6. Dec 16, 2008 at 6:24 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Sweet write up! time to go tear shit up again!
  7. Dec 16, 2008 at 10:20 AM
    JimBeam
    JB
    2015 Tundra
    what do you mean? i dont have a webpage or anything so i have no use of it being in html format
    thanks guys
    thanks...tho i have a strange issue now...the spare cv i got from a guy who cut out all his IFS and it came out of i think an 03 tacoma...anyways...the boot closest to the tire has one more rib than the stock one and previously i had no ribs touching but now i do...i tried to take my busted one to autozone but they no longer do core swaps as they claim their new cvs are all core-less
    not until i get some more money, time and the issue i just described with chris sorted out
    oh and now my driver's side is leaking grease from the inner boot :rolleyes::mad:
  8. Dec 16, 2008 at 10:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Interesting. Maybe the guy that had the shaft before replaced only the boot, but with a different one? In the past, I have heard about people useing a "spiral" type boot. Maybe you could find one of them. they are supposed to eliminate any rubbing of fins altogether.
  9. Dec 16, 2008 at 10:30 AM
    JimBeam
    JB
    2015 Tundra
    im just gonna say screw it for now and run this one till it starts popping...i only paid $50 for it...i'll keep my eyes open for another couple from a SAC on ttora...cheaper than the $125 autozone core-less special right...tho many people have said that the aftermarket ones like autozone or a place like that are stronger than OEM ones and typically last longer...
  10. Dec 16, 2008 at 10:34 AM
    JVTACOMA
    JVTACOMA Well-Known Member
    York, Pa
    nice write up... and well done!!!
    the only thing i would add is to use lock-tite to the 4 bolts in step 10. i had those bolts get loose on me before.
    i wish i had to time to do those kind of write-ups but i'm usually always in a rush to get my junk back together!!!
    agian, nice work!!!
  11. Dec 16, 2008 at 10:43 AM
    JimBeam
    JB
    2015 Tundra
    you're right...a drop of locktite would be a good idea...because those falling out will be a VERY bad day...but i dont have any and i just cranked down on them good and i'l check them in a couple days
  12. Dec 16, 2008 at 11:27 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Ditto on the nice writeup! Since I put on my lift, I've wondered how one would go about changing them...
    Couple of questions:
    1. How different is this from the '05+ (anyone)?
    2. How much is a set of CV axles (in case I want to keep an extra pair on hand)?
  13. Dec 16, 2008 at 11:35 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Here's a question. Without the extra hands to help you keep from axles/hubs from spinning, could you (if you had 4wheel drive) put the truck in 4wheel drive and keep that axle from spinning if you had only one wheel up in the air and the opposite on the ground? I know there is a locker question here somewhere.
    Just wanted to contribute....
  14. Dec 16, 2008 at 11:46 AM
    JimBeam
    JB
    2015 Tundra
    i would assume that its a very similar setup...but ive never actually looked...
    new CVs from autozone for my truck are $125/per side so $250 for 2 of them...i buy them used from someone whos putting a solid axle under their truck and no longer need the CVs
    i dont know how good of an idea that is honestly...
    when i was doing it...i found if you angled a screwdriver between the wheel studs against the spin you could get enough opposite force to break the nut loose enough to undo by hand the rest of the way
  15. Dec 16, 2008 at 12:43 PM
    JimBeam
    JB
    2015 Tundra
    good point...but when income and availability of funds is a factor...a used $50 cv is much more appealing than a $125 one
  16. Dec 16, 2008 at 2:15 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    awesome write up Jeff!!! definitely should be "stuck":D.
  17. Dec 16, 2008 at 2:17 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    good to hear they are lifetime...........i may need to replace mine pretty soon, if the dealership doesnt cover them under warranty. they arent in bad shape per say........but the boots are dry rotted, not all the way, but pretty close.
  18. Jan 13, 2011 at 4:37 PM
    ywen
    ywen Well-Known Member
    I'm afraid of damaging the diff seal when popping out the CV. Is this possible? Also how critical is it to tighten down all the bolts to spec. Do we know what the spec torque is?
  19. Jan 14, 2011 at 5:33 AM
    JimBeam
    JB
    2015 Tundra
    at your own risk of course
    i dont use a torque wrench...dont even own one...just sayin
    and i dont think i've damaged my diff seal...and ive changed CVs several times
  20. Jan 14, 2011 at 7:42 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    I think the only time you have to worry about messing up the diff seal, is when you are reinstalling the axle. You just have to take your time and go easy.
