How to Change a CV Axle on an 01-04 ADD Tacoma
Discussion in 'Technical Chat' started by JimBeam, Dec 15, 2008.
  1. Apr 14, 2012 at 9:48 PM
    #41
    JimBeam
    JimBeam [OP] BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    My sway bar was non existent when I did this write up
  2. Apr 15, 2012 at 10:30 AM
    #42
    BigSurTaco
    BigSurTaco Member
    Torre
    Big Sur, CA
    03 sr5 4cyl 4x4 2" lift
    K&N, 2" suspension lift
    Yeah, I realized that after i wrote the previous post. Might be something good to mention for the newbies like me. Thanks for the write up though. I really appreciate all the pics.
  3. Aug 2, 2012 at 7:47 PM
    #43
    starsandbars
    starsandbars Member
    Dan
    Va Beach
    black beast lifted and slow
    6 inch fabtech sus lift. 3 inch bod lift. 16 mickey wheels and 365-65-16s. Cb Radio. all else is toyota.
    so i replaced mine i have a few issues you cans see in my on going post "Please help no 4X4", but i didnt take out my sway bar. just removed the 4 bolts on the bottom.
  4. Mar 14, 2013 at 8:19 PM
    #44
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Thanks for the clear write up! But i should have paid more attention to Step 8:
    "Now you’re ready to slide the new CV in. This can also be tricky because you have to line up the splines, but just keep trying and turning it till it slides part of the way in. It will more than likely stop before going all the way in. Using the prybar and rubber mallet, gently tap it all the way into the diff. The c-ring will lock it in once it gets in there good."
    Took me a about 10 minutes of getting frustrated before i went back inside and re-read it :)
    Pro-tip, O'Rielly Auto loaned me a 36mm socket for a $10 deposit.
  5. May 4, 2013 at 2:24 PM
    #45
    01GREENTACO
    01GREENTACO Not all who wander are lost
    Germantown, TN
    01 4WD
    Lost track many, many mods ago.
    Thanks for the write up! I followed and got the job done in no time. (about 1 hr total and I replaced both sides) :thumbsup:
  6. May 21, 2013 at 3:53 PM
    #46
    kbauman92
    kbauman92 Well-Known Member
    Kyle
    North Bend
    98 tacoma ext cab
    King 2.5x6 RR coilovers eibach coils Light Racing UCA Spidertrax spacers Fiberwerx fenders
    Just did this today thanks for the write up, took me probably 4 hours total but half the time was looking for a thin enough screw driver to get the dust cover off and had to go buy a 36mm socket for 11$ from napa
  7. Jun 6, 2013 at 8:28 PM
    #47
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2003 Tacoma Dbl Cab 4X4
    Quick question.
    I had my inner boot on the drivers side replaced recently (yes, I was going to attempt the repair but chickened out) & have a slight vibration up front now. (Yes, thats what I get!) Anyways, the guy replaced the inner boot only & being it was torn for only about a week, the cv was fine. I'm not sure if it's the tires needing balancing (which I'm doing tomorrow) or just due to the cv repair that was done. The tires are new & have about 6000 miles on them, so it's probably time for balancing anyways.
    So my question is, is an alignment needed after cv joints are done?
    Thanks guys
  8. Jun 6, 2013 at 9:28 PM
    #48
    kbauman92
    Kyle
    North Bend
    98 tacoma ext cab
    you shouldnt need one, i just did mine and didnt get a alignment and no vibes, but i do have a leaky seal on the passenger side i picked up both inner and outer seals? i didnt know which one to get so i got both
  9. Jun 6, 2013 at 9:56 PM
    #49
    monoman
    Dave
    Ok cool. I'm going to get the tires balanced tomorrow & well see how it rides afterward. Hope that does the trick. The guy at the tire store said it's a good idea to have them balanced at least once a year. It doesn't cost anything anyways.
  10. Jun 7, 2013 at 11:38 AM
    #50
    monoman
    Dave
    **update on the vibration.
    So I took my truck in to get the wheels balenced & had them check the front end alignment. It was off, especially the left side so I had them align it. Drives real nice now! I'm happy again
  11. Jun 8, 2013 at 9:41 AM
    #51
    cabinguy
    cabinguy New Member
    Rich
    Lincoln Vt
    Tacoma w/plow and tow set up
    plow, tow package, 600 over front spings, air shocks.
    I took out the lower shock bolt and moved the shock out of the way, easier to get axle out, won't tear the new boots going in. Other than that, a great write up!
  12. Jun 10, 2013 at 4:20 PM
    #52
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    I changed out both cv axles yesterday and now my driver side is leakin gear oil where the axle and differential meet. Is that from improper installation? Or some seal? It was not leakin before
  13. Jun 10, 2013 at 7:20 PM
    #53
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the seal probably got torn during cv install. they are super soft.
  14. Jun 10, 2013 at 8:18 PM
    #54
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Yeah that's what I figured. It's goin in the shop tomorrow to get that fixed and the tie rods. I wish I had more time before the Georgia meet to do it myself
  15. Jun 24, 2013 at 8:16 PM
    #55
    dirtduster
    dirtduster New Member
    Dusty
    S.L.C. Utah
    04 tacoma
    leveling kit
    watched your wright up. pretty good . I think I can handle that. I have 1 cv boot torn , I was going to change both side unless somebody says no just change one.
  16. Aug 13, 2013 at 8:33 PM
    #56
    FTB530
    FTB530 Well-Known Member
    Yuba City Ca.
    2005 toyota tacoma
    level kit,air raid intake,
    Lookin for info.... I just noticed the front driver side boot is cut and oil is leaking out of it ... Not bad enough it is leaking on the ground... Here is my delima ... I am up in the mountains and two hours from home... Is it sFe to drive it home to do the repair or should i go to the nearest dealer or have it towed v??? I am o a cell phone and not sure if this is the right place to ask but i couldnt figure out how to start a new thread ... Thanks for any advice any one can give me!!
  17. Aug 14, 2013 at 7:29 AM
    #57
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    You should be fine, as long as do not any deep water crossings.
  18. Nov 10, 2013 at 11:10 AM
    #58
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    Valve Caps, 2 stickers, bent radio antenna.
    good write up, mine used a 35mm socket though? weird.
  19. Jan 5, 2014 at 5:54 PM
    #59
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Nice write up Jeff, I'll save it for later use.
    Are your coil overs installed upside down? All of the ones I've seen the threads are at the top.
  20. Apr 25, 2014 at 12:48 PM
    #60
    Jkohler
    Jkohler HUH?
    Justin
    UT
    02 4DR Taco TDR Supercharged SR5 6in lift
    12" Icon 2.5 coilovers, 6" Drop Bracket, Tuff Country 5" lift knuckles, Icon 4''-8'' Extended Coilovers, Light Racing upper control arms, 7" Alcan leafs, 13" icon 2.0 smooth bodies in the rear. 2.5" exhaust with Magnaflow cats and Thrush muffler. 295x75x16 AT's (34.4") Superchargers Other shit like rear breather mod relocate, gray wire mod, intake elbow removed, led's, toolbox, etc
    Is it possible to pop the cv out of the snap lock on the inner cv? The black inner section of my cv had a lot of up and down movement since my Moab expedition. The wheel was off the ground a few times. I can feel and hear slight play in the cv at slow speeds.
