How to Change Front Brakes (Pads and Rotors)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LoadedTaco, Nov 24, 2014.
  1. Feb 26, 2019 at 4:22 AM
    #261
    nivek5sfe
    nivek5sfe Well-Known Member
    Marietta, GA
    05 DCLB 4x4
    How did they manage that? They put all new lines from the ABS to the wheels on mine so Im sure they had to replace the fluid. I know brake fluid was listed on the frame replacement invoice also. Im about to do my front brakes and didnt plan on flushing/bleeding since i just had the frame replaced 2 months ago.
  2. Feb 26, 2019 at 11:04 AM
    #262
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    eherlihy[QUOTED] likes this.
  3. Mar 2, 2019 at 12:23 AM
    #263
    tmr
    tmr Well-Known Member
    Tom
    Vancouver
    2012 Black Tacoma TRD
    Followed this guide and swapped out from front brake pads tonight, first time doing the brakes on my Tacoma since I have owned it. May have waited a little long and as mentioned it in the video the bottom guide pins on both sides were pretty tough to get out. Stupid me, I ordered the Carlson Guide Pins on Amazon and didn't read the fine print so by ordering 1 set only two pins showed up. I elected to throw the new pins in the bottoms on both side and picked the best two old pins for the tops.
    Thanks again LoadedTaco, you saved me a bunch of time and money!
    LoadedTaco[OP] likes this.
  4. Mar 15, 2019 at 8:47 PM
    #264
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Sticky piston(s) symptoms keeps coming up just about every other day so here is the summary of what happens if calipers are not maintained:
    1. Piston(s) begin to stick. This eventually causes unlevel pads, and non-uniform wear between the inner and out pads.
    2. Unlevel/non-uniform pads begin wearing a non-uniform track into the rotor. During light braking, this causes steering shake and front end wobble. During very slow rolling, you can feel the specific pulses of the pad(s) going out of their groove and back in again.
    3. In addition to a non-uniform track groove, one side of the rotor will wear faster than the other side, also contributing to steering shake.
    If you can get at least 80k miles out of the first set of brakes, I recommend also rebuilding the brake caliper seals with the $20 OEM rebuild kit (Toyota part number 04478 04050 for Tacoma 4x4 V6 models) to avoid developing sticky/slow pistons. Which also means flushing the front fluid lines (ideally you would do all 4 corners anyway after 80k anyway). Typical symptoms that develops a few months after that first-brake job is the front end will shake and wobble during light braking, and sometimes cause the steering wheel to shake when braking at highway speeds. During firm/hard braking (which we only get to do 5% of the time), there is no wobble/shake since there is more fluid pressure pushing the piston out and evenly apply force against the pads. I had the inner pads wearing faster than the outer pads, and I had uneven wear on the inner pads (so the pad material was slightly unlevel). The sticky pistons are a bitch to get out but they will come out - the ones that are slow to come out are likely the sticky ones. There was a lot of particle and crap gathering behind the pistons, with fluid (Motul RBF 600 - this is overkill for this truck - switching to Prestone Dot 4, which is very very good $4 fluid) that was only 20 months old which by the way became black behind the pistons. After cleaning, all 8 of my pistons were flawless, absolutely no pitting - at most I had a few teeny-tiny surface scratches which could not be felt with fingernails, so I think were acceptable to reuse. Before you run out and spend $200+ (and needing to return your original caliper) on 'reman' calipers, try cleaning and rebuilding the calipers during the regular brake service. These are high end, heavy duty calipers, so they need a bit more service to avoid braking issues. Just some additional comments below:
    1. 'Screwdriver method' of prying the pistons back into the caliper is a major contributor to sticky pistons- it’s an unacceptable method and it promotes the piston becoming angled-in against the square-seal. Make sure to invest in the pad-spreader tool to keep the pistons perpendicular while evenly pushing them into the caliper, if you aren’t going to rebuild them. The tool can even be used to block off the pistons when popping them out with compressed air if you do rebuild them.
    2. During vacuum bleeding, only some particles but not all particles stored behind the pistons will come out and get 'flushed'. Lots of garbage particles will still remain in the caliper, and due to the single fluid passageway in the caliper (there is only one port to get fluid to the outer 2 piston wells), will never come out unless the pistons are removed. These particles keep gathering and gathering and eventually work their way into the squareseal/piston interface - contributing sticky pistons. I think the particle material even gets under the seal groove, which causes the seal to compress harder than intended around the piston.
    3. Toyota/Lexus 4x4 trucks have 8 total brake pistons, not 2 or 4! - forget about “seized” pistons. It’s probably not going to happen unless you are constantly fording water. All it takes is 1 “sticky” piston to make braking miserable with the above symptoms.
    4. The longer the use your pads, the further out the boot is extended and which makes it more likely to take-on moisture and water, as well as having more surface area exposed for dry rotting. And the further the piston will need pressed back in anyway. You are better off just replacing the pads as soon as the pad dust groove is worn away. Don’t take them all the way down to 1/16” the way I did!
    Shamal, TacomaCZman, PzTank and 4 others like this.
  5. Apr 12, 2019 at 1:43 PM
    #265
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Awesome video. First time changing pads and Rotors myself. How long can I expect this to take? 2-3 hours, ish.
    303tacoma likes this.
  6. Apr 12, 2019 at 2:17 PM
    #266
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Yes
    After you do the first side the second side goes a lot quicker:thumbsup:
    TacomaCZman likes this.
  7. May 8, 2019 at 11:44 AM
    #267
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
  8. May 18, 2019 at 6:30 PM
    #268
    PasswordIsTaco123
    PasswordIsTaco123 Well-Known Member
    Scott
    Greenville SC
    2015 DCSB TRDOR
    2015 Silver Bullet Taco Installed: 5100's W OME887's +1/4leanspacer Toytec Boss Rear shocks Headstrong AAL + 1/2in block Ubolt Flip W superbumps Front Superbumps CB drop kit 4runner Trail Edition 17in Wheels Tires: Falken Wildpeak At3 C-load 275/70/17 Hooke Road Roof Rack Have but may/may not install Ex rear brake lines diff drop
    Norton likes this.
  9. May 30, 2019 at 8:47 PM
    #269
    youenjoymytacoAT2015
    youenjoymytacoAT2015 Pork Scratchins
    Colorado
    12' Silver DCLB 4x4
    LEER 180 Cap Squadron R Sport Fogs SCS F5 Wheels Stubby
    I cannot remember the page it was on so forgive me- the caliper grease goes between the caliper/shim and the shim/piston? Thank you in advance.
    Kory
  10. May 31, 2019 at 5:04 AM
    #270
    mbrogz3000
    Northern NJ
    Thin coating of brake grease or silicone paste only goes on the outer backing of the shim pads.
  11. May 31, 2019 at 8:01 AM
    #271
    PasswordIsTaco123
    Scott
    Greenville SC
    2015 DCSB TRDOR
    Just between the piston and the shim. Just make sure not to get any grease on the other side of the pads that contacts the rotors.
  12. May 31, 2019 at 9:32 AM
    #272
    Colorado
    12' Silver DCLB 4x4
    Awesome. Thank you for the replies!
  13. Jun 20, 2019 at 6:40 AM
    #273
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Hey folks,
    For those who switched to Speed Bleeders, have you used thread sealant?
    Thanks
  14. Jun 20, 2019 at 7:55 AM
    #274
    Norton
    I did not, when I installed mine ~8 months ago. No problems, so far.
    PzTank[QUOTED] likes this.
  15. Jun 28, 2019 at 9:38 AM
    #275
    BigDog1231
    BigDog1231 New Member
    Kevin
    2013 Dbl TRD
    Any one have a good guideline for when/ how often to replace front brake rotors?
    I get that if they are warped, then need to be either turned or replaced, but what is the general wear point? 60k 100k?
    Also any suggestions for the replacements? Cross drilled necessary/ helpful, or standard basic replacements for $50 just as good?
    Thanks
  16. Jul 2, 2019 at 6:04 AM
    #276
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    Curious why?
  17. Jul 3, 2019 at 1:02 PM
    #277
    PzTank
    Above the Notches
    Pads embed pad material onto the rotors. When properly bedded, the combination of the treated rotor and pads provide for optimal braking.
    This gets screwed up if you just change the pad with different material.
    TacomaCZman, Gunshot-6A and eherlihy like this.
  18. Jul 3, 2019 at 5:35 PM
    #278
    Jaypown
    Justin
    NE Ohio
    Ahh good to know. Thanks!
  19. Jul 4, 2019 at 5:26 AM
    #279
    PzTank
    Above the Notches
    FYI- ordered the Speed Bleeders 7100 and 1010 in SS. Ordering directly from SB is a bit funky where you have to order each separately but each pair comes in their own box. They should just charge $30 for the pair and be done w it.
    Also, both pairs came w thread locker on them.
    Norton likes this.
  20. Jul 5, 2019 at 11:25 AM
    #280
    TacoTuesday1
    SD CA
    Aren't brake discs supposed to have a minimum and maximum thickness specification stamped on them in the hub area?
    Maybe it's also written in a manual.
    I don't know if rotors warp or just develop a DTV (disc thickness variation) from uneven pad deposits or something, leading to pedal pulsation. And if 'turning' them on a lathe can remove that or not, or if lathes are precise enough to remove old material but still leave the rotor within thickness spec.
    Because with German cars on the other hand, I hear they tend to not turn their rotors vs. replace, because Germans don't advise it and the thickness spec range is so small that it doesn't give room with lathes that are said to take off a lot of material.
    I digress.
    I've always been told that you take a measuring caliper around the rotor to find the lowest point and that so long as it's above Min Thickness spec and not "warped" or any issues, to re-use it slapping on new pads whether you turn the rotor or not. By turn I mean cut. Because I heard 'turn' means cut on a lathe.
    Say a disc has old brake pad transfer material on it. And a new bad brakes against that. Is that worse? I don't know. I hear it can wear off and regenerate by laying down more. Maybe even by bedding.
    But to me, that's overthinking.
    Because if it has a thick pad squeezing a rotor, then the truck will probably stop. And will probably do better than some neglected other car on the road with a pad worn to the backing plate squealing against a thin rotor with no material left.
    Say the thickness spec says it's less than half worn. Then me personally I'd probably re-use it another time. Instead of new rotors every change. Because that adds a lot more cost versus just pads.
    Now if only I could figure out where/which brakes my pulsation is coming from and why...
    I guess one way would be to throw all new parts all around at it (expensive)
    Not even sure if I have my measuring calipers still; might be time to buy a pair, probably gonna be cheaper at Harbor Freight...
    I'm trying to figure out what parts to get too, and if I can do it the same way I did with my cabin air filter. Going with a name-brand but their cheapest version offering through RockAuto.
    Though with brakes things probably vary such as pad composition and disc metallurgy.
    Will admit, am still reading this thread. Not sure if this was discussed yet.
    But as for solid or cut, I hear slots help keep the pad clean but that drilled holes can cause rotor cracking.
