how to change sparkplugs 2TR-FE
Discussion in '4 Cylinder' started by YotaMan2007, May 16, 2011.
  1. Oct 12, 2012 at 7:24 PM
    #41
    tacoma65
    tacoma65 Member
    los angeles
    09 tacoma 4cylinder
    Hello guys im from california I did my tune up to my 09 tacoma with 55.000 miles replace the plugs iridiun ones i put all back ,before the rpm where 900 now after the tune up,it seen now they are around 400 n 600 and the truck stall ,any help will be very apreciated.
    miguel:confused: oh whats the difference between this spark plugs SK20HR11 and SK16HR11 ???
  2. Oct 14, 2012 at 8:36 PM
    #42
    tacoma65
    tacoma65 Member
    los angeles
    09 tacoma 4cylinder
    any body can help me?
  3. Oct 14, 2012 at 8:51 PM
    #43
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    SK20HR11 is the correct plug for your 2009 2.7l
    The SK16R11 has not been used since 2003.
    The SK16R11 is a hotter heat range plug. I don't know what the "H" refers to.
    Beyond that, we don't have enough information to offer any help. All we know is that you changed your plugs and now it's not running properly.
    Are all of the coil packs seated properly and reconnected?
    All of the electrical and hose connections that you had to disconnect to get to the plugs?
    This is something that's not going to be easy to troubleshoot on the internet, which is probably why you didn't get any responses Friday night.
    95SLE likes this.
  4. Oct 14, 2012 at 8:53 PM
    #44
    Rich91710
    Rich
    Los Angeles
    08 Base
    Not an unusual problem.
    I'll use a standard spark plug socket to remove the plugs since it'll "stick" and draw the plug out, but for reinstallation, I'll start the plug by hand with a piece of fuel line, then torque down with the rubber insert removed from the socket.
  5. Dec 6, 2012 at 9:53 AM
    #45
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    Great thread! Going to change mine over the weekend!
    Anybody see any MPG improvement?
  6. Dec 7, 2012 at 7:03 PM
    #46
    canucktacoma
    canucktacoma Active Member
    mike
    gta area, ontario canada
    sr5
    i just got a 2008 with 131km(cdn) on it still on originals,no record of them being checked,dealer sez 196km is ok,i just did diff fluid/tranny/&filters.will be checking plugs & rad fluid next.at least now i have a starting point going forward,expect to keep for a while,my santa fe has 265km & still runs great.little service goes long way.
  7. Dec 7, 2012 at 9:54 PM
    #47
    Rich91710
    Rich
    Los Angeles
    08 Base
    196k km is pushing it.
    On the 4 cylinder, the platinum plugs are good for around 100k miles or about 160k km.
    6 cylinder uses copper and change intervals are 30k miles or about 50k km.
  8. Dec 17, 2012 at 6:55 AM
    #48
    TacomaJack09
    Jackson
    Montana!
    06 Access Cab 4x4
    Just changed my plugs! Truck runs better but I'm throwing an error code now...
    Knew I would miss something lol
    Error code is: P2441 Secondary Air Injection System Control Valve Stuck Close.
    I'm going to go over it all again tonight, but anybody have any ideas of what I might've done? Thinking I missed a vacuum hose or something...
    Thanks!
  9. Dec 17, 2012 at 6:55 PM
    #49
    Rich91710
    Rich
    Los Angeles
    08 Base
    Hose, or a wiring connector.
    Check all connectors, even those you didn't disconnect, as they may have been pulled on and become dislodged.
  10. Mar 4, 2013 at 6:11 PM
    #50
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers
    Does anyone know what NGK laser Iridiums plugs that go into our trucks? Link or model number would be nice.
  11. Mar 4, 2013 at 8:32 PM
    #51
    Rich91710
    Rich
    Los Angeles
    08 Base
    This Kavik
    There's no reason to get some super special plug. Just go to the dealer and ask for the proper (Iridium) plug for your engine. You will get the proper size and heat range and you'll see no difference in mileage or performance with the "wiz bang" plug.
  12. Mar 4, 2013 at 8:38 PM
    #52
    Kavik
    Kavik Kavik
    Texas, DFW
    Ahh good, I didn't really wanna pay 12 bucks a plug.
  13. Mar 4, 2013 at 9:09 PM
    #53
    Rich91710
    Rich
    Los Angeles
    08 Base
    They're still going to run you around that.
    But they only need to be changed every 100k? I'd have to check the intervals.
    The 2.7 does use Iridium plugs, the 4.0 uses copper and changes at 30k.
    So change at 30k, every 90k you've spent $12 each on copper or $12 on Iridium. Same cost in the long run.
  14. Mar 4, 2013 at 9:16 PM
    #54
    Kavik
    Kavik Kavik
    Texas, DFW
    Good to know, I guess I will make a trip to a dealer soon
  15. Mar 16, 2013 at 11:10 AM
    #55
    fazerG8R
    fazerG8R New Member
    Kentucky
    04 2.4 Auto 2WD Tacoma
  16. Mar 18, 2013 at 11:34 AM
    #56
    Elkhound
    Elkhound Member
    Kurt
    New Hampshire
    Tacoma 4x4
    Thats a good website for NGK. Denso also has a website www.globaldenso.com/PLUG/ Just click on catalog downloads then click on Spark Plugs Training Manual 2005/2006 (English). This is a 100 page training manual. Page 61 gives notes for installing and removing Iridium plugs. There is no mention of using anti-seize.
    I purchsed my plugs from www.RockAuto.com At $5.79 a piece. Even with shipping it beats Advance Auto if you don't mind the wait. You can also search TW for RockAuto to get a discount code to use at checkout.
  17. Apr 12, 2013 at 8:32 PM
    #57
    Zacattack1
    Zacattack1 New Member
    Zac
    San Diego
    06' toyota tacoma 2.7L
    Pre-runner
    Brian your pic's of you changing your spark plugs have been helpful. I have a 06' toyota tacoma pre-runner sr5 regular cab, with 2.7L engine. My truck has 87k on it. I bought it used. Am just wondering when I should change plugs for this truck. Feed back would be helpful, thanks.
  18. Apr 23, 2013 at 10:29 PM
    #58
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    Can I use autolite double platinum plugs for the 2.7l?
  19. Apr 24, 2013 at 1:13 AM
    #59
    jmarquez808
    Jess
    Hawaii
    07 4x2 reg cab
    Full tune up!!
  20. Apr 24, 2013 at 8:36 PM
    #60
    Rich91710
    Rich
    Los Angeles
    08 Base
