how to change sparkplugs 2TR-FE
Discussion in '4 Cylinder' started by YotaMan2007, May 16, 2011.
  1. Apr 25, 2013 at 10:30 AM
    #61
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    i got these couple months ago from oreillys this is what they said was compatable, just dont want to buy the denso's after i spent the money on these ;/ im sure they will be fine right?
  2. Apr 25, 2013 at 9:28 PM
    #62
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I wouldn't.
    There's a lot of snake oil going with spark plugs, including the E3 abortions.
    Multiple electrodes are for the most part worse than the plugs that the factory intended. Some combustion chambers handle them okay, others, the extra electrodes just end up shielding the charge from the spark.
    Bosch Platinum 4+ are a frequent source of complaints in many engines.
  3. Aug 20, 2013 at 6:46 AM
    #63
    81shark
    81shark Well-Known Member
    did mine last night. super easy.
    picked up some denso iridium, but it looks like they aren't exactly the same part number.
    stuck them in anyways. not to concerned.
    i will say, the ones that came out, were the cleanest plugs i've ever pulled out of any car. just a little bit of light white build up on the electrodes.
  4. Aug 20, 2013 at 1:18 PM
    #64
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    How many miles on the old plugs ?
  5. Aug 21, 2013 at 7:19 AM
    #65
    81shark
    just over 91K miles. i can post pix tonight if you or any one else is interested.
  6. Aug 21, 2013 at 7:26 AM
    #66
    george3
    New Jersey
    Thanks. So color and gap were still good. Guess there is no reason to change them any earlier then the 100,000 recommendation. If you have time pics would be nice.
  7. Aug 21, 2013 at 2:27 PM
    #67
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    pics plz
  8. Aug 22, 2013 at 7:58 AM
    #68
    81shark
    here you go. spark plug order is random. i can't tell you which was #1. they all looked pretty close.
    enjoy
    Taco@Timez and HillJackJDS like this.
  9. Aug 22, 2013 at 2:40 PM
    #69
    91r100gs
    Dan
    Kansas City area
    Thanks they look great, eased my mind on mine with 65K
  10. Aug 22, 2013 at 2:59 PM
    #70
    george3
    New Jersey
    Thanks. How was the gap or didn't you bother ?
  11. Oct 6, 2013 at 6:27 PM
    #71
    my71chevynova
    my71chevynova Member
    Dave
    Gilroy, CA
    06 Base 4cyl
    Just tuned mine up today. Bought the truck at about 75K and im just shy of 120K. Called a mechanic a while back and they said wait until 120K. Took a road trip yesterday for a wedding that ate up way to much fuel. Runs a lot smoother now. This is so easy to do there is no sense in waiting as long as i was told to. Also side note, while your elbow deep in the tune up cleaning the throttle body is recommended as you basically expose it to get to the plugs anyways. Mine was pretty dirty.
  12. Oct 7, 2013 at 5:00 PM
    #72
    tacoma65
    tacoma65 Member
    los angeles
    09 tacoma 4cylinder
    How do you guys clean the throttle body.??
  13. Oct 7, 2013 at 8:38 PM
    #73
    Rich91710
    Rich
    Los Angeles
    08 Base
    Little throttle body cleaner sprayed on a microfiber towel. Wipe the butterfly around the perimeter inside and out, and wipe the bore where the butterfly rests.
    Next few restarts, expect a high idle until the ECU relearns where the proper idle point is.
  14. Oct 8, 2013 at 12:30 PM
    #74
    tacoma65
    tacoma65 Member
    los angeles
    09 tacoma 4cylinder
    thank you. Rich
  15. Oct 21, 2013 at 2:14 PM
    #75
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Just did mine at 93K and can say ditto to what 81shark saw on his plugs. Thought about a pic, but honestly they looked pretty much exactly the same. Bought Denso plugs from the dealer and the part numbers matched exactly.
    Did this too for the first time. Noticed a little high idle on my first start up/check out drive. But all seems well.
    My MPGs had dropped to the 19.5 to 20.2 range over the last 2 months. Looking to get back in a consistent 20 to 21 range. :notsure:
    :thumbsup: Thanks to YotaMan2007 for an excellent write-up. Made the job easy! :cool:
  16. Nov 11, 2013 at 2:52 PM
    #76
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I bought my 2009 Single Cab Tacoma with 2.7L 4 last February with 66,000 miles on it.
    I was skeptical about spark plugs lasting 100,000 miles so I pulled them and inspected them. They were clean and not eroded so I gapped them and put them back in. Denso Iridium plugs.
  17. Nov 19, 2013 at 11:55 AM
    #77
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Yes I agree those spark plugs look great, and it appears that they were installed without anti-seize... I could be wrong, but they look very compound-free all the way up the threads. Most plug manufacturers say that a shiny silver plating on the threads is a zinc or nickel plating that prevents seizing or galling, and no anti-seize is required. If the threads are dark or black, that indicates no plating is present and anti-seize is recommended. I'm doing some research before replacing my plugs and this information is pretty consistent among the manufacturers. The Denso SK20HR11 plugs spec'd for my 2006 2.7 have the shiny plating and I don't plan to use any anti-seize. I guess my final decision will be determined by what appears when the old ones are removed.
  18. Jan 20, 2014 at 2:19 PM
    #78
    george3
    New Jersey
    Just picked them up today. Probably won't do them til the Spring unless we get some mild weather - going 2 B in the single digits this week.
    Order Summary
    Product Subtotal: $35.96 Discounts: -$10.79 Shipping Charges: $0.00 Shipping Discount: $0.00 Core Charges: $0.00 Tax: $1.76 Total: $26.93
    If you want to save some $$ use this link
    http://www.tacomaworld.com/forum/deals-coupons/306515-advance-auto-30-off.html
  19. Feb 25, 2014 at 11:36 PM
    #79
    crawl
    crawl Well-Known Member
    Greg
    Valencia, CA
    2010 reg cab 4x4 sr5
    How much experience do you guys have in reading spark plugs?
    This is not something you should take lightly and not for your average DIY'r. Without the knowledge/ability/experience in reading plugs.. you're better off just simply replacing them.
    Spark plug part numbers:
    Unless you've contacted the tech dept. of the manufacturer and explained your intended use of a "different" plug number that is not on the application chart for your motor and year, you are taking a chance of damaging things. At the very least, you can hurt performance by changing the size of the spark, the depth of the spark in the cylinder, affecting timing, fueling........ BAD idea.
    Iridium spark plug gap:
    DO NOT gap or re-gap iridium plugs. Every manufacturer will clearly state this on their website.
  20. Feb 26, 2014 at 11:16 AM
    #80
    DGXR
    Friend
    Sacramento, CA
