how to change sparkplugs 2TR-FE
Discussion in '4 Cylinder' started by YotaMan2007, May 16, 2011.
  1. Feb 26, 2014 at 3:35 PM
    #81
    crawl
    crawl Well-Known Member
    Greg
    Valencia, CA
    2010 reg cab 4x4 sr5
  2. Mar 11, 2014 at 2:33 PM
    #82
    johnnyco
    johnnyco Member
    Just finished swapping out the plugs. Took about 1.5 hours. Next time it will be probably about 1 hour. Pretty straight forward with this handy thread and a Chiltons by my side. I was curious if I didnt attach the coils onto the end of the plugs as a i replacing each plug. But I guess they seated themselves when I reinstalled the coils because the truck now idles like a kitten. I cant even tell if the truck was running while idling!! I decided to torque the plugs to 10 Nm instead of Chiltons reccommended 20Nm. Just seemed too much for precious plugs. I also tweaked the gap a hair in order to get right at .043". I know that isnt reccommended but I did it before I read not too... No harm done.
    Fun and cheap little maintenance project. Thanks for the thread!!:)
  3. Jul 7, 2014 at 5:05 PM
    #83
    drogers0031
    drogers0031 Member
    Derek
    Sayville, NY
    2010 Reg Cab 4X4 5sp manual
    Avid Offroad Light Bar, Yellow OEM fog lights in bumper pockets, Leer 100XR Topper, 4 Leaf pack in rear, Bilstein 5100's on all four corners, Body debadged with front emblem and tailgate emblem rebadged in flat black.
  4. Jul 15, 2014 at 12:30 PM
    #84
    pinktaco808
    pinktaco808 Hot Steppa
    anyone notice any difference after they changed the plugs?
  5. Jul 15, 2014 at 2:00 PM
    #85
    81shark
    81shark Well-Known Member
    i didn't notice anything.
    i hate when people say this sort of thing, but the engine drives like it just came off the factory floor. i'm sure there are some minor differences, but it runs like a top after 101K miles
  6. Jul 15, 2014 at 8:14 PM
    #86
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    It's called "maintenance" for a reason.
    People that claim huge power gains with "special" plugs, or by going from copper to platinum or iridium... they would have seen the same gains with a new set of copper plugs because they left their plugs in too damned long.
    You should not see an improvement with any routine maintenance... the idea is to "fix" things before they become a problem.
    95SLE likes this.
  7. Jul 15, 2014 at 9:46 PM
    #87
    pinktaco808
    well i mean did it make it run like it was new again if you know what i mean
  8. Jul 15, 2014 at 9:50 PM
    #88
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ya, but it shouldn't be noticeable.
    If you notice it "running like new" with new plugs, you went too long.
    It's a Toyota. It should "run like new" until you tow it to the salvage yard as long as it is maintained properly.
    Taco@Timez likes this.
  9. Jul 17, 2014 at 6:38 AM
    #89
    81shark
    i do notice a change in how it runs after an oil change. always super smoooth for that first 25 miles or so.
  10. Jul 17, 2014 at 11:45 AM
    #90
    pinktaco808
    does it get better gas mileage?
  11. Jul 17, 2014 at 6:44 PM
    #91
    Binky
    Binky Member
    vince
    florida
    06 prerunner
    thanks alot for pics.helps alot
  12. Jul 18, 2014 at 8:59 AM
    #92
    81shark
    no
  13. Aug 24, 2014 at 10:01 AM
    #93
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    I returned to getting a consistent 20 to 21.5 MPG. I don't record it, but I generally check every fill up. As I stated above, I had noticed a drop which prompted me to change them at 93K miles, versus waiting until I hit 100K.
  14. Aug 24, 2014 at 4:11 PM
    #94
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Today I changed the plugs and cleaned the MAF sensor and throttle body. It revs a little higher on cold start but it's only been one start since the work, hopefully it will mellow a bit as the computer adjusts, had the battery disconnected for a couple hours while doing the work. It doesn't run any smoother but it always ran smooth - did the maintenance because 105k miles, not any driveability or performance issues. Everything went well, pretty easy work actually.
  15. Oct 2, 2014 at 7:48 AM
    #95
    garrettc134
    garrettc134 Active Member
    Just replaced mine for the first time at 130k miles. They looked surprisingly good, probably could have gone another 50, but meh for 20 dollars might as well change them especially since it was so easy. Thanks for the thread, wish they would give this kind of detail in my Haynes book...
  16. Oct 2, 2014 at 12:45 PM
    #96
    81shark
    i've got an excel file with mileage data by year/month/tank going back to when i purchased it in nov 05. i don't see any noticeable difference after the change. the only real variances i ever see are caused by road trips and cold/warm weather.
  17. Jan 2, 2015 at 9:16 PM
    #97
    pinktaco808
    Thanks man
  18. Jan 9, 2015 at 5:10 AM
    #98
    ojose
    ojose Active Member
    Jose
    San Juan, PR
    08 5-lug 4 cyl Base Access Cab
    I know this post is an oldie, but thanks for it. I've been searching for a while for a post on how to this with pictures.
  19. Feb 25, 2015 at 7:21 PM
    #99
    pinktaco808
    so how do you tighten it if no more torque wrench? hand tighten by hand with the ratchet off than 1/2 turn? i have ngk how deep extension do you need?
  20. Feb 26, 2015 at 5:44 AM
    #100
    pinktaco808
