How to: Change the alternator on a 2nd gen Tacoma.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaPrime, Aug 31, 2011.
  1. Jan 28, 2017 at 11:05 PM
    #41
    pinktaco808
    pinktaco808 Hot Steppa
    Anyone got pics of a 4 cylinder.
  2. Jan 29, 2017 at 12:11 AM
    #42
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  3. Jan 29, 2017 at 12:16 AM
    #43
    Chuy
    Lakeside, CA
    Silver Taco
    Oops. Double post.
    pinktaco808 likes this.
  4. Jan 29, 2017 at 12:26 AM
    #44
    pinktaco808
    How many bolts ? 2 or 3
  5. Jan 29, 2017 at 2:35 AM
    #45
    Chuy
    Lakeside, CA
    Silver Taco
  6. Apr 13, 2017 at 11:33 AM
    #46
    fleschdnb
    fleschdnb Active Member
    jason
    2008 Tacoma PreRunner SR5 (ex fake Limited Edition TRD Sport)
    3rd party (uhaul) frame mounted tow hitch and Tranny cooler
    Welp, tried to do this myself on a 08 4.0L prerunner 2wd with 1GRFE engine. There is no way to get the alt out the top without removing the battey cable wire harness and that bracket on the side of the engine block (the one you have to remove to pull the sparkplugs). All the videos i watched showed the tensioner pully on the passenger side of the fan,on mine it was the one right next to the alternator. Plus looked like a bitch to get out from bottom after taking off the skidplate so i probably would have had to take it out through the wheel well. Decided to just take it to the local shop and have them do it for $81.00. Autozone 130amp tow package alternator was 127.00 and 80 to put the new one in. Too much hassle, that alternator is too deep for me. Lol. My alt worked, but had the notorious diode whine that follows the rpms. 200 well spent. Woulda taken me hours. Took the mechanic 1 hour.
  7. Apr 13, 2017 at 12:19 PM
    #47
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    You didn't try hard enough. It definitely can be taken out the top. If you watched videos of Tacomas with 1grfe it's the same as yours.
  8. Apr 14, 2017 at 12:50 AM
    #48
    Chuy
    Lakeside, CA
    Silver Taco
    I, also, found it quite a hassle to take it out the top. Path of least resistance was through the driver-side wheel wheel. Came out easy once the 5 or so plastic clips and the rubber skirt is removed. Didn't have to remove tire either.
  9. Jun 18, 2017 at 4:39 PM
    #49
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Just got my alternator out of my '07 OR. Thanks to all who contributed this thread! I was up top, down below w the skid plate off...success in getting it out. Hopefully equal success in getting the new one in tomorrow....:thumbsup:
    Sandman614 likes this.
  10. Jun 27, 2017 at 7:24 AM
    #50
    PzTank
    Above the Notches
    A week later than planned but I was successful in getting the alternator in. Can't remember if it been posted here but when you get the top mounting bolt snugged but not torqued down, you can then pivot the alternator to get the bottom bolt in. Not as much as a pain in the ass as it looks. Thanks again folks! Side note, not bad to get 351k miles out of the original :cheers:
  11. Jul 4, 2017 at 10:09 AM
    #51
    Dajeepman
    Dajeepman Well-Known Member
    Andrew
    Pittsburg , Tx
    2006 Gold Tacoma base 4x4
    Mine just died at 102k. It wines like crazy. Gonna go back with a bigger towing package alternator this time over the 100amp. Started to start little slugish. And I put a volt meter on it and it was 11.6v. Now I have a charger on it and hopefully it will charge the battery so I can get to the store.
  12. Jul 4, 2017 at 10:16 AM
    #52
    Sandman614
    Tim
    '06 SR5 Off Road
    Sounds like the diodes are capping out. Can be fixed
    https://www.tacomaworld.com/threads/2nd-gen-1grfe-alternator-rebuild-mud-cleanout.453757/
  13. Aug 28, 2017 at 10:48 AM
    #53
    mnerren
    mnerren 2006 Tacoma TRD Sport XSP
    Jacksonville, FL
    2006 Tacoma TRD Sport Double Cab
    I just did mine. I pulled the fan and shroud. It wasn't that big of a deal. Just removing the fan was a little pain in the ass. I bought a re-manufactured alternator for 145 and I think the dealer wanted 650 to do the job. I hope this one will last as long as the original, I have 156,000 miles on it as of now.
  14. Sep 8, 2017 at 8:03 PM
    #54
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Is it possible to tell which alternator you have without removing it? I have a 120A fuse in the alternator fuse spot.
  15. Sep 9, 2017 at 10:41 AM
    #55
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Sub'd
  16. Aug 10, 2018 at 1:02 AM
    #56
    tudes
    tudes Well-Known Member
    d
    SoCal
    2011 Tacoma TX-Pro Off Road DCSB in Super White
    OEM everything, almost.
    Mine just died. 156K.
    Nearly stranded on the FWY, but managed to pull off and called AAA. Need to take care of this today.
    First my Bluetooth stopped picking up my phone, radio doesn't turn on, dash lights all started to come on one by one... and flicker.
    I was losing power and couldn't accelerate hard, all while moving at 30+ MPH.
  17. Aug 10, 2018 at 1:09 AM
    #57
    bagleboy
    Scott
    Norcal, Santa Rosa
    This is why I installed a digital voltage readout. Didn't have one in my last truck and had a similar experience I dont want to repeat. Now I should be able to see a drop in output when the alternator gets old as well as battery voltage before engine start.
  18. Oct 15, 2018 at 7:07 PM
    #58
    BenSkiv
    BenSkiv Well-Known Member
    Ben
    Maine
    2019 Tacoma TRD-off-road DCLB
    Quick question, will an alternator from a 2015 Tacoma work in a 2006 Tacoma?
  19. Oct 15, 2018 at 9:23 PM
    #59
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    If your eyes are good enough and you are running an OEM Denso, there should be a part number on it. Go to one of the many parts sites and provide that #. Should get clarification am AMPerage.
  20. Oct 15, 2018 at 9:40 PM
    #60
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Probably.. it is the same engine
    BenSkiv[QUOTED] likes this.
